410-138P-KIT
410-138P-KIT
    DIGILENT(迪芝伦)
    BOARD GENESYS FOR VIRTEX-5
410-138P-KIT 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com Genesys™ FPGA Board Reference Manual Revised April 11, 2016 This manual applies to the Genesys rev. C Overview The Genesys circuit board is a complete, ready-to-use digital circuit development platform based on a Xilinx Virtex 5 LX50T. The large on-board collection of high-end peripherals, including Gbit Ethernet, HDMI Video, 64-bit DDR2 memory array, and audio and USB ports make the Genesys board an ideal host for complete digital systems, including embedded processor designs based on Xilinx's MicroBlaze. Genesys is compatible with all Xilinx CAD tools, including ChipScope, EDK, and the free WebPack, so designs can be completed at no extra cost. The Virtex5-LX50T is optimized for highperformance logic and offers:       Adept USB2 7,200 slices, each containing four 6input LUTs and eight flip-flops 1.7Mbits of fast block RAM 12 digital clock managers six phase-locked loops 48 DSP slices 500MHz+ clock speeds The Genesys board includes Digilent's newest Adept USB2 system, which offers device programming, real-time power supply monitoring, automated board tests, virtual I/O, and simplified user-data transfer facilities. A second USB programming port, based on the Xilinx programming cable, is also built into the board. A comprehensive collection of board support IP and reference designs, and a large collection of add-on boards are available on the Digilent website. 20 4 iMPACT USB2 DDR2 256MByte 132 49 StrataFlash 32Mbyte HDMI Video Up to 1080i 20 5 AC-97 Audio Codec 10/100/1000 Ethernet PHY 29 25 USB Host Basic I/O 23 Digilent port for JTAG & data LEDs, Buttons, switches 16x2 LCD Virtex 5 XC5VLX50T FFG1136C With OTG Clock Gen Programmable 11 2 RS-232 Port UART COM link 80 2x 68-pin VHDCI DOC#: 502-138 8 Char. Display High-Speed Expansion Xilinx programming Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. 32 Pmod Port Expansion 4x 12-pin Page 1 of 27 Genesys™ FPGA Board Reference Manual Features include:             Xilinx Virtex 5 LX50T FPGA, 1136-pin BGA package 256Mbyte DDR2 SODIMM with 64-bit wide data 10/100/1000 Ethernet PHY and RS-232 serial port multiple USB2 ports for programming, data, and hosting HDMI video up to 1600x1200 and 24-bit color AC-97 Codec with line-in, line-out, mic, and headphone real-time power monitors on all power rails 16Mbyte StrataFlash™ for configuration and data storage Programmable clocks up to 400MHz 112 I/O's routed to expansion connectors GPIO includes eight LEDs, two buttons, two-axis navigation switch, eight slide switches, and a 16x2 character LCD ships with a 20W power supply and USB cable 1 Configuration After power-on, the FPGA on the Genesys board must be configured (or programmed) before it can perform any functions. A USB-connected PC can configure the board using the JTAG interface anytime power is on, or a file can be automatically transferred from the StrataFlash ROM at power-on. An on-board "mode" jumper selects which programming mode will be used. Both Digilent and Xilinx freely distribute software that can be used to program the FPGA and the Flash ROM. Configuration files stored in the ROM use the Byte Peripheral Interface (BPI) mode. In BPI UP mode, the FPGA loads configuration data from the StrataFlash in an ascending direction starting at address 000000. In BPI DOWN mode, configuration data loads in a descending direction starting at address 03FFFF. J7 Digilent Adept USB J21 JTAG Header Xilinx iMPACT USB J11 JTAG configuration To Adept USB BPI configuration PROG_B Numonyx StrataFlash 32Mbytes DONE HSWEN M0 M1 M2 Mode Jumper JP8 Virtex 5 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. 1 0 JTAG 1 0 BPI 1 0 UP 1 BPI 1 0 DOWN Page 2 of 27 Genesys™ FPGA Board Reference Manual Power Jack Power Switch Digilent Adept USB Port Mode Jumper Power Good LED Xilinx iMPACT USB Port JTAG Header Once transferred, programming files are stored in SRAM-based memory cells within the FPGA. These SRAM cells define the FPGA's logic functions and circuit connections until they are erased, either by removing power or asserting the PROG_B input. FPGA configuration files transferred using the JTAG interface use the .bin and .svf file types, and BPI files use the .bit, .bin, and .mcs file types. Xilinx's ISE WebPack and EDK software can create .bit, .svf, .bin, or .mcs files from VHDL, Verilog, or schematic-based source files (EDK is used for MicroBlaze™ embedded processor-based designs). Digilent's Adept software and Xilinx's iMPACT software can be used to program the Genesys board from a PC's USB port. During FPGA programming, a .bit or .svf file is transferred from the PC to the FPGA using the USB-JTAG port. When programming the ROM, a .bit, .bin, or .mcs file is transferred to the ROM in a two-step process. First, the FPGA is programmed with a circuit that can transfer data from the USB-JTAG port into the ROM, and then data is transferred to the ROM via the FPGA circuit (this complexity is hidden and a simple "program ROM" interface is shown). After the ROM has been programmed, it can automatically configure the FPGA at a subsequent power-on or reset event if the Mode jumpers are set to the proper BPI mode. A programming file stored in the StrataFlash ROM will remain until it is overwritten, regardless of power-cycle events. 2 Adept System 2.1 Adept and iMPACT USB Ports The Genesys board includes two USB peripheral ports – one for Adept software and another for Xilinx's iMPACT software. Either port can program the FPGA and StrataFlash, but Adept offers a simplified user interface and many additional features such as automated board test and user-data transfers. The Adept port is also compatible with iMPACT, if the Digilent Plug-In for Xilinx Tools is installed on the host PC (download it free from the Digilent website). Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 3 of 27 Genesys™ FPGA Board Reference Manual Digilent Adept USB port D_P Control [11:0] See table D_N FIFO DATA [7:0] See table Micro-USB Virtex 5 2 SCK (VID/PID) SDA I C ROM CYPRESS 68013A TMS TCK TDO TDI FPGA JTAG programming port Parallel JTAG data D_P Xilinx iMPACT USB port D_N CYPRESS 68013A Micro-USB I2C ROM (VID/PID) CPLD SCK SDA The plug-in automatically translates iMPACT-generated JTAG commands into formats compatible with the Digilent USB port, providing a seamless programming experience without leaving the Xilinx tool environment. All Xilinx tools (iMPACT, ChipScope, EDK, etc.) can work with the plug-in, and they can be used in conjunction with Adept tools (like the power supply monitor). Adept's high-speed USB2 system can be used to program the FPGA and ROM, run automated board tests, monitor the four main board power supplies, add PC-based virtual I/O devices (like buttons, switches, and LEDs) to FPGA designs, and exchange register-based and file-based data with the FPGA. Adept automatically recognizes the Genesys board and presents a graphical interface with tabs for each of these applications. Adept also includes public APIs/DLLs so that users can write applications to exchange data with the Genesys board at up to 38Mbytes/sec. The Adept application, an SDK, and reference materials are freely downloadable from the Digilent website. The Xilinx USB port is based on the Xilinx USB programming cable. It can be accessed by all Xilinx CAD tools and iMPACT. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 4 of 27 Genesys™ FPGA Board Reference Manual 2.2 Programming Interface To program the Genesys board using Adept, first set up the board and initialize the software:      plug in and attach the power supply plug in the USB cable to the PC and to the USB port on the board start the Adept software turn on Genesys' power switch wait for the FPGA to be recognized. Use the browse function to associate the desired .bit or .svf file with the FPGA, and click on the Program button. The configuration file will be sent to the FPGA, and a dialog box will indicate whether programming was successful. The configuration "done" LED will light after the FPGA has been successfully configured. Before starting the programming sequence, Adept ensures that any selected configuration file contains the correct FPGA ID code – this prevents incorrect .bit files from being sent to the FPGA. In addition to the navigation bar and browse and program buttons, the Config interface provides an Initialize Chain button, console window, and status bar. The Initialize Chain button is useful if USB communications with the board have been interrupted. The console window displays current status, and the status bar shows real-time progress when downloading a configuration file. 2.3 Flash Interface The Flash programming application allows .bin, .bit, and .mcs configuration files to be transferred to the onboard StrataFlash ROM for BPI programming, and allows user data files to be transferred to/from the Flash at user-specified addresses. The configuration tool supports BPI UP and BPI DOWN programming from any valid ROM file produced by the Xilinx tools (be sure the mode jumpers are set to BPI UP/DOWN appropriately, or Genesys will not autoconfigure properly.) The Read/Write tools allow data to be exchanged between files on the host PC and specified address ranges in Flash. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 5 of 27 Genesys™ FPGA Board Reference Manual 2.4 Test Interface The test interface provides a quick and easy way to verify many of the board's hardware circuits and interfaces. Clicking Start Test will configure the FPGA with test and PC-communication circuits, overwriting any FPGA configuration that may have been present. Once the indicator near the Start Test button turns green, all available tests can be run. The Test RAM and Test Flash utilities write/read data to/from all pages, ensuring the devices are working properly and no signals have shorts or opens. The Test Shorts feature checks all discrete I/O's for shorts to Vdd, GND, and neighboring I/O pins. The switches and buttons graphics show the current states of those devices on the Genesys board. Future releases of Adept may add additional tests, and more board features can be tested using reference projects available on the Digilent website. 2.5 Power The power application provides highly-accurate (better than 1%) real-time voltage, current, and power readings from four on-board TI power-supply monitors. The monitors are based on the TI INA219 high-side current and power monitors, which are configured to return 16-bit samples for each channel at 16Hz, with each returned sample being the average of 128 sub-samples. A 5mOhm shunt resistor and selected INA219 gain setting provide 4mV and 2mA measurement resolution. Real-time voltage, current, and power data is displayed in tabular form and updated continuously when the power meter is active (or started). Historical data is available using the Show Graph feature, which shows a graph with voltage, current, and power plots for all four power supplies for up to ten minutes. Recorded values are also stored in a buffer that can be saved to a file for later analysis. Save Buffer and Clear Buffer are used to save and clear the historical data in the buffer. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 6 of 27 Genesys™ FPGA Board Reference Manual 2.6 Register I/O The register I/O tab requires that a corresponding IP block, available in the Parallel Interface reference design (DpimRef.vhd) on the Adept page of the Digilent website, is included and active in the FPGA. This IP block provides an EPP-style interface, where an 8-bit address selects a register, and data read and write buttons transfer data to and from the selected address. Addresses entered into the address field must match the physical address included in the FPGA IP block. Register I/O provides an easy way to move small amounts of data into and out of specific registers in a given design. This feature greatly simplifies passing control parameters into a design, or reading lowfrequency status information out of a design. 2.7 File I/O The File I/O tab can transfer arbitrarily large files between the PC and the Genesys FPGA. A number of bytes (specified by the Length value) can be streamed into a specified register address from a file or out of a specified register address into a file. During upload and download, the file start location can be specified in terms of bytes. As with the Register I/O tab, File I/O also requires specific IP to be available in the FPGA. This IP can include a memory controller for writing files into the on-board DDR2 and Flash memories. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 7 of 27 Genesys™ FPGA Board Reference Manual 2.8 I/O Expand The I/O Expand tab works with an IP block in the FPGA to provide additional simple I/O beyond the physical devices found on the Genesys board. Virtual I/O devices include a 24-LED light bar, 16 slide switches, 16 push buttons, 8 discrete LEDs, a 32-bit register that can be sent to the FPGA, and a 32-bit register that can be read from the FPGA. The IP block, available in the Adept I/O Expansion reference design (AdeptIOExpansion.zip) on the Adept page of the Digilent website, provides a simple interface with well-defined signals. This IP block can easily be included in, and accessed from, user-defined circuits. For more information, please see the Adept documentation available at the Digilent website. 3 Power Supplies The Genesys board requires an external 5V 4A or greater power source with a coax center-positive 2.1mm internal-diameter plug (a suitable supply is provided as a part of the Genesys kit). Voltage regulator circuits from Texas Instruments create the required 3.3V, 2.5V, 1.8V, 1.0V, and 0.9V supplies from the main 5V supply. The table below provides additional information (typical currents depend strongly on FGPA configuration; the values provided are typical of medium size/speed designs). Supply 3.3V 2.5V 1.0V 1.8V 0.9V Circuits Device FPGA I/O, Video, RS-232, USB, Clocks, ROM, Audio FPGA Aux, VHDC, Ethernet PHY I/O, GPIO FPGA Core, Ethernet PHY core DDR & FPGA DDR I/O DDR SODIMM Termination Voltage (VTT) Amps (max/typ) IC20: TPS54620 6A / 700mA IC21: TPS54620 IC25: TPS54620 IC23: TPS54620 IC22: TPS51100 6A / 400mA 6A / 0.8 – 1.2A 6A / 1A 3A / 1A Table 1: Genesys Power Supplies. The four main voltage rails on the Genesys board use TI INA219 power supply monitors to continuously measure voltage, current, and power. Measured values may be viewed on a PC using Digilent's power meter that is a part of the Adept software. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 8 of 27 Genesys™ FPGA Board Reference Manual I2C Bus To Digilent Adept USB .005 TPS54620 Power Switch 3.3V 6A Regulator OFF EN PG INA219 IC20 ON .005 TPS54620 Power Jack 2.5V 6A Regulator VU EN PG INA219 IC21 Battery Connector .005 TPS54620 1.8V 6A Regulator EN Power Select Jumper JP13 PG INA219 IC23 .005 TPS54620 1.0V 6A Regulator EN PG INA219 IC25 Load Switch Vswt TPS51100 0.9V DDR Term. Reg. EN IC24 Power On LED (LD8) IC22 To Expansion Connectors, LCD, HDMI, USB Genesys power supplies are controlled by a logic-level switch (SW9) that enables/disables the power supply controller IC's. A power-good LED (LD8), driven by the "power good" outputs on all supplies, indicates that all supplies are operating within 10% of nominal. A load switch (the TPS51100) passes the input voltage VU to the "Vswt" node, depending on the state of the power switch. Vswt is assumed to be 5V, and is used by many systems on the board including the LCD, HDMI ports, I2C bus, and USB host. Vswt is also available at expansion connectors, so that any connected boards can be turned off along with the Genesys board. 4 DDR2 Memory A single small outline dual in-line memory module (SODIMM) connector is provided and loaded with a Micron MT4HTF3264HY-667D3 (or equivalent) single-rank unregistered 256Mbyte DDR2 module (additional address lines and chip selects are routed, so that similar SODIMMs with densities up to 2GB may be used). Serial Presence Detect (SPD) using an IIC interface to the DDR DIMM is also supported. The Genesys board has been tested for DDR2 operation at a 400MHz data rate. Faster data rates might be possible but are not tested. The DDR2 interface follows the pinout and routing guidelines specified in the Xilinx Memory Interface Generator (MIG) User Guide. The interface supports SSTL18 signaling, and all address, data, clocks, and control signals are delay-matched and impedance-controlled. Address and control signals are terminated through 47-ohm resistors to Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 9 of 27 Genesys™ FPGA Board Reference Manual a 0.9V VTT, and data signals use the On-Die-Termination (ODT) feature of the SODIMM. Two well-matched DDR2 clock signal pairs are provided to the SODIMM that can be driven with low-skew clocks from the FPGA. x14 Virtex 5 H30 E31 K29 G31 J30 R31 L29 J29 F31 F30 RAS# CAS# WE# BA0 BA1 BA2 S0# S1# ODT0 ODT1 14 AD[13:0] 64 DQ[63:0] 16 See Table DS[7:0] (differential) 8 DM[7:0] 2 I2C (SDA, SCK) 6 Data DDR2 SODIMM Clocks (differential) Address Strobes Clk,Mask,I2C Control DQ0: AF30 DQ16: AC28 DQ32: V29 DQ48: M28 AD0: L30 DS0P: AA29 CK0P: AK29 RAS#: H30 DQ1: AK31 DQ17: AB25 DQ33: Y27 DQ49: L28 AD1: M30 DS0N: AA30 CK0N: AJ29 CAS#: E31 DQ2: AF31 DQ18: AC27 DQ34: Y26 DQ50: F25 AD2: N29 DS1P: AK28 CK1P: E28 WE#: K29 DQ3:AD30 DQ19: AA26 DQ35: W24 DQ51: H25 AD3: P29 DS1N: AK27 CK1N: F28 BA0: G31 DQ4: AJ30 DQ20: AB26 DQ36: V28 DQ52: K27 AD4: K31 DS2P: AK26 CKE0: T28 BA1: J30 DQ5: AF29 DQ21: AA24 DQ37: W25 DQ53: K28 AD5: L31 DS2N: AJ27 CKE1: U30 BA2: R31 DQ6: AD29 DQ22: AB27 DQ38: W26 DQ54: H24 AD6: P31 DS3P: AB31 DM0: AJ31 S0: L29 DQ7: AE29 DQ23: AA25 DQ39: V24 DQ55: G26 AD7: P30 DS3N: AA31 DM1: AE28 S1: J29 DQ8: AH27 DQ24: AC29 DQ40: R24 DQ56: G25 AD8: M31 DS4P: Y28 DM2: Y24 ODT0: F31 DQ9: AF28 DQ25: AB30 DQ41: P25 DQ57: M26 AD9: R28 DS4N: Y29 DM3: Y31 ODT1: F30 DQ10: AH28 DQ26: W31 DQ42: N24 DQ58: J24 AD10: J31 DS5P: E26 DM4: V25 DQ11: AA28 DQ27: V30 DQ43: P26 DQ59: L26 AD11: R29 DS5N: E27 DM5: P24 DQ12: AG25 DQ28: AC30 DQ44: T24 DQ60: J27 AD12: T31 DS6P: H28 DM6: F26 DQ13: AJ26 DQ29: W29 DQ45: N25 DQ61: M25 AD13: H29 DS6N: G28 DM7: J25 DQ14: AG28 DQ30: V27 DQ46: P27 DQ62: L25 DS7P: G27 SDA: F29 DQ15: AB28 DQ31: W27 DQ47: N28 DQ63: L24 DS7N: H27 SCK: E29 Table 2. DDR2 SODIMM pinout. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 10 of 27 Genesys™ FPGA Board Reference Manual 5 Flash Memory The Genesys board uses a 256Mbit Numonyx P30 parallel flash memory device (organized as 16-bit by 16Mbytes) for non-volatile storage of FPGA configuration files. Configuration files are stored using the byte-peripheral interface mode (BPI) in either up or down configurations. A single FPGA configuration file requires less than 16Mbits, leaving 140Mbits available for user data. Data can be transferred to/from the Flash by user applications, or by facilities built into the Adept software. A reference design on the Digilent website provides an example of driving the Flash memory. Address Signals AE14 AF14 AF20 AG21 AG17 AH18 AF21 CE# OE# WE# CLK RESET# WAIT ADV# 25 See Table 16 WP A[24:0] DQ[15:0] Virtex 5 StrataFlash A0: K12 A1: K13 A2: H23 A3: G23 A4: H12 A5: J12 A6: K22 A7: K23 A8: K14 A9: L14 A10: H22 A11: G22 A12: J15 A13: K16 A14: K21 A15: J22 A16: L16 A17: L15 A18: L20 A19: L21 A20: AE23 A21: AE22 A22: AG12 A23: AF13 A24: AG23 Data Signals D0: AD19 D1: AE19 D2: AE17 D3: AF16 D4: AD20 D5: AE21 D6: AE16 D7: AF15 D8: AH13 D9: AH14 D10: AH19 D11: AH20 D12: AG13 D13: AH12 D14: AH22 D15: AG22 A board test/demonstration program is loaded into the StrataFlash during manufacturing. That configuration, also available on the Digilent webpage, can be used to demonstrate and check all of the devices and circuits on the Genesys board. 6 Ethernet PHY The Genesys board includes a Marvell Alaska Tri-mode PHY (the 88E1111) paired with a Halo HFJ11-1G01E RJ-45 connector. Both MII and GMII interface modes are supported at 10/100/1000 Mb/s. Default settings used at power-on or reset are:      MII/GMII mode to copper interface Auto Negotiation Enabled, advertising all speeds, preferring Slave MDIO interface selected, PHY MDIO address = 00111 No asymmetric pause, no MAC pause, automatic crossover enabled Energy detect on cable disabled (Sleep Mode disabled), interrupt polarity LOW The data sheet for the Marvell PHY is available from Marvell only with a valid NDA. Please contact Marvell for more PHY-specific information. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 11 of 27 Genesys™ FPGA Board Reference Manual EDK-based designs can access the PHY using either the xps_ethernetlite IP core for 10/100 Mbps designs, or the xps_ll_temac IP core for 10/100/1000 Mbps designs. The xps_ll_temac IP core uses the hard Ethernet MAC hardware core included in the Virtex 5 FPGA. U10 N5 T6 L4 K6 L5 MDIO MDC INT# RESET# COL CRS N8 L19 RX_DV RX_CLK RX_ER See Table 8 J20 J16 R8 T10 See Table RXD GTX_CLK TX_CLK TX_ER TX_EN 8 Virtex 5 RXD Signals Halo HFJ11 Integrated magnetics 8 x14 CONFIG 7 CLK TXD Marvell M88E1111 RXD0: N7 RXD1: R6 RXD2: P6 RXD3: P5 RXD4: M7 RXD5: M6 RXD6: M5 RXD7: L6 TXD Signals 0001101 25MHz (from IDT5V9885) TXD0: J5 TXD1: G5 TXD2: F5 TXD3: R7 TXD4: T8 TXD5: R11 TXD6: T11 TXD7: U7 The Genesys BSB support package automatically generates a test application for the Ethernet MAC; this can be used as a reference for creating custom designs. Another example Ethernet-based design (the web server) can be found on the Digilent website. ISE designs can use the IP Core Generator wizard to create a tri-mode Ethernet MAC controller IP core. 7 USB Host A Cypress CY7C67300 USB controller provides the Genesys board with USB host and peripheral capability. The CY7C67300 includes two serial interface engines (SIE) that can be used independently. SIE1 is connected to a Type A USB host connector (J8), and SIE2 is connected to a Type B USB peripheral connector (J9). The USB controller has an internal microprocessor to assist in processing USB commands; a dedicated IIC EEPROM (IC9) is available for storing firmware. Firmware can be developed for the processor and/or written to the EEPROM using the Cypress CY3663 EZ-OTG™/EZ-Host™ development kit available from Cypress. To assist with debug, the USB controller's two-wire serial port is connected to two FPGA pins (USB-RX to FPGA pin V9, USB-TX to FPGA pin W7) using LVCMOS33 I/O standards. Jumper JP14 can be installed to prevent the USB controller from executing firmware stored in the IIC EEPROM. To access the USB host controller, EDK designs can use the xps_epc IP core. Reference designs posted on the Digilent website show an example for reading characters from a USB keyboard connected to the USB host interface. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 12 of 27 Genesys™ FPGA Board Reference Manual AD4 AE6 AF6 AE7 AD5 AD6 V9 W7 AJ6 See Table A0 A1 CS WR RD INT RX TX RESET 16 2 Data Signals Vusbp V_INT 2 I2C I2C ROM 24AA128 12MHz (from IDT5V9885) CLK Vswt D[15:0] Virtex 5 USB Periph Type B USB Power Switch Vusbh EN OC# TPS2041 HOST_EN Over_Current 2 Cypress CY7C67300 8 D0: Y6 D1: AA6 D2: Y7 D3: Y9 D4: W10 D5: AC5 D6: Y11 D7: AJ7 D8: AH7 D9: AH5 D10: AG6 D11: AG7 D12: AK7 D13: AK6 D14: AG5 D15: AF5 USB Host Type A Video Output Video output is accomplished using a Chrontel CH7301C DVI transmitter device connected to a standard Type A HDMI connector (J3). DVI and HDMI share a common TMDS signaling standard, so a simple adaptor can be used to convert the HDMI connector to a DVI connector (VGA signals are not available on the HDMI connector). The Chrontel CH7301C (IC3) supports up to 1600 X 1200 resolutions with 24-bit color. Status and control information can be moved between the FPGA and the CH7301C using an I2C bus (SCL to FPGA pin U8, and SDA to FPGA pin V8, both using the LVCMOS33 I/O standard). The I2C bus is also routed to the HDMI connector to allow direct communications with external monitors. EDK designs can use the xps_tft IP core (and its associated driver) to access the Chrontel device. The xps_tft core reads video data from the DDR2 memory, and sends it to the Chrontel device for display on an external monitor. The IP core is capable of resolutions of 640X480 at 18 bits per pixel. An EDK reference design available on the Digilent website (and included as a part of the User Demo) reads a bitmap file from the StartaFlash memory and displays it on the monitor. Another second EDK reference design (included in the User test available though Adept) displays a gradient color bar and a text in the center of the screen. An ISE reference design is available that displays a color bar. This reference design provides and example of using the DVI circuit with an ISE project. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 13 of 27 Genesys™ FPGA Board Reference Manual J11 K11 V9 V10 F13 H8 W9 CLKN CLKP RESET DE V H INT V8 U8 See Table Virtex 5 Data Signals D0: G10 D1: G8 HDMI Vid I2C D2: B12 8 D3: D12 D4: C12 2 D5: D11 I2C_DAT I2C_CLK 12 D6: F10 D7: D10 D8: E9 D[11:0] D9: F9 Chrontel CH7301C D10: E8 D11: F8 9 Audio (AC-97) The Genesys board includes a National Semiconductor LM4550 AC '97 audio codec (IC19) with four 1/8" audio jacks for line-out (J16), headphone-out (J18), line-in (J15) and microphone-in (J17). Audio data at up to 18 bits and 48-kHz sampling is supported, and the audio in (record) and audio out (playback) sampling rates can be different. The microphone jack is mono; all other jacks are stereo. The headphone jack is driven by the audio codec's internal 50mW amplifier. The table below summarizes the audio jacks. The LM4550 audio codec is compliant to the AC '97 v2.1 (Intel) standard and is connected as a Primary Codec (ID1 = 0, ID0 = 0). The table below shows the AC '97 codec control and data signals. All signals are LVCMOS33. Virtex 5 AH17 AE18 AG20 J9 E12 SDO BIT-CLK SDI SYNC RESET HdPhn Out LM4550 AC-97 Audio Codec Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Line Out Line In MIC In Page 14 of 27 Genesys™ FPGA Board Reference Manual Signal Name FPGA Pin AUD-BIT-CLK AH17 AUD-SDI AE18 AUD-SDO AG20 AUD-SYNC J9 AUD-RESET E12 Pin Function 12.288MHZ serial clock output, driven at one-half the frequency of the 24.576MHz crystal input (XTL_IN) Serial Data In (to the FPGA) from the codec. SDI data consists of AC '97 Link Input frames that contain both configuration and PCM audio data. SDI data is driven on the rising edge of AUD-BIT-CLK. Serial Data Out (to the codec) from the FPGA. SDO data consists of AC '97 Link Output frames that contain both configuration and DAC audio data. SDO is sampled by the LM4550 on the falling edge of AUD-BIT-CLK. AC Link frame marker and Warm Reset. SYNC (input to the codec) defines AC Link frame boundaries. Each frame lasts 256 periods of AUD-BIT-CLK. SYNC is normally a 48kHz positive pulse with a duty cycle of 6.25% (16/256). SYNC is sampled on the rising edge of AUD-BIT-CLK, and the codec takes the first positive sample of SYNC as defining the start of a new AC Link frame. If a subsequent SYNC pulse occurs within 255 AUD-BIT-CLK periods of the frame start it will be ignored. SYNC is also used as an active high input to perform an (asynchronous) Warm Reset. Warm Reset is used to clear a power down state on the codec AC Link interface Cold Reset. This active low signal causes a hardware reset which returns the control registers and all internal circuits to their default conditions. RESET must be used to initialize the LM4550 after Power On when the supplies have stabilized. RESET also clears the codec from both ATE and Vendor test modes. In addition, while active, it switches the PC_BEEP mono input directly to both channels of the LINE_OUT stereo output. The EDK reference design (available on the Digilent website) leverages our custom AC-97 pcore to accomplish several standard audio processing tasks such as recording and playing back audio data. 10 Serial Port The Genesys board hosts two 2-wire RS-232 serial ports, one with a DB9F connector (for a DTE connection), and one with a three-pin 100-mil header connector (including TX, RX, and GND). An ST3232 level-shifting buffer is used to provide RS-232 signal levels on both ports. The serial port, supported by standard EDK IP, is useful for user-data transfers as well as embedded processor debugging. J4 AG16 AF18 T2OUT T2IN R2OUT R2IN DB-9 100W Virtex 5 AF19 AG15 T1IN T1OUT R1OUT R1IN 100W RS232 voltage converter Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. 1 2 3 4 5 6 7 8 9 DCD RXD TXD DTR SG DSR RTS CTS RI Page 15 of 27 Genesys™ FPGA Board Reference Manual 11 Oscillators/Clocks The Genesys board has several clock sources available, including a 3.3V 100MHz crystal oscillator, a socket for a user-supplied half-size DIP oscillator, and two high-speed and highly stable differential clock sources produced by an IDT 5V9885 programmable clock generator. The IDT clock generator is programmed during manufacturing to produce several clocks required by the Genesys board, including a 25MHz clock for the Ethernet PHY, a 24.576MHz clock for the Audio codec, a 12MHz clock for the USB circuit, and two differential clocks (100MHz and 200MHz) for use by user circuits in the FPGA. Programming header (SPI) IDT5V9885 Clock Generator OUT1 25MHz Ethernet Clock OUT2 24.576MHz Audio Clock OUT3 12MHz USB Clock J12 OUT4P 200MHz J14 H13 Differential clock input 100MHz H19 H20 Differential clock input OUT4N 25MHz Crystal OUT5P OUT5N IC15 100MHz Oscillator IC13 Oscillator DIP socket AG18 Virtex 5 AH15 IC14 The IDT clock generator chip is JTAG programmable using iMPACT. If users change the factory default configuration of the clock generator, reference designs and automated tests might not work as designed. The same IDT5V9885 configuration file used during board manufacturing is available from the Digilent website and it can be used to restore the IDT default settings. 12 Basic I/O Genesys includes three pushbuttons, a navigation switch comprised of five pushbuttons packaged in a two-axis rocker switch, eight slide switches, and eight LEDs for basic digital input and output. The buttons, navigation switch, and slide switches are connected to the FPGA via series resistors to prevent damage from short circuits. The high efficiency LED anodes are connected to a 3.3V bank on the FPGA via 390-ohm resistors, so they are illuminated by about a 1mA current when a logic high is placed on the corresponding pin. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 16 of 27 Genesys™ FPGA Board Reference Manual Nav Switch 2.5V Buttons 2.5V J21 BTN0 G6 BTN1 G7 Bank 3: 2.5V E7 Bank 12: 2.5V RESET K19 H15 J17 E6 BTNL BTND BTNR BTNU Virtex 5 2.5V AG8 LD0 SW1 L18 AH8 LD1 SW2 K18 AH9 LD2 AG10 LD3 AH10 LD4 SW4 H18 H17 Bank 22: 3.3V J19 Bank 3: 2.5V SW0 SW3 SW5 K17 AG11 LD5 SW6 G16 AF11 LD6 SW7 G15 AE11 LD7 Slide Switches 13 BTNC LEDs Character LCD The Genesys board contains a standard 2x16 character LCD, typified by the Powertip 1602D (see www.powertip.com.tw). The display uses a Sitronix ST7066U or compatible controller. Pertinent parts of the controller data sheet are recreated below. Please refer to the vendor data sheet for more detailed information. The LCD controller contains a character-generator ROM (CGROM) with 208 preset 5x8 character patterns, a character-generator RAM (CGRAM) that can hold eight user-defined 5x8 characters, and a display data RAM (DDRAM) that can hold 80 character codes. Character codes written into the DDRAM serve as indexes into the CGROM (or CGRAM). Writing a character code into a particular DDRAM location will cause the associated character to appear at the corresponding display location. Display positions can be shifted left or right by setting a bit in the instruction register (IR). The write-only IR directs display operations (such as clear display, shift left or right, set DDRAM address, etc). Available instructions (and the associated IR codes) are shown in the right-most column of the "LCD Instructions and Codes" table below. A busy flag shows whether the display has competed the last requested operation; prior to initiating a new operation, the flag can be checked to see if the previous operation has been completed. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 17 of 27 Genesys™ FPGA Board Reference Manual AA5 W6 V7 Virtex 5 See table E R/W RS D[7:0] Data Signals 16x2 LCD Character Display D0: Y8 D1: AB7 D2: AB5 D3: AC4 D4: AB6 D5: AC5 D6: AC7 D7: AD7 The display has more DDRAM locations than can be displayed at any given time. DDRAM locations 00H to 27H map to the first display row, and locations 40H to 67H map to the second row. Normally, DDRAM location 00H maps to the upper left display corner, and 40H to the lower left. Shifting the display left or right can change this mapping. The display uses a temporary data register (DR) to hold data during DDRAM /CGRAM reads or writes, and an internal address register to select the RAM location. Address register contents, set via the IR, are automatically incremented after each read or write operation. RAM read/write requests will be directed to DDRAM or CGRAM, depending on which address register was most recently accessed. The LCD display uses ASCII character codes. Codes up through 7F are standard ASCII (which includes all "normal" alphanumeric characters). Codes above 7F produce various international characters – please see the Sitronix ST7066U data sheet for more information on international codes. The display is connected to the Vitex FPGA by a 16-pin connector (pins 15 and 16 are for an optional backlight, and they are not used). The 14-pin interface includes eight data signals, three control signals, and three voltage supply signals. The eight bidirectional data bus signals communicate data to the control registers or RAM locations. The RS (Register Strobe) signal clocks data into registers or into RAM, the R/W signal determines bus direction, and the E signal enables the bus for read or write operations. LCD bus signals and timings are illustrated below. LCD Signals Vss LCD Pin 1 Vdd 2 5V Power Supply Vo 3 Contrast Voltage (typically 100mV-200mV at 20C) Signal FPGA Pin Signal Description Ground RS 4 V7 Register select: high for data, low for instructions R/W 5 W6 Read/write signal: high for read, low for write E 6 AA5 Read/write: high for OE; falling edge writes data DB0 7 Y8 Bidirectional data bus 0 DB1 8 AB7 Bidirectional data bus 1 DB2 9 AB5 Bidirectional data bus 2 DB3 10 AC4 Bidirectional data bus 3 DB4 11 AB6 Bidirectional data bus 4 DB5 12 AC5 Bidirectional data bus 5 DB6 13 AC7 Bidirectional data bus 6 DB7 14 AD7 Bidirectional data bus 7 A startup sequence with specific timings ensures proper LCD operation. After power-on, at least 20ms must elapse before the function-set instruction code can be written to set the bus width, number of lines, and character patterns (8-bit interface, 2 lines, and 5x8 dots are appropriate). After the function-set instruction, at least 37us must elapse before the display-control instruction can be written (to turn the display on, turn the cursor on or off, and set the cursor to blink or no blink). After another 37us, the display-clear instruction can be issued. After another 1.52ms, the entry-mode instruction can set address increment (or address decrement) mode, and display Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 18 of 27 Genesys™ FPGA Board Reference Manual shift mode (on or off). After this sequence, data can be written into the DDRAM to cause information to appear on the display. LCD Instructions and Codes Instruction Instruction Bit Assignments DB DB DB DB DB 6 5 4 3 2 RS R/W DB 7 Clear Display 0 0 0 0 0 0 0 Return Home 0 0 0 0 0 0 Entry Mode Set 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Display ON/OFF Control Cursor or Display Shift Function Set Set CGRAM Address Set DDRAM Address Read Busy Flag/ Address DB 1 DB 0 0 0 1 0 0 1 X 0 0 1 I/D SH 0 0 1 D C B 0 0 1 S/C R/L X X 0 1 DL N F X X Description Clear display, set DDRAM address register to 00H, and return cursor to home. 1.52ms Return cursor to upper left, set DDRAM address to 0H. DDRAM contents not changed. 1.52ms I/D = '1' for right-moving cursor and address increment, SH = '1' for display shift (direction set by I/D bit). 37us Set display (D), cursor (C), and blinking cursor (B) on or off ('1' in all bits for "on"). 37us S/C = '0' to shift cursor right or left, '1' to shift entire display right or left. R/L = '1' for right. 37us Set interface data length (DL = '1' for 8 bit), number of display lines (N = '1' for 2 lines), display font (F = '0' for 5x 8 dots). 37us 0 0 0 1 AC5 AC4 AC3 AC2 AC1 AC0 Set CGRAM address counter. 37us 0 0 1 AC6 AC5 AC4 AC3 AC2 AC1 AC0 Set DDRAM address counter. 37us 0 1 BF AC6 AC5 AC4 AC3 AC2 AC1 AC0 Read busy flag and address counter. 0us Write Data to RAM 1 0 D7 D6 D5 D4 D3 D2 D1 D0 Read Data from RAM 1 1 D7 D6 D5 D4 D3 D2 D1 D0 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Write data into DDRAM or CGRAM, depending on which address was last set. 37us Read data from DDRAM or CGRAM, depending on which address was last set. 37us Page 19 of 27 Genesys™ FPGA Board Reference Manual 13.1 Reading Data from LCD RS tsu th RW tpw tr th tf E trdsu tdh DB7-DB0 Valid Data tc 13.2 Writing Data to LCD RS th tsu RW tpw tr th tf E twdsu DB7-DB0 tdh Valid Data tc LCD Bus Timings Parameter Enable cycle time Enable High pulse width Enable rise/fall time RS, R/W setup time RS, R/W hold time Read data setup Data hold time Write data setup time Symbol tc tw tr, tf tsu th trdsu tdh twdsu Min Max 1200 480 25 0 10 60 300 80 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. 320 Unit ns ns ns ns ns ns ns ns Pin E E E RS, R/W RS, R/W DB0-DB7 DB0-DB7 DB0-DB7 Page 20 of 27 Genesys™ FPGA Board Reference Manual Power On WAIT 40ms Function Set RS R/W DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 0 0 0 0 0 1 1 0 DB4: 8-bit interface DB3: Two lines DB2: 5x8 dot font WAIT 37us “Function Set” may need to be repeated Display ON/OFF Control RS R/W DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 0 0 0 0 0 0 1 1 1 0 DB2: Display On DB1: Cursor On DB0: No blink WAIT 37us Display Clear RS R/W DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 0 0 0 0 0 0 0 0 0 1 DB0: Clear WAIT 1.52ms Entry Mode Set RS R/W DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 0 0 0 0 0 0 0 1 1 0 DB1: Right-moving DB0: Move cursor Init Complete LCD Start-Up Sequence 14 PS/2 Port The 6-pin mini-DIN connector can accommodate a PS/2 mouse or keyboard. Most PS/2 devices can operate from a 3.3V supply, but older devices may require a 5VDC supply. A 3-pin jumper on the immediately adjacent to the PS/2 connector selects whether regulated 3.3V or the main input power bus voltage (VU) is supplied to the PS/2 connector. To send 5V to the PS/2 connector, set the PS2 power jumper to VU (the main input power bus), and ensure the board is powered from USB or a 5VDC wall-plug supply. To send 3.3V to the connector, set the jumper to 3.3V. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 21 of 27 Genesys™ FPGA Board Reference Manual 8 6 5 3 2 5 1 2 8 1 3 6 Pin1: Data Pin2: Data Pin3: GND Pin5: Vdd Pin6: Clock Pin8: Clock VU Virtex 5 H9 H10 200 W 200 W CLK 3.3V DATA 6-pin mini-DIN (bottom up) Both the mouse and keyboard use a two-wire serial bus (clock and data) to communicate with a host device. Both use 11-bit words that include a start, stop, and odd parity bit, but the data packets are organized differently, and the keyboard interface allows bi-directional data transfers (so the host device can illuminate state LEDs on the keyboard). Bus timings are shown in the figure. The clock and data signals are only driven when data transfers occur, and otherwise they are held in the "idle" state at logic '1'. The timings define signal requirements for mouseto-host communications and bi-directional keyboard communications. A PS/2 interface circuit can be implemented in the FPGA to create a keyboard or mouse interface. Tck Tck Edge 0 ‘0’ start bit Thld Edge 10 ‘1’ stop bit Tsu Symbol Parameter Min Clock time 30us TCK Data-to-clock setup time 5us TSU THLD Clock-to-data hold time 5us Max 50us 25us 25us 14.1 Keyboard The keyboard uses open-collector drivers so the keyboard or an attached host device can drive the two-wire bus (if the host device will not send data to the keyboard, then the host can use input-only ports). PS/2-style keyboards use scan codes to communicate key press data. Each key is assigned a code that is sent whenever the key is pressed; if the key is held down, the scan code will be sent repeatedly about once every 100ms. When a key is released, an "F0" key-up code is sent, followed by the scan code of the released key. If a key can be "shifted" to produce a new character (like a capital letter), then a shift character is sent in addition to the scan code, and the host must determine which ASCII character to use. Some keys, called extended keys, send an "E0" ahead of the scan code (and they may send more than one scan code). When an extended key is released, an "E0 F0" key-up code is sent, followed by the scan code. Scan codes for most keys are shown in the figure. A host device can also send data to the keyboard. Below is a short list of some common commands a host might send. ED Set Num Lock, Caps Lock, and Scroll Lock LEDs. Keyboard returns "FA" after receiving "ED", then host sends a byte to set LED status: bit 0 sets Scroll Lock; bit 1 sets Num Lock; and bit 2 sets Caps lock. Bits 3 to 7 are ignored. EE Echo (test). Keyboard returns "EE" after receiving "EE". F3 Set scan code repeat rate. Keyboard returns "F3" on receiving "FA", then host sends second byte to set the repeat rate. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 22 of 27 Genesys™ FPGA Board Reference Manual FE Resend. "FE" directs keyboard to re-send most recent scan code. FF Reset. Resets the keyboard. The keyboard can send data to the host only when both the data and clock lines are high (or idle). Since the host is the "bus master", the keyboard must check to see whether the host is sending data before driving the bus. To facilitate this, the clock line is used as a "clear to send" signal. If the host pulls the clock line low, the keyboard must not send any data until the clock is released. The keyboard sends data to the host in 11-bit words that contain a '0' start bit, followed by 8-bits of scan code (LSB first), followed by an odd parity bit and terminated with a '1' stop bit. The keyboard generates 11 clock transitions (at around 20 - 30KHz) when the data is sent, and data is valid on the falling edge of the clock. Scan codes for most PS/2 keys are shown in the figure below. ESC 76 `~ 0E 1! 16 TAB 0D Caps Lock 58 Shift 12 F1 05 F2 06 F3 04 F4 0C 2@ 1E 3# 26 4$ 25 5% 2E Q 15 W 1D A 1C S 1B Z 1Z Ctrl 14 E 24 D 23 X 22 Alt 11 R 2D F5 03 6^ 36 T 2C F 2B C 21 V 2A F6 0B F7 83 7& 3D Y 35 G 34 8* 3E U 3C H 33 B 32 9( 46 I 43 J 3B N 31 F8 0A F9 01 0) 45 O 44 K 42 M 3A -_ 4E P 4D L 4B ,< 41 Space 29 F10 09 =+ 55 [{ 54 ;: 4C >. 49 /? 4A Alt E0 11 F11 78 F12 07 E0 75 BackSpace 66 E0 74 ]} 5B '" 52 \| 5D E0 6B Enter 5A E0 72 Shift 59 Ctrl E0 14 PS/2 Keyboard Scan Codes. 14.2 Mouse The mouse outputs a clock and data signal when it is moved; otherwise, these signals remain at logic '1'. Each time the mouse is moved, three 11-bit words are sent from the mouse to the host device. Each of the 11-bit words contains a '0' start bit, followed by 8 bits of data (LSB first), followed by an odd parity bit, and terminated with a '1' stop bit. Thus, each data transmission contains 33 bits, where bits 0, 11, and 22 are '0' start bits, and bits 11, 21, and 33 are '1' stop bits. The three 8-bit data fields contain movement data as shown in the figure above. Data is valid at the falling edge of the clock, and the clock period is 20 to 30KHz. The mouse assumes a relative coordinate system wherein moving the mouse to the right generates a positive number in the X field, and moving to the left generates a negative number. Likewise, moving the mouse up generates a positive number in the Y field, and moving down represents a negative number (the XS and YS bits in the status byte are the sign bits – a '1' indicates a negative number). The magnitude of the X and Y numbers represent the rate of mouse movement – the larger the number, the faster the mouse is moving (the XV and YV bits in the status byte are movement overflow indicators – a '1' means overflow has occurred). If the mouse moves continuously, the 33-bit transmissions are repeated every 50ms or so. The L and R fields in the status byte indicate Left and Right button presses (a '1' indicates the button is being pressed). Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 23 of 27 Genesys™ FPGA Board Reference Manual Mouse status byte 1 0 L R 0 Start bit 1 XS YS XY YY P Stop bit X direction byte 1 0 Y direction byte X0 X1 X2 X3 X4 X5 X6 X7 P 1 0 Stop bit Start bit Y0 Y1 Y2 Y3 Y4 Y5 Y6 Y7 P Start bit Idle state 1 Stop bit Idle state Mouse data format. 15 Expansion Connectors The Genesys board offers two 68-pin VHDC connectors for high-speed parallel I/O, and four 8-pin Pmod ports for lower speed and lower pin-count I/O. Data sheets for VHDC connectors can be found on the Digilent website and on many vendor and distributor websites as well. The VHDC connectors include 40 data signals (routed as 20 impedance-controlled matched pairs), 20 grounds (one per pair), and eight power signals. These connectors, commonly used for SCSI-3 applications, can accommodate data rates of several hundred megahertz on every pin. Both board-to-board and board-to-cable mating connectors are available. Digilent and several distributors carry mating connectors and cables of various lengths. External circuits connected the VHDC expansion connectors can receive 2.5V or 3.3V supplies from Genesys, depending on the position of power supply selection jumpers. Jumper JP11 selects the voltage provided to VHDC connector J1 and the associated FPGA I/O bank 11, and jumper JP12 selects the supply for VHDC connector J2 and FPGA I/O bank 12 (all I/O's to the connectors are routed as matched pairs to support LVDS signaling). The VHDC connectors also include two pins connected directly to in the input voltage VSWT; jumper JP1 can break that connection if required. The VHDC connectors, labeled J1 and J2 on the first page of the schematic, use symmetrical pinouts (as reflected around the vertical axis of the physical connector) so that peripheral boards as well as other system boards can be connected. Connector pins 15 and 49 are routed to FPGA clock input pins. Pin 34 Pin 68 10 Matched Pairs VU VCC 10 Matched Pairs Clock Inputs Pin 1 Pin 35 The Genesys board's unregulated input voltage (VU) is routed to the four center pins of the connector, providing up to 1A of current (250mA per pin) to connected boards. VU is routed to the connectors through the main power switch, and through jumper JP1 (so that VU can be removed from peripheral boards if desired). All I/O pins on connector J1 are routed to FPGA I/O bank 11, and all I/O pins on connector J2 are routed to FPGA I/O bank 13. The VCC voltage driving these I/O banks is also routed to four VCC pins on each connector, using pins immediately distal to the four VU pins. The shared I/O bank and connector VCC may be set to 3.3V, 2.5V, left unconnected or driven from an external source using jumpers JP11 (J1) and JP12 (J2). Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 24 of 27 Genesys™ FPGA Board Reference Manual Switched VU JP1 3.3V 2.5V Bank 11 VCCO Pins (x3) JP11 20 Matched Pairs J1 Virtex 5 Bank 13 VCCO Pins (x3) 3.3V 2.5V JP12 20 Matched Pairs J2 Name IO1-P IO2-P IO3-P IO4-P IO5-P IO6-P IO7-P IO8-P IO9-P IO10-P IO11-P IO12-P IO13-P IO14-P IO15-P IO16-P IO17-P IO18-P IO19-P IO20-P VHDC Connector J1 Pin Name B32 IO1-N C32 IO2-N B33 IO3-N E32 IO4-N C34 IO5-N G32 IO6-N F33 IO7-N J32 IO8-N G33 IO9-N K33 IO10-N H34 IO11-N L34 IO12-N L33 IO13-N N33 IO14-N P32 IO15-N P34 IO16-N R33 IO17-N T33 IO18-N U32 IO19-N U33 IO20-N Pin A33 D32 C33 E33 D34 H32 E34 H33 F34 K32 J34 K34 M32 M33 N32 N34 R32 R34 U31 T34 Name IO21-P IO22-P IO23-P IO24-P IO25-P IO26-P IO27-P IO28-P IO29-P IO30-P IO31-P IO32-P IO33-P IO34-P IO35-P IO36-P IO37-P IO38-P IO39-P IO40-P VHDC Connector J2 Pin Name W34 IO21-N V32 IO22-N AA34 IO23-N Y33 IO24-N AC33 IO25-N Y32 IO26-N AC34 IO27-N AC32 IO28-N AF34 IO29-N AF33 IO30-N AG33 IO31-N AH34 IO32-N AD32 IO33-N AK34 IO34-N AG32 IO35-N AM33 IO36-N AJ32 IO37-N AN34 IO38-N AL34 IO39-N AN32 IO40-N Pin V34 V33 Y34 AA33 AB33 W32 AD34 AB32 AE34 AE33 AH33 AJ34 AE32 AK33 AH32 AM32 AK32 AN33 AL33 AP32 Pmods use 2x6 right-angle, 100-mil connectors that mate with standard 2x6 pin headers available from a variety of catalog distributors. Each 12-pin Pmod port provides two VCC signals (pins 6 and 12), two Ground signals (pins 5 and 11), and eight logic signals. VCC and Ground pins can deliver up to 1A of current, and a jumper block is Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 25 of 27 Genesys™ FPGA Board Reference Manual available for each connector to choose the VCC voltage: regulated 3.3V or the unregulated board input voltage (VU). Pmod data signals are not matched pairs, and they are routed using best-available tracks without impedance control or delay matching. ESD/protection circuit on each Pmod signal (x8) 3.3V VCC GND VU 8 signals Pin 1 Pin 6 Bank 22 3.3V Pin 12 VCC Pmod Signals (x8) Pmod Connector – front view as loaded on PCB Pmod Connector Digilent produces a large collection of accessory boards that can attach to the Pmod and VHDC expansion connectors to add ready-made functions like A/D's, D/A's, motor drivers, sensors, cameras and other functions. See www.digilentinc.com for more information. Pmod A Pmod B Pmod C Pmod D Signal Pin Signal Pin Signal Pin Signal Pin JA1 AD11 JB1 AE9 JC1 AL11 JD1 AN14 JA2 AD9 JB2 AC8 JC2 AJ10 JD2 AN13 JA3 AM13 JB3 AB10 JC3 AK9 JD3 AP12 JA4 AM12 JB4 AC9 JC4 AF9 JD4 AL10 JA7 AD10 JB7 AF8 JC7 AK11 JD7 AP14 JA8 AE8 JB8 AB8 JC8 AC10 JD8 AN12 JA9 AF10 JB9 AA10 JC9 AJ9 JD9 AM11 JA10 AJ11 JB10 AA9 JC10 AA8 JD10 AK8 Pmod port pinouts. 16 System Monitor The Genesys board supports the dedicated analog inputs (VP and VN pins on J13) to the Virtex 5 FPGA System Monitor block. The PCB layout for the VP and VN pins is designed using differential pairs and anti-alias filtering in close proximity to the FPGA as recommended in the Virtex 5 FPGA System Monitor User Guide. The Virtex 5 FPGA System Monitor function is built around a 10-bit, 200-kSPS Analog-to-Digital Converter (ADC). The System Monitor is fully functional on power up, and measurement data can be accessed via the JTAG port pre-configuration. The Xilinx ChipScope™ Pro tool provides access to the System Monitor over the JTAG port. The System Monitor control logic implements some common monitoring features. For example, an automatic channel sequencer allows a userdefined selection of parameters to be automatically monitored, and user-programmable averaging is enabled to ensure robust noise-free measurements. The System Monitor also provides user-programmable alarm thresholds for the on-chip sensors. Thus, if an on-chip monitored parameter moves outside the user-specified operating range, an alarm logic output becomes active. In addition to monitoring the on-chip temperature for user-defined applications, the System Monitor issues a special alarm called Over-Temperature (OT) if the FPGA temperature becomes critical (> 125°C). The OT signal is Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 26 of 27 Genesys™ FPGA Board Reference Manual deactivated when the device temperature falls below a user specified lower limit. If the FPGA power-down feature is enabled, the FPGA enters power down when the OT signal becomes active. The FPGA powers up again when the alarm is deactivated. For additional information about the System Monitor, see http://www.xilinx.com/systemmonitor and consult the Virtex 5 FPGA System Monitor User Guide. The table below shows the System Monitor connections. 17 J13 Pin Signal Function 1 DXP Anode of the FPGA temperature-sensing diode 2 VP System Monitor dedicated differential analog input (positive side) 3 DXN Cathode of the FPGA temperature-sensing diode 4 VN System Monitor dedicated differential analog input (negative side) 5 GND 6 GND Built-In Self Test A demonstration configuration is loaded into the StataFlash ROM on the Genesys board during manufacturing. This demo, also available on the Digilent website, can serve as a board verification test since it interacts with all devices and ports on the board. To configure the FPGA from the demo file stored in StrataFlash, set the mode jumper to BPI UP and cycle power. When Genesys powers up, the DDR is tested, and then an image file will be transferred from the StrataFlash into DDR2. This image will be driven out the HDMI port for display on a DVI/HDMI compatible monitor. The slide switches are connected to the user LEDs, and user buttons BTN0, BTN1, and BTN3 cause varying sine-wave frequencies to be driven on the LINE IN and LINE OUT audio ports. The LCD screen (DISP1) will initially display "Genesys User Demo / BIST" on startup, and then display text whenever the state of a user button or switch is changed. If the self test is not resident in the StrataFlash ROM, it can be programmed into the FPGA or reloaded into the ROM using the Adept programming software. All Genesys boards are 100% tested during the manufacturing process. If any device on the Genesys board fails test or is not responding properly, it is likely that damage occurred during transport or during use. Typical damage includes stressed solder joints and contaminants in switches and buttons resulting in intermittent failures. Stressed solder joints can be repaired by reheating and reflowing solder, and contaminants can be cleaned with off-theshelf electronics cleaning products. If a board fails test within the warranty period, it will be replaced at no cost. If a board fails test outside of the warranty period and cannot be easily repaired, Digilent can repair the board or offer a discounted replacement. Contact Digilent for more details. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 27 of 27
410-138P-KIT 价格&库存
很抱歉,暂时无法提供与“410-138P-KIT”相匹配的价格&库存,您可以联系我们找货
