114990253
114990253
    SEEED(矽递科技)
    TXB0108 Translator Interface Photon Platform Evaluation Expansion Board
114990253 数据手册
Arduino Shield for Photon SKU: 114990253 Description Sometimes life can be a little difficult in the land of electronics when two systems talk a different voltage language. How do you make them talk to each other without making one of them burn out? The Shield Shield is the answer. This shield performs all the necessary voltage translation and provides an Arduinocompatible footprint to make it easier for you to plug in your existing Arduino shields or talk to other 5V hardware. The shield converts the pin mapping of the Photon to Arduino pin layout and provides a voltage translation of 3.3V to/from 5V. It use Texas Instruments TXB0108PWR to do the voltage translation in between the Particle's device's 3.3V to a 5V logic. Unlike other IO pins, the analog pins are rated at only a max of 3.3V and NOT 5.0V. Please remember NOT to exceed this voltage at anytime. The shield has an on-board voltage regulator and can be powered from 7V to 15V DC source. You could also power it via the USB plug on the Particle device alone but the current would be limited to 500mA. Specifications Operating voltage: 7 to 15V DC Current consumption: standalone 7mA at 9V DC Voltage translator with auto direction detect: TXB0108PWR Dedicated MOSFET based voltage translator on I2C lines Separate unidirectional quad buffer for driving heavy loads: 74ACT125 Diode protection on ADC pins Dimensions: 3.4” x 2.1” Part List: • 1 x Arduino shield for Photon Copyright © 2008-2015 Seeed Technology Co., Ltd All rights reserved.
114990253 价格&库存
很抱歉,暂时无法提供与“114990253”相匹配的价格&库存,您可以联系我们找货
