107010001
107010001
    SEEED(矽递科技)
    RESPEAKERMICARRAY-FAR-FIELD
107010001 数据手册
ReSpeaker Mic Array - Far-field w/ 7 PDM Microp SKU 107010001 Far-field Voice Capture Acoustic Source Localization Beamforming Noise Suppression De-reverberation Acoustic Echo Cancellation Description The ReSpeaker Mic Array can be stacked (connected) right onto the top of ReSpeaker Core to significantly improve the voice interaction experience. It is developed based on the XVSM-2000 Smart Microphone from XMOS. The board integrates 7 PDM microphones to help enhance ReSpeaker's acoustic DSP performance to a much higher level. With the Mic Array attached onto the top of the ReSpeaker Core, ReSpeaker is now able to:  Far-field Voice Capture Acoustic Source Localization Beamforming Noise Suppression De-reverberation Acoustic Echo Cancellation XMOS microcontroller with 16 cores inside   7 high performance digital microphones Supports Far-field Voice Capture (up to 10m) Supports Beamforming, Acoustic Source Localization, Nosie Suppression, De-reverberation and Acoustic Echo Cancellation 12 programmable RGB LED indicators   Microphones: ST MP34DT01-M   Sensitivity: -26 dBFS (Omnidirectional)   Acoustic overload point: 120 dBSPL   SNR: 61 dB   Power Supply: 5V DC from Micro USB or expansion header   Dimensions: 70mm (Diameter)   Weight: 15.25g  1x ReSpeaker Far-filed Mic Array  Copyright © 2008-2016 Seeed Development Limited All rights reserved
107010001 价格&库存
很抱歉,暂时无法提供与“107010001”相匹配的价格&库存,您可以联系我们找货
  • 1+696.534921+90.21367
