VREG click
1
VREG click
VReg click
VReg click
IC/Module
LM317
[1]
MCP4921 12-bit DAC
MCP3204 12-bit ADC
[2]
[3]
ZXMP7A17K MOSFET
[3]
LMx58
Interface
Power supply
Website
[4]
SPI
3.3V, 5V
www.mikroe.com/click/vreg
[5]
VREG click is a digitally controlled DC Voltage regulator in mikroBUS™ form factor. The design is based on the
well-known LM317 circuit, with the addition of a 12-bit DAC, 12-bit ADC, and an Operational Amplifier. Two pairs
of screw terminals serve as inputs and outputs.
Features and usage notes
The LM371 IC is a reliable regulator with typical line regulation of
0.01% and load regulation of 0.1%. It also has internal short-circuit
current limiting and thermal overload protection.
The circuit regulates voltage by turning all input/output difference into
heat (effectively dissipating all the excess power). If it gets too hot it
may damage the board or cause unexpected behaviour.
Schematic also available in PDF
[6]
Because of that, the board’s operating range is defined by two factors.
1) maximum input voltage and current (should not exceed 20V/1A);
and 2) maximum wattage arising from current and I/O voltage
difference (should not exceed 2W, measured as I x (Input V - Output
V).
The board also carries a MOSFET chip to toggle the output on and off.
VREG click
2
VREG click communicates with the target board MCU through the SPI interface (CS, SCK, MISO, MOSI). The
board can use either a 3.3V or a 5V power supply.
It is also possible to use the board’s power supply as the Input, by resoldering the onboard INPUT SEL jumper.
Programming
This code checks if the output value is equal to the desired set_value. If it is not, it sets the desired value and sends it
to the DAC of the VREG click, which then sets the output voltage to the desired value.
while(1)
if(output < set_value)
value = value + 1;
if(value>4095) {value = 4095;}
if(output > set_value)
value = value - 1;
if(value
很抱歉,暂时无法提供与“MIKROE-2443”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+198.40443
- 5+190.46908
