3231
3231
    ADAFRUIT
    BOX ALUM BLUE 2.25"L X 1.38"W
3231 数据手册
Adafruit LoRa Radio FeatherWing - RFM95W 900 MHz PRODUCT ID: 3231 Description Add short-hop wireless to your Feather with these Radio Featherwings. These add-ons for any Feather board will let you integrate packetized radio (with the RFM69 radio) or LoRa radio (with the RFM9x's). These radios are good options for kilometer-range radio, and paired with one of our WiFi, cellular or Bluetooth Feathers, will let you bridge from 433/900 MHz to the Internet or \RXUPRELOHGHYLFH 7KHVHUDGLRPRGXOHVFRPHLQ¬IRXUYDULDQWV¬ WZRPRGXODWLRQW\SHVDQGWZRIUHTXHQFLHV 7KH RFM69's are easiest to work with, and are well known and understood. The LoRa radios are H[FLWLQJORQJHUUDQJHDQGPRUHSRZHUIXOEXWDOVRPRUHH[SHQVLYH RFM69 @ 433 MHz - basic packetized FSK/GFSK/MSK/GMSK/OOK radio at 433 MHz for use in Europe ITU 1 license-free ISM, or for amateur use with restrictions (check your local amateur regulations!) RFM69 @ 900 MHz - basic packetized FSK/GFSK/MSK/GMSK/OOK radio at 868 or 915 MHz for use in Americas ITU 2 license-free ISM, or for amateur use with restrictions (check your amateur regulations!) RFM98 @ 433 MHz - LoRa capable radio at 433 MHz for use in Europe ITU 1 license-free ISM, or for amateur use with restrictions (check your local amateur regulations!) RFM95 @ 900 MHz - LoRa capable radio at 868 or 915 MHz for use in Americas ITU 2 license-free ISM, or for amateur use with restrictions (check your local amateur regulations!) 7KLVLVWKH/R5D[#0+]UDGLRYHUVLRQZKLFKFDQEHXVHGIRUHLWKHU0+]RU0+] transmission/reception -WKHH[DFWUDGLRIUHTXHQF\LVGHWHUPLQHGZKHQ\RXORDGWKHVRIWZDUH VLQFHLWFDQEHWXQHGDURXQGG\QDPLFDOO\7KHVHDUHG%P/R5DSDFNHWUDGLRVWKDWKDYHD VSHFLDOUDGLRPRGXODWLRQWKDWLVQRWFRPSDWLEOHZLWKWKH5)0V¬EXW¬FDQJRPXFKPXFK¬IDUWKHU They can easily go 2 Km line of sight using simple wire antennas, or up to 20Km with directional antennas and settings tweakings 6;[/R5DЬEDVHGPRGXOHZLWK63,LQWHUIDFH Packet radio with ready-to-go Arduino libraries Uses the license-free ISM bands +5 to +20 dBm up to 100 mW Power Output Capability (power output selectable in software) aX$GXULQJIXOOVOHHSaP$SHDNGXULQJG%PWUDQVPLWaP$GXULQJDFWLYHUDGLR listening. Our initial tests with default library settings: over 1.2mi/2Km line-of-sight with wire quarter-wave antennas. (With setting tweaking and directional antennas, 20Km is possible). Currently tested to work with the )HDWKHU(63, Teensy 3 Feather, Feather 32u4 and Feather M0 VHULHVVRPHZLULQJLVUHTXLUHGWRFRQILJXUHWKH)HDWKHU:LQJIRUWKHFKLSVHW\RXSODQWRXVH $OOUDGLRVDUHVROGLQGLYLGXDOO\DQGFDQRQO\WDONWRUDGLRVRIWKHVDPHSDUWQXPEHU(J5)0 900 MHz can only talk to RFM69 900 MHz, LoRa 433 MHz can only talk to LoRa 433, etc. (DFKUDGLR :LQJFRPHVZLWKVRPHKHDGHU6RPHVROGHULQJLVUHTXLUHGWRDWWDFKWKHKHDGHU
很抱歉,暂时无法提供与“3231”相匹配的价格&库存,您可以联系我们找货
