Assembled Pi Cobbler Plus - Breakout Cable
for Pi B+/A+/Pi 2
PRODUCT ID: 2029
DESCRIPTION
The Raspberry Pi B+/Pi 2 has landed on the Maker World like a 40-GPIO pinned,
quad-USB ported, credit card sized bomb of DIY joy. And while you can use most of
our great Model B accessories by hooking up our downgrade cable, its probably a
good time to upgrade your set up and accessorize using all of the Model B+'s / Pi
2's 40 pins.
That's why we now carry the Adafruit Assembled Pi Cobbler Plus - Breakout and
Cable for Raspberry Pi A+, B+, and Pi 2. It's an add on prototyping Pi Cobbler from
Adafruit specifically designed for the B+ and Pi 2 that you can break out all those
tasty power, GPIO, I2C and SPI pins from the 40-pin header onto a solderless
breadboard. This will make "cobbling together" prototypes with the Pi super easy.
Designed for use with Raspberry Pi Model A+/B+/Pi 2 only! No soldering required!
This Cobbler is in a compact shape, which is the least bulky way to wire up. The
cable plugs between the Pi A+/B+/Pi 2 computer and the Cobbler breakout. The
Cobbler can plug into any solderless breadboard (or even a prototyping board like
the PermaProto). The Cobbler PCB has all the pins labeled nicely so you can go
forth and build circuits without keeping a pin-out printout at your desk. We think
this will make it more fun to expand the Pi and build custom circuitry with it.
Please note, this product only contains an assembled Cobbler Plus and 40-pin
ribbon cable (in slimming Adafruit Black). Raspberry Pi B+, solderless breadboard,
breadboarding wires, cables, components, power supply, etc are not included! We
do stock many of those items in the shop, so check those out as well!
Note: The Raspberry Pi Model A+ and Raspberry Pi 2 are also compatible with this
product!
http://www.adafruit.com/product/2029
11/13/2015
Technical Details
Dimensions:
63mm x 20mm x 11mm / 2.5" x 0.8" x 0.4"
Height with pins: 20mm / 0.8"
Weight: 12g
很抱歉,暂时无法提供与“2029B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+66.021951+8.27928
