MIKROE-1996
MIKROE-1996
    MIKRO
    9DOF CLICK
MIKROE-1996 数据手册
2. Soldering the headers Before using your click™ board, make sure to solder 1x8 male headers to both left and right side of the board. Two 1x8 male headers are included with the board in the package. MPU 9DOF click 1 4. Essential features ™ 2 3 Turn the board upside down so that the bottom side is facing you upwards. Place shorter pins of the header into the appropriate soldering pads. Turn the board upward again. Make sure to align the headers so that they are perpendicular to the board, then solder the pins carefully. 1. Introduction MPU 9DOF click™ carries the MPU–9150 SiP (System in Package), which is the world’s first 9-axis MotionTracking device. The device comprises two chips: one is the MPU–6050 that contains a 3-axis accelerometer, a 3-axis gyroscope, and a DMP (digital motion processor); the other is AK8975, a 3-axis digital compass. MPU 9DOF click™ communicates with the target board through mikroBUS™ I2C (SCL, SDA), INT and RST (FSYNC) lines. It’s designed to use a 3.3V power supply only. 3. Plugging the board in Once you have soldered the headers your board is ready to be placed into the desired mikroBUS™ socket. Make sure to align the cut in the lower-right part of the board with the markings on the silkscreen at the mikroBUS™ socket. If all the pins are aligned correctly, push the board all the way into the socket. The MPU–9150 aboard MPU 9DOF click™ is designed for the low power, low cost and high performance requirements of consumer electronics equipment and wearable sensors. The ability to track motion in free space also makes MPU 9DOF click™ a suitable sensor when designing remote controlled quadcopters. The Tri-Axis gyro has a sensitivity up to 131 LSBs/dps and a full-scale range of ±250, ±500, ±1000, and ±2000dps; the Tri-Axis accelerometer with a programmable full scale range of ±2g, ±4g, ±8g and ±16g; and the tri-axis compass has a full scale range of ±1200µT. click ™ BOARD www.mikroe.com MPU 9DOF click™ manaul ver. 1.00 0 100000 027325 5. MPU 9DOF click™ board schematic 6. Zero-Ohm jumpers VCC3.3 REGOUT R1 2K2 LD1 VCC3.3 C2 100nF MPU 9DOF click™ has two jumpers (zero-Ohm resistors). FSYNC enables or disables the interrupt function on the FSYNC (RST) mikroBUS™ pin. I2C ADD allows you to select between the available I2C addresses. VCC3.3 C3 100nF C4 10uF C1 VCC3.3 CLKIN NC VDD MPU-9150 NC NC AUX_DA SA0 REGOUT FSYNC INT 7 8 9 10 11 12 AUX_CL VLOGIC AD0/SDO REGOUT FSYNC INT 1 2 3 4 5 6 VCC3.3 VCC3.3 Once you have done all the necessary preparations, it’s time to get your click™ board up and running. We have provided examples for mikroC™, mikroBasic™ and mikroPascal™ compilers on our Libstock website. Just download them and you are ready to start. 2.2nF U1 R3 4K7 SDA SCL NC NC CPOUT NC 24 23 22 21 20 19 SDA SCL 7. Code examples VCC3.3 GND GND NC GND NC VDD 18 17 16 15 14 13 FSY AN RST CS SCK MISO MOSI +3.3V GND PWM INT TX RX SCL SDA +5V GND MIKROBUS DEVICE CONN. R2 R4 4K7 INT SCL SDA FSY FSYNC FSY EN/DIS J1A .com VCC3.3 SA0 ADDR SEL 100K 8. Support J2A MikroElektronika assumes no responsibility or liability for any errors or inaccuracies that may appear in the present document. Specification and information contained in the present schematic are subject to change at any time without notice. Copyright © 2014 MikroElektronika. All rights reserved. MikroElektronika offers free tech support (www.mikroe.com/support) until the end of the product’s lifetime, so if something goes wrong, we’re ready and willing to help!
MIKROE-1996 价格&库存
很抱歉,暂时无法提供与“MIKROE-1996”相匹配的价格&库存,您可以联系我们找货
