SEN0211
SEN0211
    DFROBOT
    GRAVITY:ANALOGACCURRENTSENSO
SEN0211 数据手册
- SKU:SEN0211 Introduction When you want to measure AC current, it is common to have trouble cutting the wires, wiring or soldering. The Gravity: Analog AC Current Sensor comes to the rescue, eliminating the need to cut wires or reconnect circuits. Simply clamp the AC transformer probe on the AC line, and then plug the 3.5mm headphone jack into the signal conversion module to read the current AC current value. The analog output is designed to be compatible with 3V3/5V micro-controller. It can be conveniently used for AC current measurement to monitor AC motors, lighting equipment, air compressors, etc. Specification • AC Current Signal Conversion Module o o o o o o • Input Voltage (VCC): 3.3V - 5.5V Interface: Gravity Analog (PH2.0-3P,analog voltage output 0.2-2.8VDC) AC Voltage Input Range: 0-1V (AC RMS) Relative Error: ±4% Dimension: 32 × 27 mm /1.26 × 1.06 in Weight: 5 g Open Type AC Transformer Probe o o o o o o o o o AC Current Range: 0 - 5A (SEN0287), 0 - 10A(SEN0288), 0 - 20A(SEN0211) Signal Output (standard Φ3.5mm 3P plug): 0-1V AC voltage, linear corresponding range 0-5A, 0-10A, 0-20A Accuracy: ±1% Non-linearity: ≤±0.2% Frequency Range: 50Hz ~ 1kHz Cable Length: 1 m Working Temperature: -25 ℃ ~ +70 ℃ Opening Size: 13 × 13 mm / 0.51 × 0.51 in Weight: 50 g Board Overview LABEL NAME Function Description 1 - GND 2 + Power Input (3.3V-5.5V) 3 A Signal Output (0.2-2.8VDC) 4 Φ3.5mm 3P plug AC Transformer Input Signal Tutorial This tutorial will demonstrate how to use the AC transformer probe and AC sensor module to detect AC current. Requirements • Hardware o Arduino UNO or simliar x1 o AC Current Signal Conversion Module x1 o Open Type AC Transformer Probe x1 o LCD Keypad Shield For Arduino x1 o Gravity-3P Analog Sensor Cable x1 • Software o Arduino IDE V1.6.5 Click to Download Arduino IDE from Arduino® Connection Diagram The AC transformer probe can only clamp to one of the AC wire. It cannot be clamped both at the same time! Sample Code • • • • Connect the module to the A2 port of the Arduino UNO according to the connection diagram. Modify the parameters of #define ACTectionRange 20; in the sample code according to the AC transformer range used. For example, if the AC transformer range is 5A (SEN0287), change this parameter to 5. Upload the sample program below. Turn on the serial port monitoring, set the baud rate to 115200, and observe the serial printed data. About Calibration Since the analog reading is affected by the accuracy of the reference voltage. For a more accurate reading, use a high-precision multimeter to measure the analog reference voltage of the controller (usually the same as the supply voltage) and modify the #define VREF 5.0 parameter in the sample code below to complete the calibration. /*! * @file readACCurrent. * @n This example reads Analog AC Current Sensor. * @copyright Copyright (c) 2010 DFRobot Co.Ltd (https://www.dfrobot.com) * @licence The MIT License (MIT) * @get from https://www.dfrobot.com Created 2016-3-10 By berinie Chen Revised 2019-8-6 By Henry Zhao */ const int ACPin = A2; #define ACTectionRange 20; (5A,10A,20A) //set arduino signal read pin //set Non-invasive AC Current Sensor tection range // VREF: Analog reference // For Arduino UNO, Leonardo and mega2560, etc. change VREF to 5 // For Arduino Zero, Due, MKR Family, ESP32, etc. 3V3 controllers, change VREF to 3.3 #define VREF 5.0 float readACCurrentValue() { float ACCurrtntValue = 0; float peakVoltage = 0; float voltageVirtualValue = 0; //Vrms for (int i = 0; i < 5; i++) { peakVoltage += analogRead(ACPin); //read peak voltage delay(1); } peakVoltage = peakVoltage / 5; voltageVirtualValue = peakVoltage * 0.707; //change the peak voltage to the Virtual Value of voltage /*The circuit is amplified by 2 times, so it is divided by 2.*/ voltageVirtualValue = (voltageVirtualValue / 1024 * VREF ) / 2; ACCurrtntValue = voltageVirtualValue * ACTectionRange; return ACCurrtntValue; } void setup() { Serial.begin(115200); pinMode(13, OUTPUT); } void loop() { float ACCurrentValue = readACCurrentValue(); //read AC Current Value Serial.print(ACCurrentValue); Serial.println(" A"); digitalWrite(13, HIGH); delay(500); digitalWrite(13, LOW); delay(500); } Copy Connection Diagram with LiquidCrystal Sample Code with LiquidCrystal /*! * @file readACCurrent_LCD. * @n This example reads Analog AC Current Sensor and display on the LCD. * @copyright Copyright (c) 2010 DFRobot Co.Ltd (https://www.dfrobot.com) * @licence The MIT License (MIT) * @get from https://www.dfrobot.com Created 2016-3-10 By berinie Chen Revised 2019-8-6 By Henry Zhao */ #include LiquidCrystal lcd(8, 9, 4, 5, 6, 7); const int ACPin = A2; #define ACTectionRange 20; (5A,10A,20A) // select the pins used on the LCD panel //set arduino signal read pin //set Non-invasive AC Current Sensor tection range // VREF: Analog reference // For Arduino UNO, Leonardo and mega2560, etc. change VREF to 5 // For Arduino Zero, Due, MKR Family, ESP32, etc. 3V3 controllers, change VREF to 3.3 #define VREF 5.0 float readACCurrentValue() { float ACCurrtntValue = 0; float peakVoltage = 0; float voltageVirtualValue = 0; //Vrms for (int i = 0; i < 5; i++) { peakVoltage += analogRead(ACPin); //read peak voltage delay(1); } peakVoltage = peakVoltage / 5; voltageVirtualValue = peakVoltage * 0.707; //change the peak voltage to the Virtual Value of voltage /*The circuit is amplified by 2 times, so it is divided by 2.*/ voltageVirtualValue = (voltageVirtualValue / 1024 * VREF ) / 2; ACCurrtntValue = voltageVirtualValue * ACTectionRange; return ACCurrtntValue; } void setup() { Serial.begin(115200); lcd.begin(16, 2); pinMode(13, OUTPUT); // start the library } void loop() { lcd.setCursor(3, 0); float ACCurrentValue = readACCurrentValue(); //read AC Current Value // Serial.println(ACCurrentValue); lcd.print("AC CURRENT"); lcd.setCursor(5, 1); lcd.print(ACCurrentValue); lcd.print(" A"); digitalWrite(13, HIGH); delay(500); digitalWrite(13, LOW); delay(500); } Copy FAQ For any questions, advice or cool ideas to share, please visit the DFRobot Forum. More Documents • • Schematic Layout with dimension Gravity_Analog_AC_Current_Sensor__SKU_SEN0211_-DFRobot_9-9-21
SEN0211 价格&库存
很抱歉,暂时无法提供与“SEN0211”相匹配的价格&库存,您可以联系我们找货
SEN0211
  • 1+194.277921+25.25550
库存:7
