FIT0478
FIT0478
    DFROBOT
    7-INCHCAPACITIVETOUCHPANELOV
FIT0478 数据手册
          7-inch Capacitive Touch Panel Overlay for LattePanda Display SKU: FIT0478 INTRODUCTION This is a capacitive touch panel overlay for the LattePanda board, overlay the panel on your LattePanda 7-inch display, power the board, and you will have a high-quality user interface for project Note: Here is a new batch of touch panel that have a higher sensibility. We've already updated the driver in the new pre-installed system. And early users can manually install the driver below. Please run“install.bat”as administrator to update the driver correctly. SPECIFICATION    Capacitive touch control      Response Time: ≤16ms Transmittance:>85% Surface Hardness: 6H Tapping Durability: 200,000,000 times Supports LattePanda 10cm FPC Extension Cable Dimensions: 164.0mm x 96.0mm Powered By DFRobot © 2008-2017
FIT0478 价格&库存
很抱歉,暂时无法提供与“FIT0478”相匹配的价格&库存,您可以联系我们找货
FIT0478
  • 1+178.587511+23.15142
库存:125
FIT0478
    • 1+148.90746
    库存:109
