SpeakUp - Speech recognition click board
for recognizing over 200 different voice
commands
The SpeakUp is a speech recognition click™
board. You can set it up to recognize over 200
different voice commands and have the on-board
MCU carry them out instantly.
PREORDER NOW
shipping starts April 28th
Easy to
configure
Over 200
commands
Ultra fast
operation
Standalone
mode
Simple & Straightforward
SpeakUp learns from scratch, so you can make it understand your commands spoken in any language, dialect or slang.
SpeakUp - Speech recognition click board for recognizing over 200 different voice commands
It listens
and learns...
...understands
and obeys
Using a simple interface
on your computer, you
When you put it to work,
record a word or phrase
it listens to what you're
(up to 5 seconds) and
saying, matches the
assign it an instruction.
sound to one of the pre-
Repeat for as many
recorded commands, and
commands as you need.
triggers the specified
action which the onboard MCU executes.
Ins & Outs
What gives the SpeakUp its speech recognition capabilities is the firmware we developed for the on-board MCU. It's based
on the DTW algorithm, which makes it decisive, it turns your talk into action almost instantly.
Input:
Sound is received through an on-board microphone. There’s also a 3.5mm jack for
connecting an external microphone.
Between the mic and the MCU sits a VS1053 IC with a
built in stereo-audio codec to process the raw signal.
Output:
After the processed sound has been forwarded to the STM32F415RG MCU that interprets the
voice command, there are two output options which can be utilized at the same time or separately:
STANDALONE
CLICK™ MODE:
MODE: On-board
Sends index of the
MCU directly controls
matched voice
external devices using
command to a
12 user programmable
selectable interface:
GPIOs.
USB or UART.
Software Makes It Easy
Recording commands and assigning actions is dead simple thanks to the free software tool for programming the SpeakUp.
First, connect the SpeakUp to your computer using a USB cable. It will show up as a HID device, so no special drivers are
required. Just launch the app and start tinkering.
1. Create a project
2. Add a command
3. Record it
Start by creating a new project.
Commands are listed as tabs.
Record your voice command
It will hold all of your settings
Add a new one using the plus
and give it a name. You can
and configuration.
button in the upper left corner.
play it back to make sure it’s
OK.
Turn Talk To Action
Wouldn't you rather issue verbal commands and have your machines comply, instead of pressing keys, pushing buttons and
flipping switches all the time? There's a wide range of applications for the SpeakUp.
Command your lights, doors and home appliances.
Create voice commanded remotes for TVs or media centers.
Reduce complexity and cost of control interfaces.
When you do something with both hands and voice command is the only option.
Examples comming soon!
Tech Specs
Along with its key components, the tiny click board packs other useful bits like two buttons for recording or deleting voice
commands manually, three signal LEDs give recognition feedback and indicate power.
Microphone
Microcontroller
- Sensitivity: -44 ± 3dB
- STM32F415RG (ARM Cortex-M4)
- Frequency rage: 100Hz to 20.000Hz
- 1024kB Flash, 192kB RAM
- Signal to noise ratio: 56dBA
- 168MHz operation
Audio codec
Connectivity
- VS1053 stereo audio codec
- 12 programmable GPIOs
- Streaming support
- mikroBUS connector
- Line out pads
- USB MINI-B connector
What You Get
Package dimensions:
L 70mm, W 60mm, H 30mm
Package weight:
~40g
Preorder Now For Shipping On April
28th
CUSTOMIZATION: We can modify our products to suit your requirements, click here for details.
MIKROE1534
SpeakUp click
MikroElektronika Embedded Solutions
PIC Solution
dsPIC Solution
Follow us on
STM32 Solution
8051 Solution
Add-on boards
PIC Development Boards
dsPIC Development Boards
STM32 Development Boards
8051 Dev. Boards
Click Boards
PIC Compilers
dsPIC Compilers
STM32 Compilers
8051 Compilers
mikromedia shields
PIC Programmers/Debuggers
dsPIC Programmers/Debuggers
STM32 Programmers/Debuggers
8051 Programmers
Communication
PIC Kits
dsPIC Kits
STM32 Kits
8051 Books
Storage
PIC Books
dsPIC Books
8051 Kits
Real Time Clock
PIC32 Solution
Tiva C Series Solution
AVR Solution
Tiva C Development Boards
Additional Software
PIC32 Development Boards
AVR Development Boards
Tiva C Compilers
Visual TFT
PIC32 Compilers
AVR Compilers
Tiva C Programmers/Debuggers
Visual GLCD
PIC32 Programmers/Debuggers
AVR Programmers/Debuggers
Tiva C Kits
Package Manager
PIC32 Kits
AVR Kits
Forum
mikroBUS
Power Supply
GPS
GLCD Font Creator
Lets make
Press
Legal
Archive
Measurement
Audio & Voice
GSM/GPRS
Timer Calculator
Support
Display
About Us
Customization
Copyright © 1998 - 2014. MikroElektronika. All rights reserved. All trade and/or services marks mentioned are the property of their respective owners.
http://www.mikroe.com/click/speakup/[3/18/2014 8:47:29 AM]
很抱歉,暂时无法提供与“MIKROE-1534”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+375.28345
- 5+367.77507
- 25+360.42290
- 国内价格 香港价格
- 1+359.455661+45.12150
- 3+353.796333+44.41110
- 5+351.231955+44.08920
- 10+347.7833010+43.65630
- 20+342.3008220+42.96810
