3386
3386
    ADAFRUIT
    RIVET SEMI-TUBE 0.218" BRASS
3386 数据手册
Adafruit PiRTC - PCF8523 Real Time Clock for Raspberry Pi PRODUCT ID: 3386  Description This is a great battery-backed real time clock (RTC) that allows your Raspberry Pi project to keep track of time if the power is lost. Perfect for data-logging, clock-building, time-stamping, timers and alarms, etc. Equipped with PCF8523 RTC, it works great with the Raspberry Pi and has native kernel support. Works perfectly with any Raspberry Pi (or similar single board linux computer) including the Pi 1, Pi 2, Pi 3, Pi Zero, A+, B+ etc. o o Fully assembled & tested PCB plugs directly into your Pi's GPIO pins ‐ No soldering  required!  Will keep time for 5 years or more  Note: This product does not come with a CR1220 coin cell battery. We recommend you purchase a coin cell battery to use with this product. The PCF8523 is simple and inexpensive but not a high precision device. It may lose or gain a second or two per day. For a high-precision, temperature compensated alternative, please check out the DS3231 precision RTC.  Technical Details Product Dimensions: 21.0mm x 20.0mm x 12.0mm / 0.8" x 0.8" x 0.5" Product Weight: 2.2g / 0.1oz        Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3386”相匹配的价格&库存,您可以联系我们找货
库存:620
