104990263
104990263
    SEEED(矽递科技)
    7 INCH BEAGLEBONE GREEN LCD CAPE
104990263 数据手册
7 Inch BeagleBone Green LCD Cape with Resistive Touch SKU: 104990263 Description This cape features a compact 7 inch LCD for Beaglebone Green or Beaglebone Black. On size it’s a bit larger than the 5 inch version, which means it can have a graphical display at 1024x600 resolution, along with a layer of 4-wired resistive touchscreen for user interactions. It’s very easy to set it up as you only need to attach it directly onto your BBG/BBB through the 2x46 pin headers, which will provides everything the cape requires such power and display signals. Also as an alternative, you can power the cape through the built-in micro USB on the back. Below the screen is an array of push buttons - LEFT, RIGHT, UP, DOWN and ENTER, which provides an alternative way to interact with your screen. Besides, two LEDs are used to indicate Power and User status, NOTE: This LCD cape is only compatible with Beaglebone Green and Beaglebone Black. Features Resolution up to 1024 x 600 Resistive Touch 5 push buttons includes LEFT, RIGHT, UP, DOWN and ENTER Supports Debian Supports Angstrom Supports WinCE / Android 4.2 by user-define driver ULP(Ultra Low Power) consumption backlight 4x 3mm mounting holes Built-in USB for powering Specifications Voltage: 5V DC Current: 335mA (Test conditions: Beaglebone Green not include.) Watt: 1.675W (Test conditions: Beaglebone Green not include.) Dimensions: 180mm*116.5mm*21mm Weight: 222g Part List 1 x 7 Inch BeagleBone Green LCD Cape with Resistive Touch Copyright © 2008-2015 Seeed Technology Co., Ltd All rights reserved.
104990263 价格&库存
很抱歉,暂时无法提供与“104990263”相匹配的价格&库存,您可以联系我们找货
