A000080
A000080
    ARDUINO
    SHIELD - MEGA PROTO PCB REV3
A000080 数据手册
          A R D U I N O   M E G A   P R OTO   S H I E L D   REV3 (PCB)  Code: A000080  The Arduino Prototyping Shield makes it easy for you to design  custom circuits for the MEGA standard Arduino pinout.  The Arduino Prototyping Shield makes it easy for you to design custom circuits.  You can solder parts to the prototyping area to create your project,or use it with a  small solderless breadboard (not included) to quickly test circuit ideas without  having to solder. It's got extra connections for all of the Arduino MEGA I/O pins,  and it's got space to mount through‐hole and surface mount integrated circuits.  It's a convenient way to make your custom Arduino circuit into a single module.  General  PCB Size  Weight  101.5 x 53.3 mm  0.013 Kg  OSH: Schematics  The Arduino Mega Proto Shield is open‐source hardware! You can build your own  board using the following files:  EAGLE FILES IN .ZIP   https://www.arduino.cc/en/uploads/Main/arduino‐mega‐proto‐Shield‐reference‐design.zip  SCHEMATICS IN .PDF  https://www.arduino.cc/en/uploads/Main/arduino‐mega‐proto‐Shield‐reference‐design.pdf  Description  Board features as follows:        1.0 Arduino pinout  1 Reset button  1 ICSP connector  14 pins SMD footprint (50 mils pitch)  32 double row through Hole pads, standard Arduino breakout layout  Proto aerea with multiple THT pads, 100 mils pitch  Power  The Proto Shield bring the power from the Arduino standard 5V and GND pins to  the two power bus rows placed between the Through Hole package footprint,  which can be used for powering the DIP sockets, or for power and ground rows.  Physical Characteristics  The maximum length and width of the Proto Shield PCB are 2.7 and 2.1 inches  respectively. Three screw holes allow the shield to be attached to a surface or  case. Note that the distance between digital pins 7 and 8 is 160 mil (0.16"), not an  even multiple of the 100 mil spacing of the other pins.  SPI Connection  On the ICSP connector only 5V, GND and RST are wired to the respective pins on  the header. MOSI and MISO are present only on the connector pads. For more  information about the SPI communication see the SPI library.  http://www.arduino.org/learning/reference/SPI                                 https://store.arduino.cc/usa/arduino‐mega‐proto‐shield‐rev3‐pcb 12‐7‐17
A000080 价格&库存
很抱歉,暂时无法提供与“A000080”相匹配的价格&库存,您可以联系我们找货
A000080
  • 1+54.470021+6.81295
  • 10+53.4161010+6.68113
  • 25+52.4501625+6.56032
  • 50+51.2411350+6.40909
库存:97
A000080
  • 1+49.80939
  • 10+49.08042
  • 25+48.45559
库存:222
