1300 Henley Court
Pullman, WA 99163
509.334.6306
www.digilentinc.com
Pmod SF3 Board Reference Manual
Revised October 5, 2016
This manual applies to the Pmod SF3 rev. A
Overview
The Digilent Pmod SF3 (Revision A) provides 32MB of serial Flash Memory.
Features:
32MB serial NOR Flash Memory
Supports extended SPI Protocol, Dual I/O, and
Quad I/O
Minimum 100,000 ERASE cycles per sector
More than 20 years data retention
12-pin Pmod connector with SPI interface
Follows Digilent Interface Specification Type 2A
The Pmod SF3.
1
Functional Description
The Pmod SF3 utilizes Micron's NOR Flash memory (N25Q256A) to provide easily accessed non-volatile memory to
system boards. The data sheet can be found here.
2
Interfacing with the Pmod
The Pmod SF3 communicates with the host board via the SPI protocol. By bringing the Chip Select line logic level
low voltage, users may issue a single byte instruction code to memory chip. A table of available commands can be
found in the data sheet for the N25Q256A here starting on page 28.
The memory is byte-addressed with the range of 0x000000 to 0x1FFFFFF and is organized into 256 byte pages, 4 KB
subsectors, and 64 KB sectors. The memory is written by using an Erase-Program cycle. The smallest
programmable unit is one page and the smallest erasable unit is 1 subsector.
DOC#: 510-340
Copyright Digilent, Inc. All rights reserved.
Other product and company names mentioned may be trademarks of their respective owners.
Page 1 of 2
Pmod SF3 Reference Manual
Users that wish to simply use the memory module without concerning themselves with the dual/quad input and
output communication may use the example code and tutorials found on the Pmod SF3 Resource Center.
3
Pinout Description Table
Pin
Signal
Description
Pin
Signal
Description
1
~CS
Chip Select
7
NC
Not Connected
2
MOSI/DQ0
Master-Out-Slave-In
8
NC
Not Connected
3
MISO/DQ1
Master-In-Slave-Out
9
W/DQ2
Write Protect
4
SCK
Serial Clock
10
HLD/DQ3
Hold
5
GND
Power Supply Ground
11
GND
Power Supply Ground
6
VCC
Power Supply (3.3V)
12
VCC
Power Supply (3.3V)
Any external power applied to the Pmod SF3 must be within 2.31V and 3.7V; it is strongly recommended the Pmod
is operated at 3.3V. Bottom of Form
4
Physical Dimensions
The pins on the pin header are spaced 100 mil apart. The PCB is 1 inch long on the sides parallel to the pins on the
pin header and 0.8 inches long on the sides perpendicular to the pin header.
Page 2 of 2
很抱歉,暂时无法提供与“410-340”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+176.616491+22.86117
