Terminal sensor adapter V2 SKU: DFR0055
Contents
1 Introduction
2 Specifications
3 Pin Out
4 Application with DS18B20
4.1 Application Connection Diagram
5 Sample Code
6 Version history
Introduction
This is universal sensor adapter V2.0, it can be accessed by digital input modules and analog input
module. The module with Arduino sensor expansion board, in combination.Improvment compare
with the old version,we add a 10K resistor between A & B, A & C respectively,so that you needn't to
connect a addition resistor while the sensor must have a pull-up or pull-down resistor. Why need a
pull-up or pull down resistor, please refer to"Uderstanding pull-up and pull-down resistors"
Generally speaking, this terminal provides a much easier way to connect a switch or any modules
that requires pull-up/down resistor to microcontroller
Specifications
Voltage: +5 V
Current:
Blue(DATA SIGNAL)
B
RED
C
Black (GND)
(VIN)
2.Waterproof DS18B20 Digital Temperature Sensor & Arduino board
1(A)
Digital Pin2
2(B)
5V/3.3V
3(C)
GND
Setting for the Pull-up Register/Pull-down Register Selection Jumpers
When connect DS18B20 with the adapter,please choose to use the
Pull-up Register Jumper
#include
int DS18S20_Pin = 2; //DS18S20 Signal pin on digital 2
//Temperature chip i/o
OneWire ds(DS18S20_Pin);
// on digital pin 2
void setup(void) {
Serial.begin(9600);
void loop(void) {
float temperature = getTemp();
Serial.println(temperature);
delay(2000); //just here to slow down the output so it is easier to read
float getTemp(){
//returns the temperature from one DS18S20 in DEG Celsius
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
//no more sensors on chain, reset search
Serial.println("no more sensors on chain, reset search!");
ds.reset_search();
return -1000;
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return -1000;
if ( addr[0] != 0x10 && addr[0] != 0x28) {
Serial.print("Device is not recognized");
return -1000;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
byte present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for (int i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
ds.reset_search();
byte MSB = data[1];
byte LSB = data[0];
float tempRead = ((MSB
很抱歉,暂时无法提供与“DFR0055”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+20.862061+2.71200
