Arduino Shield for Raspberry Pi 2B and 3B SKU:DFR0327
Contents
1 Introduction
2 Specification
3 Features
4 Raspberry Pi B+ Meet Arduino Shield Pinout
4.1 Feature Introduction Diagram
5 Get Started with Raspberry Pi B+ Meet Arduino Shield
5.1 Tools Required
5.2 Software Required
5.3 Hardware Connection
5.4 Step by Step tutorial
6 Program the Arduino shield using Raspberry Pi B+
6.1 Software Required
6.2 Steps
7 FAQ
Introduction
What happens when a Pi meets an Arduino?
A simple example would be, when building a mobile robot, we use the Raspberry Pi to extend its
vision and get a nice tiny monitor. Meanwhile, Arduino handle nicely with the motor driving part and
delivers fast responses like obstacle avoidance. Because, without the OS, the response time of rapid
changes on the Arduino is much shorter. Also the high performance Pi can deals much easily with
wireless communications, imaging and running complex algorithm.
Therefore, with the Arduino and Pi together, you get a powerful "brain" and "cerebellum" for your
project, at one time.
Specification
Onboard Microcontroller: ATmega32u4
Arduino Leonardo Chip
Arduino Compatible pin mapping
Compatible with All arduino standard shield and sensors
System Voltage: 5v
Arduino Digital I/O: 20
Arduino Analog I/O: 6
Raspberry Pi B+ GPIO : 16
Raspberry Pi B+ I2C: 1
Raspberry Pi B+ ID_I2C: 1
Raspberry Pi B+ SPI: 1
Raspberry Pi B+ TTL UART: 1
Dimension: 88mm x 56mm x 26mm
Features
Integrate with the Xbee socket
Available to be connected to Arduino or Raspberry Pi B+ directly either
Compatible with BLE Link(BT4.0)/Bluetooth Bee(BT2.1) and xbee modules
Embeded DS1307 RTC module,which keeps time of the Pi even when the power is off, or the
battery removed
Bidirectional logic converter for Raspberry Pi B+ GPIO to convert signal between 3.3v and 5v
3 pin headers sensor port for Arduino pins and B+ GPIO, directly compatible with hundreds of
Arduino sensors and modules,like:
Relay Module V3.1 for IOT AC control
Analog pH Meter Kit for monitoring Water quality of your pool
SHT1x Humidity and Temperature Sensor
Motion Sensor for security and human detection
And so on...
Arduino shield compatible layout makes it possible to extend Arduino shield features for your Pi also,
A nice and low cost LCD12864 display
2A Motor Shield for robot building
Dual Bipolar Stepper Motor Shield
GSM/GPRS and GPS Shield
Fig1: Pi Meet Arduino Pinout
NOTE: The ID-I2C is an EEPROM interface, which is dedicated to connect to external EEPROM, it
will test automatically EEPROM devices attached to it when it starts, is used for configuring GPIO
and Linux drivers. In theory, it can be used as an ordinary IIC.
Fig2: Feature Introduction
First of all, let's control a sensor by Raspberry Pi directly with Meet Arduino Shield. Note: For
this tutorial, we assume that you've known the basic knowledge about the Raspberry Pi B+. And
more details will be focused on how to extend and use more hardware modules and sensors for your
Raspberry pi B+ projects. In this part, we will control the Relay module with Python via Pi's GPIO.
Tools Required
1. Raspberry Pi B+ with Ethernet or WIFI connected
2. Raspberry Pi B+ Meet Arduino shield
3. Relay module (or and LED module)
Software Required
1. Python 2 Installed.
2. Setup SSH on Raspberry Pi.
If you didn't install python. Please enter the following commands below into LX Terminal via SSH.
root@raspberrypi:/home/pi# sudo apt-get update
root@raspberrypi:/home/pi# sudo apt-get install python-rpi.gpio
Hardware Connection
Fig3: Relay CD
1.Plug the Pi Meet Arduino shield to the Raspberry Pi B+, Which connected with the power and
Ethernet.
2.Connect the Relay module(or LED module) to your Pi as the hardware connection shown.
3.Login in your Pi by Putty.
Fig4: Login SSH
4.Create a Python example code using nano.
root@raspberrypi:/home/pi# nano blink.py
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
GPIO.setup(4,GPIO.OUT)
while True:
GPIO.output(4,GPIO.HIGH)
time.sleep(1)
GPIO.output(4,GPIO.LOW)
time.sleep(1)
5.Run the python sample by the command below.And Check the effect. PS: The module is
connected to the GPIO 4 matching the software configuration.
root@raspberrypi:/home/pi# python blink.py
6.+ to stop running the python demo. =. = The switching of the relay module create the
noise...
In this part, we will share how to program your Arduino using Pi. The steps is quite simple what you
need is just installing the Arduino on your Pi and run the remote desktop to test it.
Software Required
1. TightVNC Viewer on your PC
2. TightVNC on your Pi
3. Arduino IDE on your Pi
To install the TightVNC on your Pi, please check the commands below.
root@raspberrypi:/home/pi# sudo apt-get install tightvncserver
And to install the Arduino IDE on your Pi.
root@raspberrypi:/home/pi# sudo apt-get install arduino
Steps
1. Connect the micro usb from Meet Arduino shield to the USB host on the Pi.
2. Launch your VNC server on the Raspberry Pi B+.
root@raspberrypi:/home/pi# sudo vncserver
1. Log in the remote desktop to Pi using TightVNC Viewer.
2. Launch your Arduino IDE. Open the blink sample sketch. Choose the leonardo as the board
connected and open the right port as the picture shown.
Fig2: Arduino IDE and program the shield
1. Click "Upload" to program it.
FAQ
Q1. Some general Arduino Problems/ FAQ/ Tips, very good to know.
A. Clike the topic link on DFRobot Forum.
For Q2.ICSP interface pin definition
Q2. SPI devices not working on this expansion shield? I have been working around with the
microSD card reader (cod. dfr0229) and this expansion shield. The arduino works great, I even
have a lcd display working without any problem, but the SD card reader doesn't seem to work
so well, I have connected it to the icsp pins (D4,11,12,13, 5V&GND). His post link on Forum.
A. Note that the SPI pins of Leonardo are not connected to any of the digital I/O pins as
they are on the Uno, they are only available on the ICSP connector. From Arduino.cc
For any question/advice/cool idea to share, please visit DFRobot Forum.
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“DFR0327”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+174.878571+22.73365
- 国内价格 香港价格
- 1+124.129251+16.13640
