Teensy Audio Board
DEV‐12767 RoHS
Description: This is the Teensy Audio board add-on for the Teensy 3.0 and 3.1 development
boards. This audio board provides you with an easy-to-use tool to add high quality 16 bit, 44.1 kHz
sample rate audio to your Teensy project. With the audio library provided in the Documents section
below you will be able to use both the input and output simultaneously in order to make a variety of
great audio projects, incorporate synth waveforms, effects, and mix multiple sound streams and cd
quality audio to your headphones or different line outs!
The Teensy Audio board utilizes the SGTL5000 stereo codec with headphone amp IC to decode
and drive audio files and the Cortex-M4 DSP instructions from the Teensy dev board to provide
power to a real-time FFT. Each board is also equipped with 3.5mm audio jack for headphones, a
micro-SD card slot for storing audio files, and optional spaces for a 25k potentiometer (volume
control) and flash memory chip. The two rows of 14x1 headers are not included to give you the
freedom to choose how to connect your audio board with your Teensy
Features:
16 bit, 441 kHz Sample Rate Audio
Plays Uncompressed WAV and Raw Audio Files
4 Channel Software Mixer
3.5mm Audio Jack
micro-SD Card Slot
SparkFun Electronics ®
很抱歉,暂时无法提供与“DEV-12767”相匹配的价格&库存,您可以联系我们找货
