MIKROE-2102
MIKROE-2102
    MIKRO
    H3LIS331DL Accelerometer Sensor mikroBUS™ Click™ Platform Evaluation Expansion Board
MIKROE-2102 数据手册
Page 1 of 2 Accel 3 click From MikroElektonika Documentation Revision as of 17:28, 26 May 2016 by Srdjan.misic (talk | contribs) (diff) ← Older revision | Latest revision (diff) | Newer revision → (diff) Accel 3 click Accel 3 click IC/Module H3LIS331DL (http://www.st.com/content/ccc/resource/technical/document/datasheet/3e/48/02/c7/a4/e6/41/bb/DM00053090.pdf/files/DM00053090.pdf/jcr:content/translations/en.DM00053090.pdf) Interface SPI (CS, SCK, MISO, MOSI), I2C (SCL, SDA), INT Power 3.3V supply Website www.mikroe.com/click/accel3 (http://www.mikroe.com/click/accel3) Accel 3 click carries ST’s H3LIS331DL low-power high-g 3-axis digital accelerometer. The IC has ±100g/±200g/±400g dynamically selectable full scales and outputs 16-bit data at rates from 0.5 Hz to 1 kHz. On the upper end, the chip can survive a 1000g high-shock. H3LIS331DL has extremely low power consumption (down to 1µA in lowpower mode). Advanced sleep-to-wakeup functions are also available. Accel 3 click can communicate with the target MCU either through the mikroBUS™ SPI or UART interface, with additional functionality provided by an interrupt pin (INT). The board is designed to use a 3.3 power supply only. Features and usage notes Accel 3 click has three groups of jumpers (zero ohm resistors) onboard: - The four jumpers on the left side of the board are for choosing between the SPI or I2C interface for the sensor output. By default, these are soldered into the I2C position. On the right side of the board, the upper jumper is for specifying which of the two interrupt pins on H3LIS331DL will be connected to the mikroBUS™ pin. - The final jumper is for configuring the I2C address The I2C interface is compliant with both normal and fast modes (400 KHz), both common I2C standards. H3LIS331DL incorporates a sleep-to-wakeup function. In sleep mode the sensor is in a low-power operating mode; it continues to detect acceleration and generate interrupt requests, but with lower data rate refreshments. Once an interrupt threshold is sensed, the device automatically wakes up and increases the output data rate and bandwidth. Schematic also available in PDF (http://cdndocs.mikroe.com/images/4/47/Accel_3_click_schema 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 Programming This snippet reads three axes' from the accelerometer every 30 milliseconds and displays them to UART. The values displayed have been calibrated and are measured in gs. #include #include "accel3.h" sbit ACCEL_3_CS at GPIOD_ODR.B13; sbit ACCEL_3_INT at GPIOD_IDR.B10; void main() { uint8_t address = 0x18; xyz_t* my_coords; //I2C I2C1_Init_Advanced( 100000, &_GPIO_MODULE_I2C1_PB67 ); Delay_ms(200); //Accel 3 Initialization accel3_init( address, accel_mode, d_rate, mode ); while(1) { my_coords = accel3_get_xyz(); sprintf( text, " x: %d y: %d z: %d ", my_coords->x_pos, my_coords->y_pos, my_coords->z_pos ); Page 2 of 2 24 25 26 } 27 28 29 } UART1_Write_Text( text ); UART1_Write_Text( "\r\n" ); Delay_ms(30); Code examples that demonstrate the usage of Accel 3 click with MikroElektronika hardware, written for mikroC for ARM, AVR, dsPIC, FT90x, PIC and PIC32 are available on Libstock (http://libstock.mikroe.com/projects/view/1795/accel-3-click). Resources - Accel 3 click code examples on Libstock (http://www.libstock.com) - Accel 3 click related tutorial on learn.mikroe.com (http://learn.mikroe.com/mems-sensors-conversion-physical-world-digital-world/) - H3LIS331DL vendor’s data sheet (http://www.st.com/content/ccc/resource/technical/document/datasheet/3e/48/02/c7/a4/e6/41/bb/DM00053090.pdf/files/DM00053090.pdf/jcr:content/translations/en.DM00053 Retrieved from "http://docs.mikroe.com/index.php?title=Accel_3_click&oldid=347" ◾ This page was last modified on 26 May 2016, at 17:28. ◾ Content is available under Creative Commons Attribution unless otherwise noted. http://docs.mikroe.com/index.php?title=Accel_3_click&oldid=347&printable=yes 6/15/2016
MIKROE-2102
物料型号:H3LIS331DL,由意法半导体(ST)生产,是一款低功耗、高g值、3轴数字加速度传感器。
器件简介:Accel 3 click模块搭载了H3LIS331DL,能够动态选择±100g/±200g/±400g的全量程,并以16位数据输出,数据更新率从0.5 Hz到1 kHz。该芯片在高端可以承受1000g的高冲击,并且具有极低的功耗(在低功耗模式下低至1µA)。此外,还具备高级的睡眠到唤醒功能。
引脚分配:模块支持SPI (CS, SCK, MISO, MOSI)和I2C (SCL, SDA)两种通信接口,以及中断引脚(INT)。
参数特性:Accel 3 click设计为仅使用3.3V电源供电。I2C接口兼容正常模式和快速模式(400 KHz),均为常见的I2C标准。在睡眠模式下,传感器以低功耗运行,继续检测加速度并生成中断请求,但数据刷新率较低。一旦检测到中断阈值,设备自动唤醒并提高输出数据率和带宽。
功能详解:模块板上有三组跳线(零欧姆电阻),用于选择传感器输出的SPI或I2C接口、指定H3LIS331DL的两个中断引脚中的哪一个连接到mikroBUS™引脚,以及配置I2C地址。
应用信息:模块可与目标微控制器通过mikroBUS™ SPI或UART接口进行通信,并通过中断引脚(INT)提供额外功能。
封装信息:文档提供了模块的原理图,并指出模块仅设计为使用3.3V电源供电。
MIKROE-2102 价格&库存
很抱歉,暂时无法提供与“MIKROE-2102”相匹配的价格&库存,您可以联系我们找货
MIKROE-2102
  • 1+220.717401+28.55317
MIKROE-2102
  • 1+220.61714
  • 5+216.20167
库存:8
