PIM013
PIM013
    PIMORONI
    PIGLOW
PIM013 数据手册
  PiGlow PIM013 The PiGlow is a small add on board for the Raspberry Pi that provides 18 individually controllable LEDs. You can use it for all sorts of things! And of course, it fits inside a Pibow! Works just fine with all models of Raspberry Pi including the B+! There are tons of things you can do with it:       Mood lighting / ambience Showing current system load Notify you of events like mentions in tweets or incoming e-mail Feedback the status of scripts/daemons running on your Pi Works great when VESA mounted to provide a cast against a wall ...and pretty much anything else you can think of! More detail This board uses the SN3218 8-bit 18-channel PWM chip to drive 18 surface mount LEDs. Communication is done via I2C over the GPIO header with a bus address of 0x54 (Python example code provided). Each LED can be set to a PWM value of between 0 and 255.      18 LEDs (three each of red, orange, yellow, green, blue, and white)  Great to provide feedback if you're running your Pi headless  PWM (dimming) control for each channel  Fully assembled (no soldering required)  Python code to access and control lighting provided        https://shop.pimoroni.com/products/piglow 4/17/2017
PIM013 价格&库存
很抱歉,暂时无法提供与“PIM013”相匹配的价格&库存,您可以联系我们找货
