Arduino LUCKY SHIELD
You are lucky with Arduino Lucky Shield! A single shield with
many sensors.
Arduino Lucky Shield is an easy way to use your Arduino boards, that grants you
access to barometric pressure, relative altitude, luminosity, temperature, motion and
presence. You can also turn it into a simple controller and OLED (organic lightemitting diode) display system. It is the perfect shield for IoT.
Description
Operating voltage: 3.3 VDC / 5 VDC
LEDs: POWER (Green) . LED1 (Yellow) . LED2 (Yellow)
Joystick: 5-directional tact switch
Buzzer: MINIMUM SPL 90 dBA RESONANT FREQUENCY 500 Hz
Relay: 50000 operations min (NC) at 250VAC, 8A (resistive load) 50000 operations
min at 30 VDC, 5A (resistive load)
PIR sensor: Encapsulation type TO5, Spectral response 7~14μm, Transmittance
≥77%, Field of view 139º
Ambient light sensor: Peak sensitivity wavelength 630nm , Operating temperature 40 ~ +85°C
Temperature / humidity: Operating temperature -40 ~ +85°C
Pressure sensor: Operating pressure range 300 ~ 1100 hPa
Magnetometer: E-compass, Full-scale range ±1000 T, Output data rates (ODR) up
to 80 Hz
Accelerometer: G-sensor, Ultra-fast data output time, ~700 μs ±8g full-scale range 3axis, 45° tilt outputs
Power
The shield doesn't need external power. It will be provided by the Arduino base
board, through the 5V and 3.3V pins of the base.
Physical Characteristics
The maximum length and width of the Lucky Shield PCB are 2.7 by 2.1
inches,respectively (68.6 x 53.4 mm). Four screw holes allow the Shield to be
attached to a surface or case. Note that the distance between digital pins 7 and 8 is
160 mil (0.16"), not an even multiple of the 100 mil spacing of the other pins.
Compatible Boards
The shield is compatible with all Arduino board 5V and 3.3V standards.
Overview
Arduino Lucky Shield is an easy way to use your Arduino boards, that grants you access to
barometric pressure, relative altitude, luminosity, temperature, motion and presence. You
can also turn it into a simple controller and OLED display system. It is the perfect shield for
IoT.
FEATURES
GENERAL
Relays
OMRON G6RL-1
(5V DC)
Operating
Voltage
3.3 V / 5 V
PIR Sensor
MOSDESIGN
M7616
Extra
DogOLED
support
Ambient Light
Sensor
EVERLIGHT ALSPT19315C/L177/TR8
PCB size
53 x 68.5 mm
Weight
0.054 Kg
Humidity
Sensor
BOSCH
SENSORTEC BME
280
Product Code
A000125
Temperature
Sensor
BOSCH
SENSORTEC BME
280
Pressure sensor
BOSCH
SENSORTEC BME
280
3-axis
magnetometer
NXP MAG3110
3 Axis
accelerometer
NXP MMA8491Q
Buzzer
PUI AUDIO SMT0927-S-6-R
Joystick
5-directional tact
switch
http://www.arduino.org/products/boards/arduino-lucky-shield
9/28/2016
很抱歉,暂时无法提供与“A000125”相匹配的价格&库存,您可以联系我们找货
