MIKROE-2264
MIKROE-2264
    MIKRO
    AK8963 Compass Sensor mikroBUS™ Click™ Platform Evaluation Expansion Board
MIKROE-2264 数据手册
Page 1 of 3 Compass 2 click From MikroElektonika Documentation Revision as of 16:23, 24 June 2016 by Srdjan.misic (talk | contribs) (diff) ← Older revision | Latest revision (diff) | Newer revision → (diff) Compass 2 click carries an AK8963 3-axis electronic compass. The high sensitivity sensor is based on the Hall effect. The built-in ADC converter can be set up at either 14 or 16 bit resolution, for each of the 3 axes. The sensitivity is 0.6µT/LSB typ. at 14-bit, and 0.15µT/LSB at 16-bit. Compass 2 click communicates with the target MCU through either through the I2C or SPI interface, with an added INT pin. Onboard jumpers enable you to switch between two interfaces. The board is designed to use a 3.3 power supply only. Compass 2 click Features and usage notes The AK8964 has several operating modes which can be configured by setting a specific register (CNTL1) to certain values. The following is a list of available operating modes with partial descriptions (to give you an overview). The configuration details are available on page 13 of the official data sheet, while the complete descriptions (1) Power-down mode Schematic also available in PDF (http://cdndocs.mikroe.com/images/1/1a/Compass_2_click_sche Power to almost all internal circuits is turned off. All registers are accessible in power-down mode. However, fuse ROM data cannot be read correctly. Data stored in read/write registers are remained. They can be reset by soft reset. (2) Single measurement mode When single measurement mode (MODE[3:0]=“0001”) is set, sensor is measured, and after sensor measurement and signal processing is finished, measurement data is stored to measurement data registers (HXL to HZH), then AK8963 transits to power-down mode automatically. Compass 2 click IC/Module AK8963 (http://www.akm.com/akm/en/product/datasheet1/? partno=AK8963) Interface SPI, I2C, INT Power 3.3V supply Website www.mikroe.com/click/compass-2 (http://www.mikroe.com/click/compass-2) (3) Continuous measurement mode 1 and 2 When continuous measurement mode 1 (MODE[3:0]=“0010”) or 2 (MODE[3:0]=“0110”) is set, sensor is measured periodically at 8Hz or 100Hz respectively. When sensor measurement and signal processing is finished, measurement data is stored to measurement data registers (HXL ~ HZH) and all circuits except for the minimum circuit required for counting cycle lentgh are turned off (PD). (4) External trigger measurement mode When external trigger measurement mode (MODE[3:0]=“0100”) is set, AK8963 waits for trigger input. When a pulse is input from TRG pin, sensor measurement is started on the rising edge of TRG pin. When sensor measurement and signal processing is finished, measurement data is stored to measurement data registers (HXL to HZH) and all circuits except for the minimum circuit required for trigger input waiting are turned off (PD state). (5) Fuse ROM access mode Fuse ROM access mode is used to read Fuse ROM data. Sensitivity adjustments for each axis is stored in fuse ROM. Compass 2 click has both SPI and I2C interfaces. The active interface is configured with onboard jumpers. If you use I2C, an additional jumper will allow you to set the I2C address. Programming This code snippet initiates Compass 2 with I2C communication, and reads out the heading value, along with a direction, ( N, NE, E, etc ) from the module to a UART terminal every 100 ms. 1 2 3 4 5 6 7 8 9 10 #include #include "compass2_hw.h" sbit COMPASS2_CS at GPIOD_ODR.B13; void system_setup( bus_mode_t mode, uint8_t addr ); float mRes; // scale resolutions per LSB for the sensors uint8_t asax, asay, asaz; float adjusted_ASAX, adjusted_ASAY, adjusted_ASAZ; Page 2 of 3 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 float heading, adjusted_MX, adjusted_MY, adjusted_MZ, magbias[3]; int16_t mx, my, mz; char text[20] = { 0 }; void main() { // Local Declarations uint8_t address = 0x0F; bus_mode_t my_mode = I2C; float heading = 0; char uart_text[5] = { 0 }; system_setup( my_mode, address ); while(1) { compass2_get_all_values( &mx, &my, &mz ); heading = compass2_get_compass_heading( mx, my, mz ); if( heading < 0 ) heading += 360; UART1_Write_Text( "Heading: " ); FloatToStr( heading, text ); UART1_Write_Text( text ); UART1_Write_Text( " Direction: " ); if( heading >= 330 || heading = 300 && heading = 240 && heading = 210 && heading
MIKROE-2264 价格&库存
很抱歉,暂时无法提供与“MIKROE-2264”相匹配的价格&库存,您可以联系我们找货
