DEV-13033
DEV-13033
    SPARKFUNELECTRONICS
    LSM9DS0 Motion Sensor Intel Edison Platform Evaluation Expansion Board
DEV-13033 数据手册
Page 1 of 8   SparkFun Blocks for Intel® Edison - 9 Degrees of Freedom Block Introduction The 9 Degrees of Freedom Block for the Intel® Edison uses the LSM9DS0 9DOF IMU for full-range motion sensing. Use this Block to determine orientation, acceleration, and compass headings. The LSM9DS0 combines a 3-axis accelerometer, a 3-axis gyroscope, and a 3-axis magnetometer. The IMU is connected to the Edison through the I2C bus. 9 Degree of Freedom Block Suggested Reading If you are unfamiliar with Blocks, take a look at the General Guide to Sparkfun Blocks for Intel Edison. Other tutorials that may help you on your Edison adventure include: • Powering Your Project • Battery Technologies • Connector Basics Board Overview Page 2 of 8 The 9DOF Block has a lot of jumpers on it, but you can use it without understanding or changing any of them. Here’s a description of each one: A (INT2) - Accelerometer/magnetometer interrupt 2. This pin can be configured to change on a number of different conditions. See datasheet pp 58 and 65-67 for more details on configuring the device. Closing this jumper with a solder blob connects the INT2 pin on the LSM9DS0 to GPIO 49 on the Edison. B (INT1) - Accelerometer/magnetometer interrupt 1. This pin can be configured to change on a number of different conditions. See datasheet pp 58 and 63-65 for more details on configuring the device. Closing this jumper with a solder blob connects the INT2 pin on the LSM9DS0 to GPIO 48 on the Edison. C (DRDYG) - Data Ready, gyroscope. Closing this jumper connects the pin to GPIO 47. See datasheet page 43 for information on configuring this pin. D (INTG) - Gyroscope interrupt. This pin can be configured to change on a number of different conditions. Closing this jumper will connect the pin to GPIO 46. See datasheet pages 43 and 47-50 for information on configuring this pin. E (DEN) - Data enable, gyroscope. Enable or !pause data collection. This pin can safely be ignored. Closing this jumper allows processor control of data collection via GPIO 165. F (CLOCK/DATA) - I/O interface selection jumpers. Default setting is to I2C1 but cutting the small trace visible between the two upper pads of each jumper and closing the bottom two pads with a solder blob allow the user to route control to SPIDEV2. SPI is currently an unsupported feature and will likely be removed from a future revision. G (CSG) - SPI chip select, gyroscope. Closing this jumper connects the signal to GPIO 111 on the Edison, which is FS0 on SPIDEV2. The CS pin can be either handled manually or by the driver. SPI is currently an unsupported feature and will likely be removed from a future revision. H (CSXM) - SPI chip select, accelerometer/magnetometer. Closing this jumper connects the signal to GPIO 110 on the Edison, which is FS1 on SPIDEV2. The CS pin can be either handled manually or by the driver. SPI is currently an unsupported feature and will likely be removed from a future revision. I (SDOG) - SPI serial data out (MISO), gyroscope. SPI is currently an unsupported feature and will likely be removed from a future revision. J (SDOXM) - Serial data out (MISO), accelerometer/magnetometer. SPI is currently an unsupported feature and will likely be removed from a future revision. Page 3 of 8 K (I2C PUs) - Pull-up resistor removal for I2C SDA and SCL lines. Most likely, you won’t want to remove these resistors from the system; however, if you have a lot of devices on the I2C bus, you may need to remove some of the pull-ups from the lines to reduce the pull-up strength. L (CS PUs) - Pull-up resistor removal for SPI chip select lines. Normally pull-up resistors should be left in place. SPI is currently an unsupported feature and will likely be removed from a future revision. M (SDOG PU) - Closed by default, this pin sets the I2C address used by the gyroscope. When closed, the gyroscope’s address is 0x6b. When open, jumper SDOG PD (labeled ‘O’ above) must be closed. N (SDOXM PU) - Closed by default, this pin sets the I2C address used by the magnetometer/accelerometer. When closed, their collective address is 0x1d. When open, jumper SDOXM PD (labeled ‘P’ above) must be closed. O (SDOG PD) - Open by default, this pin sets the I2C address used by the gyroscope. When closed, the gyroscope’s address is 0x6a. P (SDOXM PD) - Open by default, this pin sets the I2C address used by the magnetometer/accelerometer. When closed, their collective address is 0x1e. Connecting the 9 DOF Block To use the 9 DOF Block simply attach an Intel Edison to the back of the board or add it to your current stack. Blocks can be stacked without hardware but it leaves the expansion connectors unprotected from mechanical stress. 9 DOF Block Installed We have a nice Hardware Pack available that gives enough hardware to secure three blocks and an Edison. Intel Edison Hardware Pack Page 4 of 8 NOTE: The 9 DOF Block does not have console access or a voltage regulator. It is recommended to use a console communication block in conjunction with this block like ones found in the General Guide to Sparkfun Blocks for Intel Edison. C++ Code Examples We’re assuming that you’re using the Eclipse IDE as detailed in our Beyond Arduino tutorial. If you aren’t, you’ll need to read over that tutorial to get up to speed. Getting Started Follow the instructions in the programming tutorial to create a new project named “SparkFun_9DOF_Edison_Block_Example”. Once you’ve created the project, open the project files on disk (hint: you can find the path to the project by choosing “Properites” from the project menu), and copy the three source files found in the Edison 9DOF Block CPP library GitHub repository into the “src” directory. D O W N L O A D A ZI P FIL E O F T H E RE P O S I T O R Y Code Everything you need to know is in the comments. Page 5 of 8 #include "mraa.hpp" #include #include #include "SFE_LSM9DS0.h" using namespace std; int main() { LSM9DS0 *imu; imu = new LSM9DS0(0x6B, 0x1D); // The begin() function sets up some basic parameters and tu rns the device // on; you may not need to do more than call it. It also re turns the "whoami" // registers from the chip. If all is good, the return valu e here should be // 0x49d4. Here are the initial settings from this functio n: // Gyro scale: 245 deg/sec max // Xl scale: 4g max // Mag scale: 2 Gauss max // Gyro sample rate: 95Hz // Xl sample rate: 100Hz // Mag sample rate: 100Hz // These can be changed either by calling appropriate functi ons or by // pasing parameters to the begin() function. There are nam ed constants in // the .h file for all scales and data rates; I won't repro duce them here. // Here's the list of fuctions to set the rates/scale: // setMagScale(mag_scale mScl) setMagODR(mag_odr mRat e) // setGyroScale(gyro_scale gScl) setGyroODR(gyro_odr gRa te) // setAccelScale(accel_scale aScl) setGyroODR(accel_odr aR ate) // If you want to make these changes at the point of callin g begin, here's // the prototype for that function showing the order to pas s things: // begin(gyro_scale gScl, accel_scale aScl, mag_scale mSc l, // gyro_odr gODR, accel_odr aODR, mag_odr mOD R) uint16_t imuResult = imu­>begin(); cout
DEV-13033 价格&库存
很抱歉,暂时无法提供与“DEV-13033”相匹配的价格&库存,您可以联系我们找货
