Blinkt! PIM184
Eight super-bright RGB LED indicators that are ideal for adding visual notifications to your
Raspberry Pi without breaking the bank!
Inspired by Alex Ellis' work with his Raspberry Pi Zero Docker Cluster, we developed these
boards for him to use as status indicators. Blinkt! offers eight APA102 pixels in the smallest (and
cheapest) form factor to plug straight onto your Raspberry Pi.
Each pixel on Blinkt! is individually controllable and dimmable allowing you to create gradients,
pulsing effects, or just flash them on and off like crazy. The data and clock lines are connected to
GPIO #23 and #24 respectively but for simplicity you can just use our Python library to drive
them.
Features
Eight APA102 RGB LEDs
Individually controllable pixels
Sits directly on top of your Pi in a tiny footprint
Fits inside most Pi cases
Doesn't interfere with PWM audio
Compatible with Raspberry Pi 3, 2, B+, A+, Zero, and Zero W
Python library
Comes fully assembled
Software
Our Blinkt! Python library will have you blasting out rainbows in two shakes of a unicorn's tail!
There's a stack of examples too, from binary clocks to cheerlights and flickering candles to
Larson scanners!
Notes
Be careful to plug in your Blinkt! the correct way round, it has curves on the top that match
the corners of your Raspberry Pi.
If you want to access the rest of the GPIO at the same time as using Blinkt! then our Mini Black
HAT Hack3r is the ideal accompaniment, allowing you to combine Blinkt! with another HAT or
pHAT, or just prototype using the GPIO pins for your own project.
The dimensions of Blinkt! are 65mm long x 8mm wide x 8.5mm thick (thickness includes header
and pixels).
We featured Blinkt! on a special episode of Bilge Tank where we tried to come up with as many
different code examples as possible in one morning. Check it out below.
https://shop.pimoroni.com/products/blinkt 4/19/2017
很抱歉,暂时无法提供与“PIM184”相匹配的价格&库存,您可以联系我们找货
