Brushless click
1
Brushless click
Brushless click
Brushless click
IC
Interface
Toshiba's TB6575FNG
[1]
PWM,INT,AN and RST pins
Power supply
5V
Product page
www.mikroe.com/click/brushless
Schematic
Brushless click schematic
[2]
[3]
Brushless click carries Toshiba's TB6575FNG IC for driving 3-phase full-wave Brushless DC motors — which are
ideal for powering flying drones. The click is able to safely drive external motors with up to 32V/2A.
The board features three pairs of onboard screw terminals. VBAT is for connecting an external 7-32V power supply.
The other two are for connecting an external motor.
The IC controls the rotation speed by changing the PWM duty cycle by analog voltage.
Features and usage notes
Motor position detection error
Position detection is synchronized with the PWM signal generated in the IC. When the IC is used in a high speed
motor a position detection error relative to the PWM frequency may occur. The detection is performed on the falling
edge of the PWM signal. An error is recognized when the pin voltage exceeds the reference voltage.
MOSFET chips
Two types of MOSFET chips on board switch the output on and off (N-channel 40V and P-channel 30V). They are
here for electronic motor control – switching the output on and off controls the voltage levels applied to the motor
and this in turn determines the speed and rotation of the motor shaft.
To ensure a more secure connection there are three pairs of screw terminals - CON1 for the power supply and CON2
and CON3 for connecting to the motor. The U,V and W pins control the motor rotation direction. The Brushless
click communicates with the target board MCU over the PWM pin, as well as INT, AN and RST pins.
Brushless click
2
The board is designed to use a 5V power supply only.
Application:
Automotive industry, drones (because of the good power-to weight ratio of the motor), computers, medical
equipment, HVAC systems, small home appliances, robotics, battery powered systems, small cooling fans in
computers, toys, etc.
Key features:
TB6575FNG driver for sensorless communication
5V power supply
Overcurrent protection
20-mA current sink capability on PWM output pins
MOSFET chips toggle the output on and off
MCP6281 prevents phase reversal
Lead angle control (7.5° and 15°)
Forward/reverse rotation
Input voltage −0.3 to VDD + 0.3V
• Green LED indicates that power is on
• Operating temperature -30°C to 105°C
Pinout diagram
This table shows how the pinout on Brushless click corresponds to the pinout on the mikroBUS™ socket (the latter
shown in the two middle columns).
Notes
Pin
Pin
Notes
mikroBUStm
Measures the voltage of the DC power supply VSENSE 1 AN
Motor direction
X PWM 16 PWM Duty cycle control
DIR
2 RST
INT
15 INT
NC
3 CS
RX
14 NC
NC
4 SCK
TX
13 NC
NC
5 MISO
SCL
12 NC
NC
6 MOSI
SDA
11 NC
This click works on 5V only
NC
7 +3.3V
+5V
10 +5V
Ground
GND
8 GND
GND 9
GND
Rotation speed sensing output
+5V power input
Ground
Brushless click
3
Programming
This code snippet initializes required ports, ADC channels and PWM module. It also initializes TFT and sets motor
direction. In an endless loop, if button is pressed, we increment or decrement current PWM duty by STEP, which
consequently change the rotating speed of BLDC motor.
Code example
1 void main()
2 {
3
MCU_Init();
4
TFT_Init_ILI9341_8bit(320, 240);
5
TFT_BLED = 1;
6
DrawFrame();
7
MOTOR_DIR = CCW;
8
while(1) {
// TFT Init
// Setting motor direction to counter-clock-wise
9
if (GPIOD_IDR.B3) {
10
Delay_ms(10);
11
current_speed = current_speed + STEP;
12
if (current_speed > pwm_period)
13
14
// button on PD3 pressed
// if we increase current_duty greater then possible pwm_period value
current_speed = 0;
15
16
PWM_TIM5_Set_Duty(current_speed,
17
// reset current_duty value to zero
_PWM_NON_INVERTED, _PWM_CHANNEL1);
// set newly acquired duty ratio
18
if (GPIOD_IDR.B6) {
// button on PD6 pressed
19
Delay_ms(10);
current_speed = current_speed - STEP;
21
22
23
current_speed = pwm_period;
24
// if we decrease current_duty greater then possible pwm_period value (overflow)
// set current_duty to value of pwm_period
25
26
_PWM_NON_INVERTED, _PWM_CHANNEL1); // set newly acquired duty ratio
27
Delay_ms(20);
28
// current_speed display
29
WordToStr(current_speed, txt);
30
TFT_Rectangle(150, 80, 250, 110);
31
TFT_Write_Text(txt, 150, 80);
32
// increment current_duty
33 }
Code examples for Brushless click, written for MikroElektronika hardware and compilers are available on Libstock
[4]
Brushless click
Resources
Brushless click data sheet [1]
Library [4]
Brushless click schematic [5]
mikroBUS™ standard specifications [6]
References
[1]
[2]
[3]
[4]
[5]
[6]
https:/ / toshiba. semicon-storage. com/ ap-en/ product/ linear/ motordriver/ detail. TB6575FNG. html
http:/ / www. mikroe. com/ click/ brushless
http:/ / cdn-docs. mikroe. com/ images/ 7/ 7a/ Brushless_schematic_v100. pdf
http:/ / libstock. mikroe. com/ projects/ view/ 1951/ brushless-click-example
http:/ / cdn-docs. mikroe. com/ images/ e/ e4/ Brushless-click. pdf
http:/ / www. mikroe. com/ mikrobus/
4
Article Sources and Contributors
Brushless click Source: http://docs.mikroe.com/index.php?oldid=2193 Contributors: Biljana.nedeljkovic, Lana.vulic, Srdjan.misic, Vojislav.gvozdic
Image Sources, Licenses and Contributors
File:Click brushless new front.jpg Source: http://docs.mikroe.com/index.php?title=File:Click_brushless_new_front.jpg License: unknown Contributors: Vojislav.gvozdic
File:mikrobus logo.png Source: http://docs.mikroe.com/index.php?title=File:Mikrobus_logo.png License: unknown Contributors: Vojislav.gvozdic
License
Creative Commons Attribution
https:/ / creativecommons. org/ licenses/ by/ 4. 0/
5
很抱歉,暂时无法提供与“MIKROE-2441”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+375.46049
- 5+367.95211
