3.5 inches TFT Touchscreen for Raspberry Pi SKU: DFR0428
Contents
1 Introduction
2 Technical Specifications
3 Pin Descriptions
4 Using the LCD with your Raspberry Pi
4.1 Get Started
4.2 Restore Output to HDMI
Introduction
Looking for a small screen that is the same size as your Raspberry Pi? This 3.5" resistive touch
screen with 480 x 320 resolution will certainly meet your needs. If further combined with a wireless
keyboard, It will act as a fully functional computer that fits right in your pocket. Use it to run the Pi's
terminal, to play games, or to browse the web.
This item is more than just a screen, it is also a development friendly platform. It is seamlessly
compatible with DFRobot Gravity series modules making it easy to connect or even to debug your Pi
via the serial port! All the pins of Pi are left unoccupied, giving you more room to connect jumper
wires.
This Touchscreen is well designed for the Raspberry Pi 3, 2 or Model B+ (with 40 GPIO Pins).
Please note that it is not directly compatible with the old 26 pin GPIO Raspberry Pi.
Supports Raspian and Ubuntu systems, compatible with Raspberry Pi B+, Raspberry Pi 2 and the
latest Raspberry Pi 3. (any version with 40 GPIO pins)
Operating Voltage: 5V
Screen resolution: 480 x 320
Interface: SPI
GPIO Header Pins: 16
UART Header Pins: 1
Gravity I2C Pins: 1
Gravity UART Pins: 1
Gravity GPIO Pins: 1
Dimensions: 86 x 56 mm / 3.38" x 2.24"
Weight: 70g
Pin Descriptions
Raspberry Pi Pin Diagram
Rear View Display
↑ Raspberry Pi Pin "GPIO 2" corresponds to the LCD digital pins "2" ↑
Get Started
Download LCD drivers: LCD-show-160811.tar.gz
https://raw.githubusercontent.com/DFRobot/WikiResource/master/DFR0428/LCD-show160811.tar.gz
Copy LCD driver onto the USB disk.
Insert the USB disk into the USB host on your Raspberry Pi
Copy the LCD drivers into the Pi's filesystem, e.g /home/pi
Open a terminal and use the cd command to navigate to the directory where the driver is
e.g. if the directory is "/home/pi" then you need to use the command "cd /home/pi"
Unzip LCD-show.tar.gz:
tar -xvf LCD-show.tar.gz
Enter the LCD-show directory
cd /home/pi/LCD-show
ls
Install driver
suo ./LCD35-show
After you run the command, the system will automatically restart and switch to the LCD display.
cd /home/pi/LCD-show/
sudo ./LCD-hdmi
Note: When using the LCD display driver be sure to power off the system using software rather
than switching the power off abruptly to avoid damage to the LCD.
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“DFR0428”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+331.961421+43.15391
