MIKROE-1938
MIKROE-1938
    MIKRO
    MAGNETO2CLICK
MIKROE-1938 数据手册
Magneto 2 click Magneto 2 click is a mikroBUS™ add-on board with Melexis's MLX90316 monolithic rotary position sensor. Sensing flux density with the IC surface of the MLX90316 allows the click to decode the absolute rotary (angular) position from 0 to 360 degrees. In combination with the correct library, the magnetic flux density of a small magnet (diametral magnetisation) rotating above the IC can be measured in a non-contacting way. The sensor enables the design of novel generation of non-contacting rotary position sensors that are frequently required for both automotive and industrial applications. Magneto 2 click communicates with the target MCU through the mikroBUS™ SPI bus. The board is designed to use a 5V power supply only. Applications Absolute Rotary Position Sensor, Pedal Position Sensor, Float-Level sensor, and Throttle Position Sensor. Key features Triaxis® Hall Technology Programmable Angular Range up to 360 Degrees 12 bit Angular Resolution SPI interface 5V power supply Key Benefits CRC checks for even higher accuracy Multiple filter settings for higher accuracy Ready-to-use examples save development time Supported in mikroC compiler mikroBUS™ is specially designed pinout standard with SPI, I2C, Analog, UART, Interrupt, PWM, Reset and Power  supply pins. See Standard Specification. Features and usage notes Programmable Linear Transfer Characteristic SPI interface 5V Power Supply Tria⊗is® Hall Technology 40 bit ID number Single Die ‐ SO8 or Dual Die (Full Redundant) ‐ TSSOP16, RoHS Compliant Absolute Rotary Position Sensor IC Changeable main frequency for DSP chip (7MHz or 20 MHz master clock) Hysteresis Filter FIR and IIR filters for higher output accuracy Programming This code initialises UART and SPI, reads data from the Magneto 2 click, and, if the readings are successful, prints  1 void main() { 2 char txt[20]; 3 uint8_t check = 0; 4 float angle = 0.0; 5 UART1_Init_Advanced( 9600, _UART_8_BIT_DATA, 6 _UART_NOPARITY, 7 _UART_ONE_STOPBIT, 8 &_GPIO_MODULE_USART1_PA9_10 ); 9 Delay_ms(300); 10 11 UART1_Write_Text("Uart initialized\r\n"); 12 GPIO_Digital_Output( &GPIOD_BASE, _GPIO_PINMASK_13 ); // set CS pin as output 13 14 15 16 17 18 19 20 21 22 23 // Initialize SPI SPI3_Init_Advanced(_SPI_FPCLK_DIV64, _SPI_MASTER | \ _SPI_8_BIT | _SPI_CLK_IDLE_LOW | \ _SPI_SECOND_CLK_EDGE_TRANSITION | \ _SPI_MSB_FIRST |\ _SPI_SS_DISABLE |\ _SPI_SSM_ENABLE |\ _SPI_SSI_1, &_GPIO_MODULE_SPI3_PC10_11_12); SPI_Set_Active(&SPI3_Read, &SPI3_Write); // Sets the SPI1 module active 24 25 26 while (1) 27 { 28 check = read_mlx(); 29 if ( check == 0) // if read was successful, print success and angle 30 { 31 Uart1_Write_Text("Success \r\n"); 32 angle = (float) mlx.angle; 33 angle /= 45.5; 34 floattostr(angle,txt); 35 Uart1_Write_Text(txt); 36 Uart1_Write_Text("\r\n"); 37 } 38 else // else print fail 39 Uart1_Write_Text("Fail \r\n"); 40 41 Delay_ms(400); // Wait 400ms 42 } 43 } Code example that demonstrates the usage of Magneto 2 click with MikroElektronika hardware, written for  mikroC for ARM is available on Libstock. MIKROE-1938 Magneto 2 click Copyright © 1998 - 2016. MikroElektronika d.o.o.
MIKROE-1938 价格&库存
很抱歉,暂时无法提供与“MIKROE-1938”相匹配的价格&库存,您可以联系我们找货
