Matrix click
From MikroElektonika Documentation
Matrix click is a mikroBUS™ add-on board with two red or green (there are two
options) 5x7 matrices driven by two MAX7219 8-bit LED Display Drivers. The
active area of each matrix is 7.62mm high and 5.08 mm wide. 7x5 is a standard
resolution for displaying ASCII characters, so 7x10 click is essentially a dualcharacter display capable of showing letters in more readable typefaces compared to
a 14-segment display. The click communicates with the target MCU through the
mikroBUS™ SPI interface with two separate Chip Select lines for each matrix (CSL
for the left, CSR for the right). This board is designed to use a 5V power supply.
TK click
Features and usage notes
The 7x5 LED matrix is a
standard resolution for
displaying ASCII characters.
Matrix click is essentially a
dual-character display capable
Schematic also available in PDF (http://cdndocs.mikroe.com/images/f/f4/Matrix_G_click_schem
If you double up on a board with
two adjacent mikroBUS sockets,
such as clicker 2 or Flip & click,
you will get four characters.
The possibility to horizontally
scroll the text makes for a
virtually unlimited space for displaying written information.
Programming
The code snippet results in blinking two by two letters of string provided as a first
parameter.
Matrix G click
IC/Module MAX7219 8-bit LED Display Drivers
(https://www.maximintegrated.com/en/datasheet/index.mvp/id/1339)
and a pair of 7x5 LED matrices
(http://optoelectronics.liteon.com/upload/download/DS-30-97087/S_110_LTP-305HR.pdf)
Interface
SPI, CSL, CSR
Power
5V
supply
Website
1 void main()
2 {
system_init();
3
matrix_init();
4
matrix_text_blink( "MIKROELEKTRONIKA", MATRIX_MED_FAST );
5
Delay_ms( 1000 );}
6
www.mikroe.com/click/matrix-g
(http://www.mikroe.com/click/matrix-g)
www.mikroe.com/click/matrix-r
(http://www.mikroe.com/click/matrix-r)
Code examples that demonstrate the usage of Matrix clicks with MikroElektronika hardware, written for mikroC for ARM, AVR, dsPIC, FT90x, PIC and PIC32
are available on Libstock (http://libstock.mikroe.com/projects/view/1852/matrix-click).
Resources
- Data sheet for LED drivers (https://www.maximintegrated.com/en/datasheet/index.mvp/id/1339)
- LTP-305HR LED matrix data sheet (http://optoelectronics.liteon.com/upload/download/DS-30-97-087/S_110_LTP-305HR.pdf)
- mikroBUS standard specifications (http://www.mikroe.com/downloads/get/1737/mikrobus_specification.pdf)
Retrieved from "http://docs.mikroe.com/index.php?title=Matrix_click&oldid=484"
◾ This page was last modified on 8 July 2016, at 23:14.
◾ Content is available under Creative Commons Attribution unless otherwise noted.
http://docs.mikroe.com/index.php?title=Matrix_click&printable=yes
8/8/2016
很抱歉,暂时无法提供与“MIKROE-2246”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+262.27249
- 5+257.02392
