A000106
A000106
    ARDUINO
    ARDUINO GSM SHIELD 2 ANT CONN
A000106 数据手册
        ARDUINO GSM SHIELD 2  ( A N T E N N A   C O N N E C TO R )   Code: A000106    The Arduino GSM Shield 2 allows your Arduino board to make phone  calls, send SMS and connect to the Internet.     The Arduino GSM Shield 2 allows an Arduino board to connect to the internet,  make/receive voice calls and send/receive SMS messages. The shield uses a radio  modem M10 by Quectel. It is possible to communicate with the board using AT  commands. The GSM library has a large number of methods for communication  with the shield.  https://www.arduino.cc/en/Reference/GSM    The shield uses digital pins 2 and 3 for software serial communication with the  M10. Pin 2 is connected to the M10’s TX pin and pin 3 to its RX pin. See these  notes for working with an Arduino Mega, Mega ADK, or Leonardo. The modem's  PWRKEY pin is connected to Arduino pin 7.  https://www.arduino.cc/en/Main/en/Guide/GSMShieldLeonardoMega  The M10 is a Quad‐band GSM/GPRS modem that works at frequencies  GSM850MHz, GSM900MHz, DCS1800MHz and PCS1900MHz. It supports TCP/UDP  and HTTP protocols through a GPRS connection. GPRS data downlink and uplink  transfer speed maximum is 85.6 kbps.  To interface with the cellular network, the board requires a SIM card provided by a  network operator. See the getting started page for additional information on SIM  usage.  https://www.arduino.cc/en/Main/Guide/ArduinoGSMShieldV2#toc4    The most recent revision of the board uses the 1.0 pinout on rev 3 of the Arduino  Uno board.    To use this board you should note that:        Requires an Arduino board (not included)  Operating voltage 5V (supplied from the Arduino Board)  Connection with Arduino Uno on pins 2, 3 (Software Serial) and 7 (reset). See these  notes for working with a Mega, Mega ADK, or Leonardo.  https://www.arduino.cc/en/Guide/GSMShieldLeonardoMega  This version has a connector for an external antenna    You can find your board warranty information here.  https://www.arduino.cc/en/Main/warranty  Getting Started  In the Getting Started section, you can find all the information you need to  configure your board, use the Arduino Software (IDE), and start to tinker with  coding and electronics.  https://www.arduino.cc/en/Guide/ArduinoGSMShieldV2  https://www.arduino.cc/en/Main/Software    OSH: Schematics  Arduino GSM Shield 2 is open‐source hardware! You can build your own board  using the following files:  EAGLE FILES IN .ZIP    https://www.arduino.cc/en/uploads/Main/arduino‐gsm‐shield‐06‐reference‐ design.zip  SCHEMATICS IN .PDF  https://www.arduino.cc/en/uploads/Main/Arduino‐GSM‐Shield2‐Rev3.2‐SCH.pdf  SIM to use with this shield  The GSM shield 2 is compatible with Data only and Voice and Data SIM. GPRS and  SMS are supported by 2G Data only SIM, while voice calls, supported by the  hardware, require a Voice and Data SIM, the same you may use in a GSM mobile  phone. The Data transfer is based on GPRS technology and therefore it is not  compatible with 3G or UMTS only network providers. GPRS is a 2G technology.  Power  It is recommended that the board be powered with an external power supply that  can provide between 700mA and 1000mA. Powering an Arduino and the GSM  shield 2 from a USB connection is not recommended, as USB cannot provide the  required current for when the modem is in heavy use.  On board indicators  The shield contains a number of status LEDs:     On: shows the Shield gets power.  Status: turns on to when the modem is powered and data is being transferred to/from  the GSM/GPRS network.  Net: blinks when the modem is communicating with the radio network.  On board interfaces  The shield comes with a on‐board audio jack as well, and it can be used for both  microphone and line inputs. It is also possible to make voice calls. You don’t need  to add a speaker and microphone.  There are two small buttons on the shield. The button labeled "Reset" is tied to  the Arduino reset pin. When pressed, it will restart the sketch. The button labeled  "Power" is connected to the modem and will power the modem on and off. For  early versions of the shield, it was necessary to press the power button to turn on  the modem. Newer versions of the board will turn the modem on automatically.  If you have an early version of the shield, and it does not turn on automatically,  you can solder a jumper to the CTRL/D7 pad on the reverse side of the board, and  it will turn on when an attached Arduino receives power.      Several of the modem pins are exposed on the underside of the board. These  provide access to the modem for features like speaker output and microphone  input. See the datasheet for complete information.      Previous Versions Do you own a past an old version of this product? Check Arduino GSM Shield  V1 product page.  https://www.arduino.cc/en/Main.ArduinoGSMShieldV1        https://store.arduino.cc/usa/arduino‐gsm‐shield‐2‐antenna‐connector 12‐7‐17
A000106 价格&库存
很抱歉,暂时无法提供与“A000106”相匹配的价格&库存,您可以联系我们找货
