Weight Sensor Module SKU:SEN0160
Contents
1 Introduction
2 Specification
2.1 24-Bit Analog-to-Digital Converter for Weight Scales (HX711)
2.2 Weight Sensor Module
3 Tutorial
3.1 Hardware Requirement
3.1.1 Connection Diagram
3.2 Software Requirement
3.3 Detail Steps
4 The structure of the weight sensor
Introduction
Weight Sensor Module is based on HX711,which is a precision 24-bit analog-to-digital convertor
designed for weigh scale and industrial control applications to interface directly with a bridge
sensor.Compared with other chips, HX711 not only has a few basic function,also contains high
integration,fast response,immunity,and other features.The chip lowedrs the cost of the electronic
scale,at the same time,improving the performance and reliability.
The input interface of this weight sensor module is used sensor interface,which is compatible with
Arduino I/O port.The output adopts compact terminal that makes weight sensor module easier to
connect the weight sensor.It's the best choose for electronic enthusiast to do some tiny home scale.
The weight sensor module can be combined with weight sensor on the market. We also help you to
pick a small range of weight sensor.
Specification
24‐Bit Analog‐to‐Digital Converter for Weight Scales (HX711)
Two selectable differential input channels
On-chip active low noise PGA with selectable gain of 32,64 and 128
On-chip power supply regulator for load-cell and ADC analog power supply
On-chip oscillator requiring no external component with optional external crystal
On-chip power-on-rest
Simple digital control and serial interface: pin-driven controls, no programming needed
Selectable 10SPS or 80SPS output data rate
Simultaneous 50 and 60Hz supply rejection
Supply Voltage: 2.6V~5.5V
Current:
很抱歉,暂时无法提供与“SEN0160”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+149.192351+19.28470
- 国内价格 香港价格
- 1+148.611001+19.20960
