Grove - LoRa Radio 868MHz
SKU 113060006
Using RFM95 module based on SX1276 LoRa®
Inputting voltage: 5V/3.3V
~28mA(Avg) @+20dBm continuous transmit
~8.4mA(Avg)@standby mode
~20mA(Avg) @receive mode, BW-500kHz
Description
Grove is a very powerful platform developed by Seeed Studio to simplify your IoT projects.We
have integrated the grove connector to most boards produced by Seeed to make them become a
system. This time, we combined Grove with LoRa to provide an ultra-long-range wireless
module for you.
The main functional module in Grove - LoRa Radio 868MHz is RFM95, which is a transceiver
features the LoRa long range modem that provides ultra-long range spread spectrum
communication and high interference immunity whilst mini-missing current consumption. The
heart of Grove - LoRa Radio 868MHz is ATmega168, a widely used chip with very highperformance and low power consumption, especially suitable for this grove module.
There we already integrated a simple wire antenna to receive signal, if the signal is too weak to
receive, don’t worry, the MHF connector next to the antenna is for adding a second antenna
which has MHF interface to gain more signal.
This is the 868MHz version, which can be used for 868MHz communication. You can also find
the version for 433MHz at Grove - LoRa Radio 433MHz.
Note:
Please keep the antenna vertical to the board and as straight as possible to make the best
performance.
Please avoid making any big metal object near the antenna and a metal cape is also not
recommended if you need to add a cape for your device.
Features
Working Temperature: -20 – 70Ԩ
Communication Interface: UART
Simple wire antenna or MHF Connector for external high gain antenna
Working Frequency: 868MHz
+20dBm - 100 mW Power Output Capability
Copyright © 2008-2016 Seeed Development Limited All rights reserved
Grove - LoRa Radio
Introduction
module for you.
The main functional module in Grove - LoRa Radio 433MHz is RFM98, which is a transceiver
heart of Grove - LoRa Radio 433MHz is ATmega168, a widely used chip with very highperformance and low power consumption, especially suitable for this grove module.
This is the 433MHz version, which can be used for 433MHz communication. You can also find
the version for 868MHz at Grove - LoRa Radio 868MHz.
Version
Released Date
Grove - LoRa Radio 433 MHz
Dec 10, 2016
Grove - LoRa Radio 868 MHz
Dec 10, 2016
Features
Working Voltage:5V/3.3V
Working Temperature:-20 – 70
Interface:Grove - UART(RX,TX,VCC,GND)
Working Frequency:868MHz/433MHz
+20dBm 100 mW Power Output Capability
Rate:0.3kps~50kps
Ready-to-go Arduino libraries
Resered MHF antenna connector
Tip
More details about Grove modules please refer to Grove System
Platforms Supported
Arduino
Wio
BeagleBone
Raspberry Pi LinkIt ONE
Caution
The platforms mentioned above as supported is/are an indication of the module's hardware or theoritical compatibility. We only provide
software library or code examples for Arduino platform in most cases. It is not possible to provide software library / demo code for all
possible MCU platforms. Hence, users have to write their own software library.
Hardware Overview
1.
2.
3.
4.
5.
ATMega168 MCU (datasheet)
MHF Connector
Wire Antenna
RFM95 Module (datesheet)
Grove Interface
NAME
PIN
FUNCTION
1
TX
TX of UART
2
RX
RX of UART
3
VCC
Power supply, 3.3V or 5V
NAME
PIN
4
GND
FUNCTION
Connect Ground
Application Ideas
Internet of Things
Smart Home
Sensor Hub
Long distance wireless communication
Getting Started
After this section, you can make Grove - LoRa Radio run with only few steps.
Preparations
Now we are making a demo for P2P(point to point) communication with the Grove - Lora Radio
433MHz, the Grove - LoRa Radio 868MHz is the same way to use.
Tip
Grove - LoRa Radio 433MHz can’t talk to Grove - LoRa Radio 868MHz.
Item
Qty
Link
Seeeduino Lotus
2
GET ONE NOW!
2
GET ONE NOW!
Micro USB Cable
2
GET ONE NOW!
If this is your first time using Seeeduino Lotus, please refer to Seeeduino Lotus’s wiki.
Seeeduino Lotus is fully compatible with Arduino which works as simple as Arduino.
If this is your first time using Arduino, Please put hand on here to start your Arduino journey.
Connecting hardware
Seeeduino Lotus is a combination of Seeeduino and Base Shield. We can connect the LoRa
Radio module to the D5 socket directly as the below picture shows.
Download Library
Click to download the library and install it (How to install an Arduino Library)
Open the example
Open your Arduino IDE, click File > Examples>Grove_LoRa_433MHz_and_915MHz_RFmaster you will get many examples for the module.
Node
Example Name
Function
Sender
rf95_client
Send “Hello World” every 1s
Receiver
rf95_server
Receive data and print it
Click Tools>Board to choose “Seeeduino Lotus” and select respective serial port then click on
Upload button to finish the steps.
Tip
If you’re using Grove - LoRa Radio 868MHz module change the following code.
//rf95.setFrequency(434.0);
rf95.setFrequency(868.0);
Review Results
After upload completed, you can open the serial monitor to see the result.
Data Rate
The below chart shows the relationships between the band rate signal band width spreding factor
and sensitivity.
Resources
Schematics
o
o
o
o
Grove - LoRa Radio 433MHz v1.0 Schematics (Eagle files)
Grove - LoRa Radio 433MHz v1.0 Schematics (PDF files)
Grove - LoRa Radio 868MHz v1.0 Schematics (Eagle files)
Grove - LoRa Radio 868MHz v1.0 Schematics (PDF files)
Datasheet
o
o
RFM95/96/97 Datasheet
Atmega168 Datasheet
References
o
LoRa Alliance
Library
o
Grove - LoRa Radio Library and Examples
Download ALL Above
Help us make it better
Thank you for choosing Seeed. A couple of months ago we initiated a project to improve our
documentation system. What you are looking at now is the first edition of the new
documentation system. Comparing to the old one, here is the progresses that we made:
Replaced the old documentation system with a new one that was developed from Mkdocs, a
more widely used and cooler tool to develop documentation system.
Integrated the documentation system with our official website, now you can go to Bazaar and
other section like Forum and Community more conveniently.
Reviewed and rewrote documents for hundreds of products for the system’s first edition, and will
continue migrate documents from old wiki to the new one.
An easy-to-use instruction is as important as the product itself. We are expecting this new system
will improve your experience when using Seeed’s products. However since this is the first
edition, there are still many things need to improve, if you have any suggestions or findings, you
are most welcome to submit the amended version as our contributor or give us suggestions in the
survey below, Please don’t forget to leave your email address so that we can reply.
Happy hacking
很抱歉,暂时无法提供与“113060006”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+175.162911+22.64167
