MIKROE-2507
MIKROE-2507
    MIKRO
    ECG2CLICK
MIKROE-2507 数据手册
ECG 2 click PID: MIKROE-2507 Weight: 30 g Condition: New product Track the patterns of your beating heart with ECG 2 click. ECG 2 click contains ADS1194 16‐bit delta‐ sigma analog‐to‐digital converters from Texas Instruments, a built‐in programmable gain amplifier  (PGA), an internal reference, and an onboard oscillator.      Table of contents 1. 2. 3. 4. 5. 6. Setup guide – How to use the ECG 2 click  MikroPlot application  Power supply  OverVoltage and OverCurrent protection  Application  Key features  Track the patterns of your beating heart with ECG 2 click. ECG 2 click contains ADS1194 16-bit delta-sigma analog-to-digital converters from Texas Instruments, a built-in programmable gain amplifier (PGA), an internal reference, and an onboard oscillator. The click communicates with the target MCU over SPI and the following mikroBUS pins: PWM, AN and INT. ECG 2 click runs on 3.3V and 5V power supply. Note: We offer cables for three electrodes measuring (using 3.5mm jack onboard) Setup guide – How to use the ECG 2 click You will need the following things to start recording your ECG:    1.ECG 2 click  2.Cable  3.Disposable adhesive electrode pads (sold in packs of 30)  Of course, you will also need a target board with an MCU (preferably powered from an external battery). There are two available measuring options: 1. For 3 wire measurement, a 3.5mm jack is used. You can connect the click to a person using three electrodes placed on the left arm, right arm and the left side of the abdomen (below the heart) or alternatively on the left leg. We offer cables and electrodes that are marked (left leg (LL) – red, left arm (LA) – black, right arm (RA) – white). 2. For 4 wire measurement, screw terminals are used. ECG 2 click can also be connected by 4 electrodes that are placed on both arms and legs. MikroPlot application MikroPlot is a free data visualization tool (Windows) that can be used to generate an ECG. The graph is generated from data sent from the MCU (ADC values from ECG click input + time stamp). A UART-USB connection is required. See the learn.mikroe.com article for more information. Power supply ECG 2 click uses both 3.3V and 5V power supply — 3.3V is used as digital power supply and 5V is used for analog power supply (via linear regulator which gives stabilized 3V at output). OverVoltage and OverCurrent protection OverVoltage and OverCurrent protection is realized over 22k resistors and diodes. Application Measures the electrical activity of a beating heart through electrodes taped to the skin. DISCLAIMER: ECG 2 click is a prototyping tool, not a medical-grade device. Do not use it to diagnose patients. Key features      ADS1194 IC   o Built‐in oscillator and reference  o Built‐in programmable gain amplifier  Onboard 3.5mm jack  MikroPlot application  Interface: SPI  3.3V and 5V power supply  SPECIFICATION  Product Type Biomedical Measures the electrical activity of a beating heart through electrodes taped to the Applications skin ADS1194 IC, Onboard 3.5mm jack, Mikro Plot application, SPI interface, 3.3V Key Features and 5V power supply Ready-to-use example and free software tool to generate ECG plot, record ECG Key Benefits while you watch TV, read email, talk over the phone – study patterns to see what excites you (HRV - heart rate variability is a good indicator of state of mind). Interface SPI Power 3.3V and 5V Supply Click board L (57.15 x 25.4 mm) size     Pinout diagram This table shows how the pinout on ECG 2 click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes    Pin  Pin Notes  mikroBUStm  Test Pace Out  PAC  1  AN  PWM  16 PWD Power Down  System reset  RESET  2  RST  INT  15 DRD Data Ready  SPI chip select  CS  3  CS  RX  14 NC  Not connected SPI clock  SCLK  4  SCK  TX  13 NC  Not connected SPI data out  DOUT  5  MISO  SCL  12 NC  Not connected SPI data in  DIN  6  MOSI  SDA  11 NC  Not connected Power supply  +3.3V  7  3.3V  5V  10 +5V Power supply  Ground  GND  8  GND  GND  9 GND Ground  Programming ECG2 click works best with a battery power supply. In cases where the board is powered through an USB cable, a periodical 50Hz noise will occur on the ECG signal. To counter this noise, the user must place their left hand on the ground pin of their development board. Code set's up the ECG2 click, measures ECG and sends data to MikroPlot application. 01: void main() { 02: 03: uint16_t i = 0; 04: char final_string[20]; 05: char time_string[20]; 06: double time_value = 0.0; 07: UART0_Init(57600); 08: delay_ms(300); 09: 10: GPIO_Digital_Input(&GPIO_PORTH, _GPIO_PINMASK_0); // pin DRDY is input 11: GPIO_Digital_Output(&GPIO_PORTC, _GPIO_PINMASK_4); // pin PWDN is output 12: ECG2_PWDN = 1; // ECG2 is powered up 13: GPIO_Digital_Output(&GPIO_PORTG, _GPIO_PINMASK_0); // pin CS is output 14: ECG2_CS = 1; // deselect ECG2 click 15: GPIO_Digital_Output(&GPIO_PORTE, _GPIO_PINMASK_2); // pin RESET is output 16: ECG2_RESET = 1; // pull RESET bit low for 18 CLK to RESET ECG device 17: 18: // init SPI 19: SPI0_Init_Advanced(500000, _SPI_MASTER, _SPI_8_BIT | _SPI_CLK_IDLE_LOW | _SPI_SECOND_CLK_EDGE_TRANSITION, &_GPIO_MODULE_SPI0_A245); 20: ecg2_hal_init(); 21: 22: 23: // issue RESET pulse 24: ECG2_RESET = 0; 25: Delay_us(100); 26: ECG2_RESET = 1; 27: 28: Delay_ms(1000); 29: 30: // device is in RDATAC mode, set it to SDATAC mode to edit registers 31: ecg2_hal_send_command(SDATAC_COMMAND); 32: delay_ms(1000); 33: setup_ecg2(); 34: 35: while (1) 36: { 37: while (ECG2_DRDY) {} // Wait for ADS1194 device to prepare output data. Data is ready every 8 milliseconds 38: Delay_us(5); 39: for (i = 0; i < num_bytes_sample; i++) 40: ecg_data_sample[i] = SPI_Read(0); // read ADS1194 output data, one sample 41: 42: time_value += 8.0; // increment time value 43: // calculate input voltage 44: // voltage LA RA 45: channel1_voltage = calculate_ecg_channel( ecg_data_sample, 3, Vref, channel_gain, channel1_voltage_offset ); 46: // voltage LL RA - channel 2 is usually used for simple ECG 47: channel2_voltage = calculate_ecg_channel( ecg_data_sample, 5, Vref, channel_gain, channel2_voltage_offset ); 48: sprintf(final_string, "%.2f", channel2_voltage); // convert values to string and send to MikroPlot 49: strcat(final_string, ","); 50: sprintf(time_string, "%.2f", time_value); 51: strcat(final_string, time_string); 52: Uart_Write_Text(final_string); 53: Uart_Write_Text("rn"); 54: 55: // voltage LL LA 56: channel3_voltage = calculate_ecg_channel( ecg_data_sample, 7, vref, channel_gain, channel3_voltage_offset ); 57: // voltage from temperature sensor 58: channel4_voltage = calculate_ecg_channel( ecg_data_sample, 9, vref, channel_gain, channel4_voltage_offset ); 59: } 60: }        Copyright © 1998 ‐ 2017. MikroElektronika d.o.o.
MIKROE-2507 价格&库存
很抱歉,暂时无法提供与“MIKROE-2507”相匹配的价格&库存,您可以联系我们找货
MIKROE-2507
  • 2+272.82889
  • 5+261.92293
库存:5
