104990262
104990262
    SEEED(矽递科技)
    5 INCH BEAGLEBONE GREEN LCD CAPE
104990262 数据手册
5 Inch BeagleBone Green LCD Cape with Resistive Touch SKU: 104990262 Description This cape features a compact 5 inch LCD for Beaglebone Green or Beaglebone Black. On size it’s a bit smaller than the 7 inch version, but it still has a graphical display at 800x480 resolution and a layer of 4wired resistive touchscreen for user interactions. It’s very easy to set it up as you only need to attach it directly onto your BBG/BBB through the 2x46 pin headers, which will provides everything the cape requires such power and display signals. Also as an alternative, you can power the cape through the built-in micro USB on the back. Below the screen is an array of push buttons - LEFT, RIGHT, UP, DOWN and ENTER, which provides an alternative way to interact with your screen. Besides, two LEDs are used to indicate Power and User status, NOTE: This LCD cape is only compatible with Beaglebone Green and Beaglebone Black. Features Resolution up to 800 x 480 Resistive Touch 5 push buttons includes LEFT, RIGHT, UP, DOWN and ENTER Supports Debian Supports Angstrom Supports WinCE / Android 4.2 by user-define driver ULP(Ultra Low Power) consumption backlight 4x 3mm mounting holes Built-in USB for powering Specifications Voltage: 5V DC Current: 110mA (Test conditions: Beaglebone Green not include) Power: 0.55W (Test conditions: Beaglebone Green not include) Dimensions: 130mm*86.5mm*19mm Weight: 120g Part List 1 x 5 Inch BeagleBone Green LCD Cape with Resistive Touch Copyright © 2008-2015 Seeed Technology Co., Ltd All rights reserved.
104990262 价格&库存
很抱歉,暂时无法提供与“104990262”相匹配的价格&库存,您可以联系我们找货
