PPMB00100
PPMB00100
    PIMORONI
    MICRO:PIXEL4X8WS2812BBOARDFO
PPMB00100 数据手册
  micro:pixel 4x8 WS2812B board for BBC micro:bit PPMB00100 Love your micro:bit but wish it had a splash of colour? Well, with this nifty add-on you have 32 individually controllable RGB WS2812B (NeoPixel) LEDs in a well proportioned 4x8 grid. The WS2812B LEDs are also known as NeoPixels, which is Adafruits Trademark name for them. As such, they use the NeoPixel library in TouchDevelop etc. The micro:pixel comes fully assembled with an edge connector, simply plug your micro:bit in and get coding! We have a link in the Example Code Section to the code we have been using to play with them! By default the micro:pixel uses Pin0 as the LED data pin as this is the default value for the touch develop neopixel library. If you wish to use another pin in Micropython or Java then we have designed in a handy solder jumper on the board, simply cut the thin track using a craft knife and solder between the other pads this will enable pin 8 as the data pin for the LEDs and free up pin 0. WARNING: These little WS2812B Neopixel fellas can get VERY bright so we recommend running at a low brightness ONLY (we recommend 1/8th which is 32 out of 255 in your code). If you run the micro:pixel board at brightnesses higher than this, then you may well damage your micro:bit board as the pixels will try to pull more power than the micro:bit itself can handle. The micro:pixel board also has the micro:bits pins 0, 1 and 2 broken out along with 3v and ground which can accommodate a banana plug or croc clip Please note that at the time of publishing the microsoft block editor doesn't have a neopixel library, touch develop, code kingdoms JavaScript and Micropython however do. Please note, micro:bit is not included. Example code (Right click save as):     Touch develop  https://www.proto‐pic.co.uk/user/products/large/microbit‐ micropixelrainbow%20test.hex  JavaScript (coming soon)  Micropython ‐ Flame  https://www.proto‐pic.co.uk/user/RealisticFlame.hex  Micropython ‐ Disco Flame  https://www.proto‐pic.co.uk/user/SpookyColours.hex                                             https://shop.pimoroni.com/products/micro‐pixel‐4x8‐neopixel‐board‐for‐bbc‐micro‐bit 4/17/2017
PPMB00100
物料型号:PPMB00100 器件简介:micro:pixel 是一款为 BBC micro:bit 设计的扩展板,具有 4x8 网格排列的 32 个可单独控制的 RGB WS2812B (NeoPixel) LED。
引脚分配:micro:pixel 默认使用 Pin0 作为 LED 数据引脚,但设计了一个焊接跳线,允许用户通过切断细线并焊接到其他焊盘来使用 Pin8 作为数据引脚。
参数特性:WS2812B LED 非常亮,建议仅以低亮度运行(推荐在代码中设置为 1/8,即 32/255)以避免损坏 micro:bit 主板。
功能详解:micro:pixel 完全组装好,带有边缘连接器,用户只需插入 micro:bit 即可开始编程。
提供了示例代码链接。
应用信息:micro:pixel 扩展板适用于需要为 micro:bit 添加彩色显示的项目。
封装信息:micro:pixel 板还扩展了 micro:bit 的引脚 0、1 和 2,以及 3V 和地线,可以适配香蕉插头或鳄鱼夹。
请注意,micro:bit 主板不包含在内,且在发布时微软的块编辑器没有 NeoPixel 库,但 Touch Develop、Code Kingdoms JavaScript 和 Micropython 支持。
PPMB00100 价格&库存
很抱歉,暂时无法提供与“PPMB00100”相匹配的价格&库存,您可以联系我们找货
