Page 1 of 2
GSM-GPS click
From MikroElektonika Documentation
GSM-GPS click carries a SIM808 module that combines GSM/GPRS and GPS into a single device.
Ideal for remote tracking devices in any shape or form.
GSM-GPS click
Features and usage notes
The high-performance GSM/GPRS engine works
on quad-band GSM frequencies: 850, EGSM 900,
DCS 1800, PCS 1900 MHz. The GPS has a 1
second TTF (Time To First Fix) from a hot star
and tracking sensitivity of -165 dBm.
The board has two antenna connectors, one for
GSM the other for GPS. The bottom side has a
SIM card slot and a Micro USB connector for
interfacing with a PC.
Schematic also available in PDF (http://cdndocs.mikroe.com/images/2/20/GSMGPS_click_schematic_v100.pdf)
GSM-GPS click communicates with the target
board MCU through mikroBUS™ UART
interface, with additional functionality provided
by STAT, PWRKEY, RTS, RS, and CTS. Beside
the mikroBUS™, the board has additional pins for
connecting speakers and a microphone to the
GSM engine.
GSM-GPS click
IC/Module SIMCO
(http://simcom.ee/documents/SIM808/SIM808%
20SPEC_V1507.pdf)
GSM-GPS click uses either a 3.3V or 5V power supply.
The following are the most importrant features of the GPRS module:
Quad-band 850/900/1800/1900MHz
•GPRS multi-slot class 12/10 •GPRS mobile station class B
Interface
UART, STAT, PWRKEY, RTS, RI, CTS
Power
supply
3.3V, 5V
Website
www.mikroe.com/click/gsm-gps
(http://www.mikroe.com/click/gsm-gps)
•Compliant to GSM phase 2/2+ – Class 4 (2 W @ 850/900MHz)
– Class 1 (1 W @ 1800/1900MHz)
•Dimensions: 24*24*2.6mm
•Weight: 3.3g •Control via AT commands (3GPP TS 27.007, 27.005 and SIMCOM enhanced AT Commands) •Supply voltage range 3.4 ~ 4.4V
•Low power consumption
•Operation temperature:-40℃ ~85℃
Specification for GPS
•Sensitivity
-Tracking: -165 dBm
-Cold starts : -148 dBm
•Time-To-First-Fix
-Cold starts: 32s (typ.)
-Hot starts:
很抱歉,暂时无法提供与“MIKROE-2382”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+509.00511
- 3+488.61855
