SPIRIT click
PID: MIKROE-2568
SPIRIT click carries the SP1ML 868MHz ultra low-power RF module. The board is designed to
use 3.3V power supply and 3.3V or 5V I/O voltage levels. It communicates with the target MCU
over UART interface, with additional functionality provided by the following pins on the
mikroBUS™ line: PWM, RST, CS.
It can be used to wirelessly send and receive UART data.
SP1ML 868MHz RF module features
SP1ML is based on the SPIRIT1 RF sub-GHz transceiver (with integrated SMPS), STM32L1
microcontroller, integrated filter/balun, and chip antenna.
There are two operational modes, command mode and operating mode. The command mode
allows module configuration and status interrogation using an extended ‘AT’ style command set.
In operating mode the module serves its primary purpose as a wireless transceiver.
In operating mode the module uses only 13.5mA, 2.2mA in command mode, and even lower in
stanby with just 1.4µA. This kind of power consumption makes it ideal for smart devices that
send small amounts of data.
The module has an integrated antenna and crystal.
Key features
o Low data rate, low power sub‐GHz transceiver
o STM32L1 Ultra low power microcontroller at 32 MHz (16 kB RAM and 128 kB Flash)
o Integrated antenna and crystal
o Output power up to +11.6 dBm
UART interface
3.3V power supply
Specification
Product Type
RF Sub 1GHz
Security systems, mobile health and medicine applications, IoT, wireless
Applications
metering, etc.
MCU
MCU Memory 16 kB RAM and 128 kB Flash
Key Features Low data rate, low power sub-GHz transceiver
Interface
UART
Power Supply 3.3V
Compatibility mikroBUS
Click board
M (42.9 x 25.4 mm)
size
Pinout diagram
This table shows how the pinout on SPIRIT click corresponds to the pinout on the mikroBUS™
socket (the latter shown in the two middle columns).
Notes
Pin
Pin
Notes
mikroBUStm
Not connected NC 1 AN
Reset input, active low RST 2 RST
PWM 16 SHDN Shutdown
INT 15
NC Not connected
Command mode CMD 3 CS
TX 14 TXD UART transmit data
Not connected NC 4 SCK
RX 13 RXD UART receive data
Not connected NC 5 MISO SCL 12
NC Not connected
Not connected NC 6 MOSI SDA 11
NC Not connected
Power supply +3.3V 7 3.3V
5V 10 +5V Power supply
Ground GND 8 GND GND 9 GND Ground
Jumpers and settings
LOGIC SEL ‐ used to select 3.3 or 5V logical level for UART communication (J1A in the schematic).
Programming
Code examples for SPIRIT click, written for MikroElektronika hardware and compilers are
available on Libstock.
General description
The library implements communication protocol between the MCU host and SPIRIT click
module. It can work in two modes, command mode and operating mode. The command mode
In operating mode the module serves its primary purpose as a wireless transceiver. It uses
asynchronous approach to issue commands and receive responses via callback functions.
Code snippet
The code snippet shows an example callback function for the ATO command. It checks if the
response is OK to change from library state to operating mode.
01 static bool on_ato(char* response)
02 {
03
if(strcmp(response, "OK") == 0)
04
05
LOG_INFO("Entered operating mode.");
06
07
spirit_mode(SPIRIT_OPERATING_MODE);
08
09
else
10
11
LOG_ERROR("Failed to enter to operation mode...");
12
13
14
return true;
15 }
Features
Configurable command buffer size.
Ring buffer for receiving data via UART
Supported mikroC compilers for ARM, PIC32, PIC, FT90.
Asynchronous command issuing.
https://shop.mikroe.com/click/wireless‐connectivity/spirit 4/5/17
很抱歉,暂时无法提供与“MIKROE-2568”相匹配的价格&库存,您可以联系我们找货
