Page 1 of 4
Adafruit FONA 808 Shield - Mini Cellular
GSM + GPS for Arduino
PRODUCT ID: 2636
Page 2 of 4
DESCRIPTION
Cellular + GPS tracking, all in one, for your Arduino? Oh yes! Introducing Adafruit
FONA 808 GSM + GPS Shield, an all-in-one cellular phone module with that lets
you add location-tracking, voice, text, SMS and data to your project, in Arduino
shield format for easy use.
This shield fits right over your Arduino or compatible. At the heart is a powerful
GSM cellular module (we use the latest SIM808) with integrated GPS. This module
can do just about everything
• Quad-band 850/900/1800/1900MHz - connect onto any global GSM network
with any 2G SIM (in the USA, T-Mobile is suggested)
• Fully-integrated GPS (MT3337 chipset with -165 dBm tracking sensitivity) that
can be controlled and query over the same serial port
• Make and receive voice calls using a headset or an external 32Ω speaker +
electret microphone
• Send and receive SMS messages
• Send and receive GPRS data (TCP/IP, HTTP, etc.)
• PWM/Buzzer vibrational motor control
• AT command interface with "auto baud" detection
Here's the GPS specifications:
Page 3 of 4
• 22 tracking /66 acquisition channels
• GPS L1 C/A code
• Sensitivity
Tracking: -165 dBm
Cold starts : -148 dBm
• Time-To-First-Fix
Cold starts: 32s (typ.)
Hot starts: 1s (typ.)
Warm starts: 5s (typ.)
• Accuracy: approx 2.5 meters
Sounds delicious, right? So we plated this fine module onto a shield with all the
extras you need to make your next project shine
• Onboard LiPoly battery charging circuitry so you can take your project on the
go. Use any 500mAh+ LiPoly or LiIon battery and recharge via the Arduino when
necessary. Two LEDs let you know when its charging and done. You can then flip
the switch and use the battery to run your circuit!
• Standard 4-pole TRRS headphone jack. Use any 'Android' or 'iPhone'compatible headset with mic
• Breakouts for external 32Ω speaker and electret mic if you don't want to use a
headphone
• Level shifting circuitry to make it Arduino-safe
• Vibrational motor (buzzer) driver so you can have noiseless notifications
• uFL connection for external passive GPS & external GSM antenna
• Indicator LEDs for power and network connectivity
• Any standard 2G SIM slides into a secure connector
On its own, this shield can't do anything. It requires a microcontroller like an
Arduino to drive it! You will also need some required accessories to make FONA
work. These are not included!
• SIM Card! A 2G Mini SIM card is required to do anything on the cellular
network. US AT&T no longer sells 2G SIMs and will shut off their 2G network,
so for American customers we recommend any T-Mobile or reseller (TING, SIMPLE
mobile, etc) that uses the T-Mobile network.
• Lipoly Battery - 500mAh or larger! This 500mAh battery, or this 1200mAh will
work great.
• External GSM Antenna - This slim uFL antenna works great!
• External Passive GPS Antenna - This 15mm passive antenna works great!
Page 4 of 4
Each order comes with one tested and assembled FONA shield and a stick of 0.1"
male header. Required Arduino, SIM card, battery, antenna and other accessories
are not included! Some light soldering is required to put the headers onto the
shield. You can also grab some stacking headers if you would like to stack a shield
on top
There's also some recommended accessories. They are not required but chances
are you'll want them!
• TRRS 4-Pole Headset - Any 'iPhone' or 'Android' compatible (but not iPhone
original) should work. We tried about 10 different ones, and basically the more
expensive once are more comfortable and louder but our official iPhone headset
mic did not work.
• External Mic & Speaker - If you want to talk directly to your FONA, an electret
mic and mini 8 ohm speaker will do quite nicely.
• Vibrating motor - the FONA can drive this directly, just solder a mini vibrating
motor disc in!
Check out our great tutorial for code, wiring diagrams, schematics, datasheets and
more!
http://www.adafruit.com/product/2636
11/13/2015
很抱歉,暂时无法提供与“2636”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+476.704721+61.71355
