SEN0101
SEN0101
    DFROBOT
    TCS3200RGBCOLORSENSORBOARD
SEN0101 数据手册
  TCS3200 Color Sensor (SKU:SEN0101) The TCS3200 Color Sensor Contents      1 Introduction 2 Specifications 3 PinOut 4 Tutorial 4.1 Connection Diagram 4.2 S0,S1,S2,S3 4.3 Sample Code 4.4 Result 5 Trouble shooting Introduction TCS3200 Color Sensor is a complete color detector, including a TAOS TCS3200 RGB sensor chip and 4 white LEDs. The TCS3200 can detect and measure a nearly limitless range of visible colors. Applications include test strip reading, sorting by color, ambient light sensing and calibration, and color matching, to name just a few. The TCS3200 has an array of photodetectors, each with either a red, green, or blue filter, or no filter (clear). The filters of each color are distributed evenly throughout the array to eliminate location bias among the colors. Internal to the device is an oscillator which produces a square-wave output whose frequency is proportional to the intensity of the chosen color. Specifications            Single-Supply Operation (2.7V to 5.5V) High-Resolution Conversion of Light Intensity to Frequency Programmable Color and Full-Scale Output Frequency Power Down Feature Communicates Directly to Microcontroller S0~S1: Output frequency scaling selection inputs S2~S3: Photodiode type selection inputs OUT Pin: Output frequency OE Pin: Output frequency enable pin (active low), can be impending when using Support LED lamp light supplement control Size: 28.4x28.4mm   PinOut Pin Name I/O DESCRIPTION Power supply ground. All voltages are GND(4) referenced to GND OE(3) I Enable for fo (active low). OUT O Output frequency (fo). S0,S1(1, Output frequency scaling selection I inputs. 2) S2,S3(7, I Photodiode type selection inputs 8) VDD(5) Supply voltage Tutorial Connection Diagram Wiring instructions VCC——5V S0——D3 S2——D5 GND——GND S1——D4 S3——D6 OUT——D2 S0,S1,S2,S3 To TCS3002D, when choose a color filter, it can allow only one particular color to get through and prevent other color. For example, when choose the red filter, Only red incident light can get through, blue and green will be prevented. So we can get the red light intensity. Similarly ,when choose other filters we can get blue or green light. TCS3002D has four photodiode types. Red , blue, green and clear, reducing the amplitude of the incident light uniformity greatly, so that to increase the accuracy and simplify the optical. When the light project to the TCS3002D we can choose the different type of photodiode by different combinations of S2 and S3. Look at the form as follows. S0 S1 OUTPUT FREQUENCY SCALING (fo) L L Power down L H 2% H L 20% H H 100% TCS3002D can output the frequency of different square wave (occupies emptiescompared 50%),different color and light intensity correspond with different frequency of square wave. There is a relationship between the output and light intensity. The range of the typical output frequency is 2HZ~500KHZ. We can get different scaling factor by different combinations of S0 and S1. Look at the form as follows. S2 S3 PHOTODIODE TYPE L L RED L H BLUE H L Clear (no filter) H H GREEN Sample Code int s0=3,s1=4,s2=5,s3=6; int out=2; int flag=0; byte counter=0; byte countR=0,countG=0,countB=0; void setup() { Serial.begin(115200); pinMode(s0,OUTPUT); pinMode(s1,OUTPUT); pinMode(s2,OUTPUT); pinMode(s3,OUTPUT); } void TCS() { flag=0; digitalWrite(s1,HIGH); digitalWrite(s0,HIGH); digitalWrite(s2,LOW); digitalWrite(s3,LOW); attachInterrupt(0, ISR_INTO, CHANGE); timer0_init(); } void ISR_INTO() { counter++; } void timer0_init(void) { TCCR2A=0x00; TCCR2B=0x07; //the clock frequency source 1024 points TCNT2= 100; //10 ms overflow again TIMSK2 = 0x01; //allow interrupt } int i=0; ISR(TIMER2_OVF_vect)//the timer 2, 10ms interrupt overflow again. Internal o verflow interrupt executive function { TCNT2=100; flag++; if(flag==1) { countR=counter; Serial.print("red="); Serial.println(countR,DEC); digitalWrite(s2,HIGH); digitalWrite(s3,HIGH); } else if(flag==2) { countG=counter; Serial.print("green="); Serial.println(countG,DEC); digitalWrite(s2,LOW); digitalWrite(s3,HIGH); } else if(flag==3) { countB=counter; Serial.print("blue="); Serial.println(countB,DEC); Serial.println("\n"); digitalWrite(s2,LOW); digitalWrite(s3,LOW); } else if(flag==4) { flag=0; } counter=0; } void loop() { TCS(); while(1); } Result Data exists deviation, you need to adjust the program according to environmental parameters Trouble shooting More question and cool idea, visit DFRobot Forum Powered By DFRobot © 2008-2017
SEN0101 价格&库存
很抱歉,暂时无法提供与“SEN0101”相匹配的价格&库存,您可以联系我们找货
SEN0101
  • 1+81.718191+10.61070
库存:34
SEN0101
  • 1+69.456441+9.01858
