DFR0256
DFR0256
    DFROBOT
    MEGAMULTI-ARDUINOMEGAEXPANSI
DFR0256 数据手册
    Mega Multi‐Expansion shield SKU:DFR0256 Contents     1 Introduction 2 Specification 3 Pinout 4 Application Introduction Bothered with the conflict of I/O pins when using shields with the Mega board during a project? Find it hard to take good advantage of the mega I/O pins? Try the Mega I/O multi-expansion shield to help solving the problem. Mega I/O multi-expansion shield means that you can plug 4 different shields at same time. All I/O pins of the Mega board are expanded so that you can plug 4 shields at most, and worry not any more about the I/O conflict. Whatsmore, it makes your project clean & tidy with the cables be arranged in order . Expand your project idea with Mega I/O multi-expansion shield Specification    Compatible with Mega1280/2560/ADK Support 4 shields Size:14.4x13cm Pinout Pinout Application Here is some example for reference A drafting instrument or a 3D printer 1. 2. 3. 4. 5. A mega board (1280/2560/ADK) Dual Bipolar Stepper Motor Shield for Arduino (A4988) LCD12864 Shield for Arduino A Power Shield (Arduino Compatible) A mega multi-expansion shield A drafting instrument or a 3D printer A 4WD robotic platform 1. 2. 3. 4. 5. A mega board (1280/2560/ADK) 2A Motor Shield For Arduino x2 A Graphic LCD4884 Shield For Arduino A Xbee Shield For Arduino A mega multi-expansion shield A 4WD robotic platform A simple smart home care robot 1. 2. 3. 4. 5. 6. A mega board (1280/2560/ADK) A LCD Keypad Shield For Arduino DFRduino Ethernet Shield (Support Mega and Micro SD) A Relay Shield for Arduino A mega multi-expansion shield A light sensor and a humidity & temperature sensor A simple smart home care robot Powered By DFRobot © 2008-2017
DFR0256 价格&库存
很抱歉,暂时无法提供与“DFR0256”相匹配的价格&库存,您可以联系我们找货
