DFR0117
DFR0117
    DFROBOT
    EEPROMDATASTORAGEMODULEFORA
DFR0117 数据手册
    EEPROM Data Storage Module For Arduino (SKU:DFR0117)   Contents      1 Introduction 2 Specification 3 Setting 4 Address Truth Table 5 Sample Code Introduction If you want more storage for your Arduino project, this module is designed for you. This EEPROM data storage module supplies an extra 32k byte for your project. Simply wired them via I2C. Supplied with Interface cable which can be fawlessly integrated with interface shield. Specification      Supply Voltage:+5V Current:> 8)); // MSB Wire.send((int)(eeaddress & 0xFF)); // LSB Wire.send(rdata); Wire.endTransmission(); } // WARNING: address is a page address, 6-bit end will wrap around // also, data can be maximum of about 30 bytes, because the Wire library ha s a buffer of 32 bytes void i2c_eeprom_write_page( int deviceaddress, unsigned int eeaddresspage, byte* data, byte length ) { Wire.beginTransmission(deviceaddress); Wire.send((int)(eeaddresspage >> 8)); // MSB Wire.send((int)(eeaddresspage & 0xFF)); // LSB byte c; for ( c = 0; c < length; c++) Wire.send(data[c]); Wire.endTransmission(); } byte i2c_eeprom_read_byte( int deviceaddress, unsigned int eeaddress ) { byte rdata = 0xFF; Wire.beginTransmission(deviceaddress); Wire.send((int)(eeaddress >> 8)); // MSB Wire.send((int)(eeaddress & 0xFF)); // LSB Wire.endTransmission(); Wire.requestFrom(deviceaddress,1); if (Wire.available()) rdata = Wire.receive(); return rdata; } // maybe let's not read more than 30 or 32 bytes at a time! void i2c_eeprom_read_buffer( int deviceaddress, unsigned int eeaddress, byt e *buffer, int length ) { Wire.beginTransmission(deviceaddress); Wire.send((int)(eeaddress >> 8)); // MSB Wire.send((int)(eeaddress & 0xFF)); // LSB Wire.endTransmission(); Wire.requestFrom(deviceaddress,length); int c = 0; for ( c = 0; c < length; c++ ) if (Wire.available()) buffer[c] = Wire.receive(); } void setup() { char somedata[] = "this is data from the eeprom"; // data to write Wire.begin(); // initialise the connection Serial.begin(9600); i2c_eeprom_write_page(0x50, 0, (byte *)somedata, sizeof(somedata)); // wr ite to EEPROM delay(10); //add a small delay Serial.println("Memory written"); } void loop() { int addr=0; //first address byte b = i2c_eeprom_read_byte(0x50, 0); // access the first address from the memory while (b!=0) { Serial.print((char)b); //print content to serial port addr++; //increase address b = i2c_eeprom_read_byte(0x50, addr); //access an address from the memo ry } Serial.println(" "); delay(2000);   } Powered By DFRobot © 2008-2017
DFR0117 价格&库存
很抱歉,暂时无法提供与“DFR0117”相匹配的价格&库存,您可以联系我们找货
