A000105
A000105
    ARDUINO
    M10 GSM/GPRS RF Arduino Platform Evaluation Expansion Board
A000105 数据手册
          ARDUINO GSM SHIELD 2  ( I N T E G R AT E D   A N T E N N A )   Code: A000105    The Arduino GSM Shield V2 allows your Arduino board to make  phone calls, send SMS and connect to the Internet.      The Arduino GSM Shield 2 allows an Arduino board to connect to the internet,  make/receive voice calls and send/receive SMS messages. The shield uses a radio  modem M10 by Quectel. It is possible to communicate with the board using AT  commands. The GSM library has a large number of methods for communication  with the shield.  https://www.arduino.cc/en/Reference/GSM  The shield uses digital pins 2 and 3 for software serial communication with the  M10. Pin 2 is connected to the M10’s TX pin and pin 3 to its RX pin. See these  notes for working with an Arduino Mega, Mega ADK, or Leonardo. The modem's  PWRKEY pin is connected to Arduino pin 7.  https://www.arduino.cc/en/Guide/GSMShieldLeonardoMega    The M10 is a Quad‐band GSM/GPRS modem that works at frequencies  GSM850MHz, GSM900MHz, DCS1800MHz and PCS1900MHz. It supports TCP/UDP  and HTTP protocols through a GPRS connection. GPRS data downlink and uplink  transfer speed maximum is 85.6 kbps.    To interface with the cellular network, the board requires a SIM card provided by a  network operator. See the getting started page for additional information on SIM  usage.  https://www.arduino.cc/en/Guide/ArduinoGSMShieldV2#toc4    The most recent revision of the board uses the 1.0 pinout on rev 3 of the Arduino  Uno board.        Requires an Arduino board (not included)  Operating voltage 5V (supplied from the Arduino Board)  Connection with Arduino Uno on pins 2, 3 (Software Serial) and 7 (reset). See these  notes for working with a Mega, Mega ADK, or Leonardo.  https://www.arduino.cc/en/Guide/GSMShieldLeonardoMega  This version includes an integrated antenna  OSH: Schematics  Arduino GSM Shield 2 is open‐source hardware! You can build your own board  using the following files:    EAGLE FILES IN .ZIP   https://www.arduino.cc/en/uploads/Main/arduino‐gsm‐shield‐06‐reference‐ design.zip  SCHEMATICS IN .PDF   https://www.arduino.cc/en/uploads/Main/Arduino‐GSM‐Shield2‐Rev3.2‐SCH.pdf  SIM to use with this shield  The GSM shield 2 is compatible with Data only and Voice and Data SIM. GPRS and  SMS are supported by 2G Data only SIM, while voice calls, supported by the  hardware, require a Voice and Data SIM, the same you may use in a GSM mobile  phone. The Data transfer is based on GPRS technology and therefore it is not  compatible with 3G or UMTS only network providers. GPRS is a 2G technology.  Power  It is recommended that the board be powered with an external power supply that  can provide between 700mA and 1000mA. Powering an Arduino and the GSM  shield 2 from a USB connection is not recommended, as USB cannot provide the  required current for when the modem is in heavy use.  On board indicators  The shield contains a number of status LEDs:     On: shows the Shield gets power.  Status: turns on to when the modem is powered and data is being transferred to/from  the GSM/GPRS network.  Net: blinks when the modem is communicating with the radio network.  On board interfaces  The shield comes with a on‐board audio jack as well, and it can be used for both  microphone and line inputs. It is also possible to make voice calls. You don’t need  to add a speaker and microphone.  There are two small buttons on the shield. The button labeled "Reset" is tied to  the Arduino reset pin. When pressed, it will restart the sketch. The button labeled  "Power" is connected to the modem and will power the modem on and off. For  early versions of the shield, it was necessary to press the power button to turn on  the modem. Newer versions of the board will turn the modem on automatically.  If you have an early version of the shield, and it does not turn on automatically,  you can solder a jumper to the CTRL/D7 pad on the reverse side of the board, and  it will turn on when an attached Arduino receives power.      Several of the modem pins are exposed on the underside of the board. These  provide access to the modem for features like speaker output and microphone  input. See the datasheet for complete information.      Previous Versions Do you own a past an old version of this product? Check Arduino GSM Shield  V1 product page.  https://www.arduino.cc/en/Main.ArduinoGSMShieldV1                                                            https://store.arduino.cc/usa/arduino‐wireless‐proto‐shield 12‐7‐17
A000105
PDF文档中包含以下信息: 1. 物料型号:型号为“LMR33630”。
2. 器件简介:LMR33630是一款同步整流降压型开关稳压器。
3. 引脚分配:包括1脚为开关节点,2脚为地,3脚为输出电压,4脚为使能,5脚为输入电压,6脚为接地,7脚为反馈,8脚为输出电压,9脚为接地。
4. 参数特性:包括输入电压范围、输出电压范围、静态电流、工作频率等。
5. 功能详解:介绍了器件的功能特点,如高效率、低噪声等。
6. 应用信息:适用于便携式设备、手机、平板电脑等。
7. 封装信息:器件采用QFN封装。
A000105 价格&库存
很抱歉,暂时无法提供与“A000105”相匹配的价格&库存,您可以联系我们找货
