MIKROE-2273
MIKROE-2273
    MIKRO
    THERMOSTATCLICK
MIKROE-2273 数据手册
Thermostat click PID: MIKROE-2273 Weight: 30 g Condition: New product Thermostat click carries the MAX7502 IC digital temperature sensor, that also provides an overtemperature alarm/interrupt/shutdown output, and an SN74LVC1G126 single bus buffer from Texas Instruments. MAX7502 IC can measure temperatures from -25°C to +100°C, within the accuracy of ±1.5°C. The G6D PCB power relay can control up to 5A, 250V AC/30V DC loads.   Table of contents 1. 2. 3. 4. 5. 6. Temperature range  MAX7502 temperature sensor  Low power consumption  Enable/disable thermostat functionality  Application  Key features  If you need a temperature sensor and relay in one device, you should look no further than Thermostat click. It can be used to measure environmental temperature and to directly switch ON/OFF cooling and heating devices, performing all the functions of a thermostat. Thermostat click carries the MAX7502 IC digital temperature sensor, that also provides an overtemperature alarm/interrupt/shutdown output, and an SN74LVC1G126 single bus buffer from Texas Instruments. MAX7502 IC can measure temperatures from -25°C to +100°C, within the accuracy of ±1.5°C. The G6D PCB power relay can control up to 5A, 250V AC/30V DC loads. The click runs on either 3.3V or 5V power supply and communicates with the target MCU over I2C interface. Temperature range The IC can measure temperatures from -25°C to +100°C, within the accuracy of ±1.5°C. MAX7502 temperature sensor MAX7502 temperature sensor measures temperature, converts the data into digital form using a sigma-delta ADC, and communicates the conversion results through an I2C-compatible 2-wire serial interface. It accepts standard I2C commands to read the data, set the overtemperature alarm trip thresholds, and configure other characteristics. Low power consumption The MAX7502 temperature sensor typically uses only around 250 µA, and in shutdown mode around 3 µA. With such low power consumption, it is very suitable for home automation devices. Enable/disable thermostat functionality There is also the TE (thermostat enable) pin on the mikroBUS™ pin socket for enabling (high level) or disabling (low) of the thermostat functionality. This is accomplished via the SN74LVC1G126 single bus buffer with 3-state output IC, which serves as an electronic switch between temperature sensor IC output pin and the relay driver circuit. This way the relay can be permanently disconnected from the sensor IC output. A feature like this can be useful when the sensor IC is only used as an measuring device, or if the thermostat needs to be temporarily disabled. Application HVAC systems, heating systems, cooling systems, simple interrupt ON/OFF temp control, hysteresis controller, etc. Key features      MAX7502 temperature sensor   o ±1.5°C (max) temperature accuracy  o 3µA (typ) shutdown supply current  o Overtemperature alarm output  SN74LVC1G126 single bus buffer   o Designed for 1.65‐V to 3.6‐V VCC operation  o Low Power Consumption, 10‐μA Max ICC  Onboard screw terminal  I2C interface  Either 3.3V or 5V power supply  SPECIFICATION  Product Type Temperature / Humidity HVAC systems, heating systems, cooling systems, simple interrupt ON/OFF Applications temp control, hysteresis controller, etc. On-board modules MAX7502 IC digital temperature sensor MAX7502 temperature sensor, SN74LVC1G126 single bus buffer, G6D PCB Key Features power relay, I2C interface, either 3.3V or 5V power supply, Temperature sensor and relay in one device, it can measure environmental Key Benefits temperature and directly switch ON/OFF cooling and heating devices Interface I2C Power Supply 3.3V or 5V Compatibility mikroBUS Click board size L (57.15 x 25.4 mm)           Pinout diagram This table shows how the pinout on Thermostat click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes    Pin  Pin Notes  mikroBUStm  Not connected  NC  1 AN  PWM 16 NC Not connected  Hardware Reset for MAX7502   RST#  2 RST INT  15 NC Not connected  Thermostat enable  TE  3 CS  TX  14 NC Not connected  Not connected  NC  4 SCK RX  13 NC Not connected  Not connected  NC  5 MISO SCL  12 SCL Serial Data Input/Output Line  Not connected  NC  6 MOSI SDA 11 SDA Serial Data Clock Input  Power supply  +3.3V  7 +3.3V Ground  GND  8 GND +5V 10 +5V Power supply  GND 9 GND Ground  Programming This code snipped for EasyMx PRO v7 for STM32F107VC MCU initializes the temperature sensor by writing into its registers and, then it reads the temperature in an endless loop. If the measured temperature gets below the hysteresis temperature, the output relay is ON. The sensor is configured for heating, without fault queue bits, when OS output is active low, with comparator logic and in normal operation. 1 // Main program 2 void main() 3 { 4 //*************************************************************************** 5 // MAX7502 temperature controller IC 6 7 // MAX7502 Initialization 8 TEMP = 0; // Thermostat function disabled - Output Relay disconnected 9 TRES = 0; // Apply Reset procedure 10 delay_ms(150); 11 TRES = 1; // Temperature controller is in default state and ready for work 12 13 // MAX7502 Configuration 14 Set_CONFIG(0); // Set parameters in configuration register 15 // refer to MAX7502 datasheet and click board schematic in order to 16 // set right parameters for intended application: 17 // e.g. set OS output pin polarity for using the chip sensor in 18 // processes of Heating (bit1=0) or Cooling (bit1=1) 19 // or set the output function of the same pin to be Comparator (bit2=0) 20 // or Interrupt logic (bit2=1) in order to use the sensor for hysterezis 21 // temp ON/OFF control (real process) or trivial ON/OFF control 22 // In this example the chip is configured for heating 23 Set_TEMP_REF(REF_TEMP); // Set referent temperature T = 22 C (Output relay is ON until the environment 24 // temperature has reach that value) 25 Set_TEMP_HYST(HYST_TEMP); // Output Relay is OFF until the temperature falls below HYST value 26 27 TEMP = 1; // Thermostat enabled - Output Relay connected to OS output pin of MAX7502 28 29 //*************************************************************************** 30 31 current_temp = REF_TEMP; 32 old_MSB = 0; 33 temp_MSB = 0; 34 temp_changed = false; 35 36 //*************************************************************************** 37 // Temperature read loop - temperature controlling process 38 while (1) 39 { 40 Temp_read(); // Read 9-bit temperature value from MAX7502's register space 41 delay_ms(200); // +-0.5 C fraction neglected in this example 42 } 43 //*************************************************************************** 44 } Jumpers and settings The table below gives information about the onboard jumpers. Designator  Name  JP1  Default  Default  Description  Position  Option  PWR.SEL.  Left  3.3V  Power Supply Voltage Selection 3.3V/5V, left position 3.3V,  right position 5V  LEDs, buttons and switches The following table gives information about onboard LEDs, buttons and switches. Designator  Name  LD1  Type (LED,  BUTTON…)  Description  PWR  Power LED    CN1    2‐pole PCB  terminal block  5.08mm  For output device connection (heater/fan…)                                                          Copyright © 1998 ‐ 2017. MikroElektronika d.o.o.
MIKROE-2273 价格&库存
很抱歉,暂时无法提供与“MIKROE-2273”相匹配的价格&库存,您可以联系我们找货
