Arduino 4 RELAYS SHIELD
The Arduino 4 Relays Shield allows your Arduino driving high power loads.
The Arduino 4 Relays Shield allows your Arduino driving high power loads that cannot
be controlled directly by Arduino's digital pins. The Shield features four relays, each
relay with 2 pole changeover contacts (NO and NC). Four LEDs indicate the on/off state
of each relay.
Power
The shield doesn't need external power: it will be provided by the base board, through
the 5V and 3.3V pins of the Arduino board used as base.
Input and Output
The relays are controlled by the following Arduino board pins:
Relay 1 = Arduino pin 4
Relay 2 = Arduino pin 7
Relay 3 = Arduino pin 8
Relay 4 = Arduino pin 12
The shield features several TinkerKit input/output and communication interfaces.
Connecting TinkerKit modules can simplify the creation of a project or a prototype.
The on-board connectors are :
2 TinkerKit Inputs: IN2 and IN3 (in white), these connectors are routed to the Arduino A2
and A3 analog input pins.
2 TinkerKit Outputs: OUT5 and OUT6 (in orange), these connectors are routed to the
Arduino PWM outputs on pins 5 and 6.
2 TinkerKit TWI: these connectors (4-pin in white) are routed on the Arduino TWI
interface. Both connect to the same TWI interface to allow you to create a chain of TWI
devices.
Physical Characteristics
The maximum length and width of the 4 Relays Shield PCB are 2.7 and 2.1 inches
respectively. Four screw holes allow the Shield to be attached to a surface or case. Note
that the distance between digital pins 7 and 8 is 160 mil (0.16"), not an even multiple of
the 100 mil spacing of the other pins.
Compatible Boards
The shield is compatible with all the Arduino boards, 5V and also 3.3V standards.
The Arduino 4 Relays Shield is a solution for driving high power loads that cannot be
controlled by Arduino's digital IOs, due to the current and voltage limits of the controller.
The Shield features four relays, each relay provides 2 pole changeover contacts (NO and NC);
in order to increase the current limit of each output the 2 changeover contacts have been
put in parallel. Four LEDs indicate the on/off state of each relay.
FEATURES
GENERAL
Thinker Kit interface
2x TWI, 2x
OUT, 2x IN
Operating
Voltage
5V
Interfaces with
Arduino Board
DIO
Current
needs
140 mA (with all
releays on, about 35
mA each)
Relays
4 (60W)
PCB size
53 x 68.5 mm
Weight
0.044 Kg
Product
Code
A000110
http://www.arduino.org/products/shields/arduino-4-relays-shield
9/28/2016
很抱歉,暂时无法提供与“A000110”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+260.50952
- 10+251.02295
- 25+242.37483
- 国内价格 香港价格
- 1+255.264921+31.92780
- 10+250.1444110+31.28734
- 25+245.8299625+30.74770
- 50+239.3601350+29.93847
- 100+228.48347100+28.57805
- 250+218.23661250+27.29640
