MOTORplate
DEV-14149 RoHS
Description: The MOTORplate from Pi-Plates brings a suite of professional motion control features
to your Raspberry Pi. These plates can each control a combination of two stepper motors, four DC
motors or one stepper and two DC motors. An onboard microprocessor does all the hard work
including controlling acceleration trajectories and microstepping. By offloading these functions, your
Raspberry Pi is free to perform other tasks. Use this board to control a precision XY stage driven by
stepper motors. Or, drive the treads of your killer robot.
Pi-Plates are a family of stackable and interchangeable add-on circuit boards that allow you to
interact with the outside world using your Raspberry Pi. Every Pi-Plate is designed to provide a
robust set of features at minimal cost while using the fewest pins possible on the RPi header. PiPlates are mechanically and electrically compatible with all revisions of the Raspberry Pi with 40 pin
headers (including the Pi 3 Model B and Pi Zero) and are designed to satisfy the needs of hobbyists,
experimenters and professionals.
Features:
Can drive 2 stepper motors or 4 DC motors or a combination of the two
Output currents as high as 1.2 amps (avg) and 3.2 amps (peak)
Motor driving MOS transistors ensure cool and efficient operation
Auxiliary power inputs with selectors and reverse-voltage protection allow each motor controller
chip to be powered by either the:
o The Raspberry Pi 5VDC supply
o Dedicated power input (15V MAX)
Dedicated onboard processor
Calculates and provides real-time acceleration trajectories
Only needs two dedicated RPI pins (GPIO 25 and CE1)
Compatible with all versions of Raspberry Pi
Design allows up to eight MOTORplate boards to be stacked together for eight times the drive
capability: 16 stepper motors or 32 DC motors!
Uses less than 10mA of DC current during standby2
All inputs ESD and overvoltage protected
+5 and ground available on terminal blocks for powering hall effect sensors, optoisolators and
limit switches
Includes programmable LED
Compatible with ServoBlaster
https://www.sparkfun.com/products/14149 3/14/2017
很抱歉,暂时无法提供与“DEV-14149”相匹配的价格&库存,您可以联系我们找货
