714
714
    ADAFRUIT
    COMBUSTION ANALYZER W/PUMP
714 数据手册
RGB LCD Shield Created by lady ada https://learn.adafruit.com/rgb-lcd-shield Last updated on 2021-11-15 05:50:10 PM EST ©Adafruit Industries Page 1 of 30 Table of Contents Overview 3 Parts List 4 • • • • • • • 5 5 5 5 6 6 6 1) Resistors 2) Potentiometer 3) Pushbuttons 4) i2c Port Expander Chip 5) Male Header Pins 6) Printed Circuit Board Additional Assembly 7 Arduino Usage 19 • • • • • • 19 19 20 20 21 21 Download the Library Adjusting Contrast Shared Pins Writing Your Own Sketches Using with Monochrome Displays Detached Usage CircuitPython Usage • • • • CircuitPython Microcontroller Wiring CircuitPython Installation of CharLCD Library CircuitPython Code Full Code Example 22 23 23 23 24 Python Docs 26 F.A.Q. 26 Downloads 29 • Software • Files • Schematic & Fabrication Print Forums ©Adafruit Industries 29 29 29 30 Page 2 of 30 Overview This new Adafruit shield makes it easy to use a 16x2 Character LCD. We really like the range of LCDs we stock in the shop, such as our classic blue & white (http://adafru.it/ 181) as well as the fancy RGB negative (http://adafru.it/399) and RGB positive (http:// adafru.it/398). Unfortunately, these LCDs do require quite a few digital pins, 6 to control the LCD and then perhaps another 3 to control the RGB backlight for a total of 9 pins. That's half of the pins available on a classic Arduino! With this in mind, we wanted to make it easier for people to get these LCD into their projects so we devised a shield that lets you control a 16x2 Character LCD, up to 3 backlight pins AND 5 keypad pins using only the two I2C pins on the Arduino! The best part is you don't really lose those two pins either, since you can stick i2c-based sensors, RTCs, etc and have them share the I2C bus. This is a super slick way to add a display without all the wiring hassle. ©Adafruit Industries Page 3 of 30 This shield is perfect for when you want to build a stand-alone project with its own user interface. The 4 directional buttons plus select button allows basic control without having to attach a bulky computer.  The shield is designed for 'classic' Arduinos such as the Uno, Duemilanove, Diecimilla, etc. and uses the I2C pins on Analog 4 and Analog 5. It will also work perfectly with Arduino Mega R3's. Earlier Mega's have the I2C pins in a different location and will require you to solder two wires from the I2C pins on the shield and plug them into the different I2C locations. This shield will not fit easily on top of an Arduino Ethernet because of the Ethernet jack height.  You can use a set of stacking headers to give the shield more 'lift' above the jack. (http://adafru.it/85) Parts List Check to make sure your kit comes with the following parts.Sometimes we make mistakes so double check everything and email support@adafruit.com if you need replacements! ©Adafruit Industries Page 4 of 30 1) Resistors There is a total of 5 resistors in this kit.  For resistors labeled R1 and R2 on the PCB, they are 1/4W 5% 4.7K resistors (Yellow, Violet Red, Gold).  For resistors labeled RED and BLUE on the PCB, they are 1/4W 5% 220 ohm resistors (Red, Red, Brown, Gold).  For the resistor labeled GREEN on the PCB, it is a 1/4W 5% 330 ohm resistor (O range Orange Brown Gold). 2) Potentiometer There is one 10k trim potentiometer.  This part will go in the spot labeled Contrast, near the RESET button. Note: The pot may be blue instead of orange. 3) Pushbuttons There are a total of 6, 6mm tactile switch pushbuttons.  These will be used in the UP, DOWN, LEFT, RIGHT, SELECT, and RESET locations on the PCB. 4) i2c Port Expander Chip There is one of these MCP23017 i2c (16 input/output) port expander chips in the kit.  This is how we are able to only use 2 Arduino pins to run the entire LCD and buttons.  Click here for more info on this chip. (http://adafru.it/732) ©Adafruit Industries Page 5 of 30 5) Male Header Pins There are two strips of 36 male header pins in the kit.  These will be used to attach the shield to the Arduino, as well as attach the LCD to the PCB. 6) Printed Circuit Board There will be one PCB in the kit as shown above. Additional You'll want an LCD to place into the shield. This isn't included by default since a lot of people already have LCDs they may want to use. (We do sell these in packs however so chances are you did get an LCD with your order). You can also use 16x2 LCDs or even OLEDs that are the same size that do not have an RGB backlight, or have no backlight at all. We carry Negative type (http://adafru.it/399) or Positive type (http://adafru.it/398) LCD s. ©Adafruit Industries Page 6 of 30 Assembly Check the kit against the parts list (https://adafru.it/cl9) to verify you have all the parts necessary Put the printed circuit board into a vise or board holder, heat up your soldering iron and make sure you're ready to go! We'll start with the first resistor R1 - which has yellow, violet, red, gold bands on it. This resistor is part of the interface between the Arduino and the 'port expander' that controls the LCD. Bend the resistor into a 'staple' and slide it into the slot marked R1 on the PCB. Resistors do not have a direction so you can put it in 'either way' and it'll work find. ©Adafruit Industries Page 7 of 30 Bend the 'legs' of the resistor out so it sits flat against the PCB and flip it over. This way the resistor won't fall out while soldering. With your soldering iron heated up and ready, solder in both leads of the resistor. To do this, heat up the round ring pad and the wire lead at the same time for 2 or 3 seconds, then dip the end of the solder into the heated joint to melt it in. Then remove the solder and the soldering iron. Once the soldering is complete, we can clean up by clipping the leads of the resistor. This keeps them from shorting to something else. Use diagonal or flush cutters to clip the wires right above where the solder joint ends. ©Adafruit Industries Page 8 of 30 Since you did so great with the first resistor, we'll place all of the rest now at the same time. R2 is a 4.7K resistor just like R1 (Yellow, Violet, Red Gold) so place that one first Next you can do the two 220 ohm resistors RED and BLUE - named because they are the backlight series resistors for the RGB backlights on the LCDs. These resistors are colored Red Red Brown Gold. They look very similar to the 330 ohm resistor so check carefully that you have the red-band ones. Use a multimeter if you can to verify the resistance! Finally, place the remaing 330 ohm resistor (Orange, Orange, Brown, Gold) into the GREEN spot. The green LED is might brighter than the red or blue in the RGB backlight so a larger resistor is required to balance it out. Make sure the resistors all sit nice and flat against the PCB. Solder the resistors just like you did with the first one. ©Adafruit Industries Page 9 of 30 Clip all the leads. Next up we will place the buttons. These buttons are useful to send a signal to the Arduino (say if you have a basic menu system). We have a 4-way 'direction pad' for up/down/left/right input and a button to the right called SELECT. These 5 buttons should be able to make 'talking' back to your project easy. These are connected to the I2C port expander chip so they require no extra pins on the Arduino, our library does the work of reading whether they are pressed. The button all the way to the right is the RESET button, for when you want to reset the entire system. All the buttons are the same, and they should snap nicely into place. Press down onto each button until it snaps in and sits flat against the PCB. ©Adafruit Industries Page 10 of 30 Flip over the PCB and check that all the legs for the buttons are sticking out. Solder each leg, taking care not to accidentally 'short' two button legs together. The ones for the directional pads are very close! ©Adafruit Industries Page 11 of 30 We're nearly done! Now we will place the I2C port expander chip. Double check that it has the MCP23017-E/SP marking on it. This is a 16-pin expander chip, that uses the i2c bus. That means you can send it commands using the i2c pins on an Arduino and control 16 more digital pins! 5 of those pins go to the buttons, 6 go to the LCD control and 3 are used for the backlight (the remaining 2 are unused). Unlike buttons or resistors, chips do have a direction and the must be put in the right way! First, use a flat table to carefully bend the legs of the chip so they are parallel. Then slip it into the silkscreened outline so that the notch at the end of the chip is on the right. Click the image to the left to make absolutely sure you've got it in the right way. Once you are sure, press the chip into place. Next, place the 10K potentiometer (the orange-faced thing with three legs) into the spot above the RESET button. It will only fit one way. This is the contrast potentiometer which will adjust how dark the characters appear. All displays are slightly different so you'll adjust this once the display is soldered in. The kit may come with two potentiometers - a big blue one for breadboarding the LCD and a smaller orange one for the shield kit. You can throw away or recycle the blue one, use only the orange one here! ©Adafruit Industries Page 12 of 30 Flip over the PCB and solder in the three legs of the potentiometer and then all 28 pins of the port expander. ©Adafruit Industries Page 13 of 30 Take a stick of 36 pin header and break off a 10 pin piece, an 8 pin piece and two 6 pin pieces. Place the header onto your Arduino, if you have an R2 or earlier arduino, there will be two pins that 'hang over' past the AREF breakout. These two extra pins are used for R3 and later Arduino classics and Mega's to make connecting to the I2C pins easier. We suggest keeping those two pins in case you ever upgrade your 'duino. Place the shield right on top. It should fit perfectly where all the short ends of the header fit into the holes of the shield. To make it sit flat, you may need to clip the legs of the buttons down - they will interfere with the DC jack, lifting the shield a bit. ©Adafruit Industries Page 14 of 30 Solder all of the header pins. Even though they aren't used for passing signals, they will make the mechanical connection to the Arduino strong. ©Adafruit Industries Page 15 of 30 Next, check if you have an RGB LCD (with 18 pins) or a Monochrome display (not RGB, with 16 pins). If you have an RGB 18 pin display break off a 18-pin strip of header and place it with the long ends down into the LCD placement slot. If you have an Monochrome 16 pin display break off a 16-pin strip of header and place it with the long ends down into the LCD placement slot so that the two right-most pins are empty. Now you can take the 16x2 LCD of your choosing and place it on top. For the RGB LCDs we stock, there are two connection rows, just make sure it matches the outline silkscreen on the shield and you should be good to go. If your LCD does not have an RGB backlight or it has no backlight, you may have to shorten the length of header (see the previous step) until it matches and make sure the LCD fits over the silkscreen outline. If you already soldered all 18 pins but you have a 16 or 14 pin LCD, simply cut off the right-most pin tops until it fits. Solder all the pins to the LCD display. ©Adafruit Industries Page 16 of 30 Flip over the shield and place it flat on the table so the long leads of the header stick out. Solder each of the header legs. ©Adafruit Industries Page 17 of 30 Finish up by carefully clipping the leads. For some Arduinos, the long leads may interfere with headers or parts on the Arduino board so we suggest just clipping them all. Do it carefully as these are a little difficult to cut and may fly at you. We suggest doing it over a trash can. You're done! Check out the next page for how to use the shield and libraries. ©Adafruit Industries Page 18 of 30 Arduino Usage The shield is really easy to use. Once you have attached the LCD of choice, plug it onto the Arduino and download our library from github. The example included shows how to use the RGB backlight control and reading from the keypad. Download the Library To interface with the LCD and buttons you must use our library which translates the commands through the port expander Open up the Arduino library manager: Search for the Adafruit RGB LCD Shield library and install it We also have a great tutorial on Arduino library installation at: http://learn.adafruit.com/adafruit-all-about-arduino-libraries-install-use (https:// adafru.it/aYM) Adjusting Contrast The shield uses a character LCD with an external contrast potentiometer. The first time you use it, adjust the potentiometer in the bottom right until you see the text clearly. If you don't upload code to the Arduino, some boxes will appear instead ©Adafruit Industries Page 19 of 30 If you don't see any text on the LCD, be sure to try twisting the orange contrast potentiometer until the text appears. You may have to turn it all the way around from one side to the other until you see text Shared Pins The I2C pins are shared with other pins, and each Arduino type has a different sharing scheme. Those pins cannot be used for anything else than I2C when this shield is used! Uno/Duemilanove/Diecimila - I2C pins are also the same pins as Analog 4 and Analog 5 Mega 1280 and 2560 - I2C pins are also the same pins as Digital 20 and 21 Leonardo and other 32u4-based - I2C pins are also the same pins as Digital 2 and 3 Writing Your Own Sketches The Adafruit_RGBLCDShield library is a derivative of the LiquidCrystal library that comes with Arduino so you can call any of the functions that you're used to and they'll work just the same. There are two extra functions you may want to use. One is lcd.setBacklight(color); whi ch will change the backlight color assuming you have an RGB LCD on. At this time, the library does not do any PWM on the RGB backlight, so you can select from 8 different colors (inlcuding OFF) - if you place these #define's at the top of your sketch you can simply call whichever color you want to appear. // These #defines make it easy to set the backlight color #define OFF 0x0 #define RED 0x1 #define YELLOW 0x3 #define GREEN 0x2 #define TEAL 0x6 #define BLUE 0x4 #define VIOLET 0x5 #define WHITE 0x7 Another extra of the shield is a 4-way directional keypad plus select button. This will let you design your own control interface for 'stand-alone' Arduino projects. All the buttons are read at once when you call lcd.readButtons(); which returns a variable that has individual bits set for the buttons. You can easily test for which buttons were held down at the time of the readButtons() call by using bitwise & as seen in this code snippet. Note that the library handles button debouncing internally.  There is no need to ©Adafruit Industries Page 20 of 30 debounce the buttons in your code. uint8_t buttons = lcd.readButtons(); if (buttons) { if (buttons & BUTTON_UP) { lcd.setBacklight(RED); } if (buttons & BUTTON_DOWN) { lcd.setBacklight(YELLOW); } if (buttons & BUTTON_LEFT) { lcd.setBacklight(GREEN); } if (buttons & BUTTON_RIGHT) { lcd.setBacklight(TEAL); } if (buttons & BUTTON_SELECT) { lcd.setBacklight(VIOLET); } } Using with Monochrome Displays Displays with monochrome backlights are controlled by the RED pin and will only respond to colors that have RED in them (RED, YELLOW, VIOLET). For these displays, you can use ON and OFF instead as in the snippet below: uint8_t buttons = lcd.readButtons(); if (buttons) { lcd.clear(); lcd.setCursor(0,0); if (buttons & BUTTON_UP) { lcd.print("UP "); lcd.setBacklight(ON); } if (buttons & BUTTON_DOWN) { lcd.print("DOWN "); lcd.setBacklight(OFF); } Detached Usage If you want to have the shield disconnected from the Arduino (say to panel mount it) or if you want to use it with a different type of processor board, its very easy! Just power the 5V pin with 5V, common ground to GND and then connect the SCL la beled pin (top left) to I2C clock and SDA to I2C data. Those are the only four wires you need to control the entire shield. • On Uno-shaped Arduinos, SCL is also connected to Analog 5 and SDA is connected to Analog 4. ©Adafruit Industries Page 21 of 30 • On Mega Arduinos, SCL is also connected to Digital 21 and SDA is connected to Digital 20. • On Leonardo Arduinos, SCL is also connected to Digital 3 and SDA is connected to Digital 2. Important: Wire +5V and GND to the shield pins shown in the pictures! The GND pin next to the 5v pin is NOT connected. You must use the one next to the VIN pin! CircuitPython Usage It's easy to use the RGB character LCD shield with CircuitPython and the Adafruit CircuitPython CharLCD (https://adafru.it/C47) library. This library allows you to easily write Python code that controls the RGB character LCD. ©Adafruit Industries Page 22 of 30 CircuitPython Microcontroller Wiring Assemble the shield kit as shown in the previous pages. Then, attach it to a Metro M0 or Metro M4. It's that simple! CircuitPython Installation of CharLCD Library You'll need to install the Adafruit CircuitPython CharLCD (https://adafru.it/C47) library on your CircuitPython board. First make sure you are running the latest version of Adafruit CircuitPython (https:// adafru.it/Amd) for your board. Next you'll need to install the necessary libraries to use the hardware--carefully follow the steps to find and install these libraries from Adafruit's CircuitPython library bundle  (https://adafru.it/uap).  Our CircuitPython starter guide has a great page on how to install the library bundle (https://adafru.it/ABU). If you choose, you may manually install the libraries from the bundle: • adafruit_character_lcd • adafruit_mcp230xx • adafruit_bus_device Before continuing make sure your board's lib folder or root filesystem has the adafrui t_character_lcd, adafruit_mcp230xx, and adafruit_bus_device files and folders copie d over. Next connect to the board's serial REPL (https://adafru.it/Awz) so you are at the CircuitPython >>> prompt. CircuitPython Code To demonstrate the usage of the character LCD we'll initialize it and display text using CircuitPython code. ©Adafruit Industries Page 23 of 30 First, you'll need to import necessary modules, initialize the I2C bus, and create an instance of the character LCD class. Paste the following code into your REPL: import board import busio import adafruit_character_lcd.character_lcd_rgb_i2c as character_lcd lcd_columns = 16 lcd_rows = 2 i2c = busio.I2C(board.SCL, board.SDA) lcd = character_lcd.Character_LCD_RGB_I2C(i2c, lcd_columns, lcd_rows) Now you're ready to start writing text and characters on the display!  The usage of the LCD class is exactly the same as shown in the parallel LCD wiring guide (https:// adafru.it/CVQ).  Be sure to check out that guide (https://adafru.it/CVQ) for a complete discussion of LCD usage. As a quick test though you can run the following code to use the color property to set the backlight to red and the message property to write text to the display: lcd.color = [100, 0, 0] lcd.message = "Hello\nCircuitPython" See the parallel LCD guide for more functions you can call to control the LCD! (https:/ /adafru.it/CVQ) That's all there is to using the RGB character LCD shield kit with CircuitPython! Full Code Example Copy the following example to code.py on your board, and see a demo of some of the different things the character LCD library has to offer! # SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries # SPDX-License-Identifier: MIT ©Adafruit Industries Page 24 of 30 """Simple test for I2C RGB character LCD shield kit""" import time import board import adafruit_character_lcd.character_lcd_rgb_i2c as character_lcd # Modify this if you have a different sized Character LCD lcd_columns = 16 lcd_rows = 2 # Initialise I2C bus. i2c = board.I2C() # uses board.SCL and board.SDA # Initialise the LCD class lcd = character_lcd.Character_LCD_RGB_I2C(i2c, lcd_columns, lcd_rows) lcd.clear() # Set LCD color to red lcd.color = [100, 0, 0] time.sleep(1) # Print two line message lcd.message = "Hello\nCircuitPython" # Wait 5s time.sleep(5) # Set LCD color to blue lcd.color = [0, 100, 0] time.sleep(1) # Set LCD color to green lcd.color = [0, 0, 100] time.sleep(1) # Set LCD color to purple lcd.color = [50, 0, 50] time.sleep(1) lcd.clear() # Print two line message right to left lcd.text_direction = lcd.RIGHT_TO_LEFT lcd.message = "Hello\nCircuitPython" # Wait 5s time.sleep(5) # Return text direction to left to right lcd.text_direction = lcd.LEFT_TO_RIGHT # Display cursor lcd.clear() lcd.cursor = True lcd.message = "Cursor! " # Wait 5s time.sleep(5) # Display blinking cursor lcd.clear() lcd.blink = True lcd.message = "Blinky Cursor!" # Wait 5s time.sleep(5) lcd.blink = False lcd.clear() # Create message to scroll scroll_msg = "
很抱歉,暂时无法提供与“714”相匹配的价格&库存,您可以联系我们找货
