MIKROE-2237
MIKROE-2237
    MIKRO
    MANOMETERCLICK
MIKROE-2237 数据手册
Manometer click From MikroElektonika Documentation Manometer click Manometer click carries a piezoresistive silicon pressure sensor – a Honeywell HSCMAND060PA3A3 module with industry-leading, extremely high accuracy of ±0.25%FSS BFSL. An absolute pressure range from 0 to 60 PSI makes it suitable for a variety applications. Beyond the measurement range, the sensor has a high burst pressure threshold, resulting in increased reliability. . Manometer click communicates with the target board MCU through the mikroBUS™ I2C interface (SCL, SDA). Manometer click uses a 3.3V power supply. Features and usage notes The sensor on Manometer click is a highly reliable and robust unit. It's also fairly easy to use and implement. It requires no calibration and it compensates for environmental conditions by relying on its internal temperature sensor. The HSC Series is calibrated over the temperature range of 0 °C to 50 °C (32 °F to 122 °F). The temperature sensor can also be accessed independently through the I2C interface. Schematic also available in PDF (http://cdndocs.mikroe.com/images/6/62/Manometer_click_v10 The barbed port accepts 4.93 mm (0.19”) tubing which connects directly (no special extensions required). Manometer click IC/Module Honeywell HSCMAND060PA3A3 (http://sensing.honeywell.com/honeywellsensing-trustability-hsc-series-high-accuracyboard-mount-pressure-sensors-50099148-aen.pdf?name=HSCMAND060PA3A3) Programming The following code snippet shows how our library simplifies the usage of Manometer click. 1 2 3 4 5 6 7 8 9 10 11 12 #include "manometer_hw.h" void main() { float pressure, temp; int count = 0; TWI_Init( 100000 ); manometer_init( MANOMETER_ADDRESS_TYPE_3, 0, 60 ); pressure = manometer_get_pressure(); temp = manometer_get_temp( CELSIUS ); if( pressure > 45 && temp > 35 ) count++; } HSCMAND060PA3A3 Interface I2C (SCL, SDA) Power 3.3V supply Website www.mikroe.com/click/manometer (http://www.mikroe.com/click/manometer) Code examples that demonstrate the usage of Manometer click with MikroElektronika hardware, written for mikroC for ARM, AVR, dsPIC, FT90x, PIC and PIC32 are available on Libstock (http://libstock.mikroe.com/projects/view/1781/manometer-click). Resources - learn.mikroe.com tutorial about Manometer click (http://learn.mikroe.com/industrial-solution-pressures/) - HSCMAND060PA3A3 data sheet (http://sensing.honeywell.com/honeywell-sensing-trustability-hsc-series-high-accuracy-board-mount-pressure-sensors50099148-a-en.pdf?name=HSCMAND060PA3A3) - Manometer click examples on Libstock (http://libstock.mikroe.com/projects/view/1781/manometer-click) - mikroBUS standard specifications (http://download.mikroe.com/documents/standards/mikrobus/mikrobus-standard-specification-v200.pdf) Retrieved from "http://docs.mikroe.com/index.php?title=Manometer_click&oldid=365" ◾ This page was last modified on 13 June 2016, at 16:10. ◾ Content is available under Creative Commons Attribution unless otherwise noted. http://docs.mikroe.com/index.php?title=Manometer_click&printable=yes 6/15/2016
MIKROE-2237
1. 物料型号:HSCMAND060PA3A3,由Honeywell生产。 2. 器件简介:Manometer click搭载了一个压阻式硅压力传感器,具有行业领先的高精度(±0.25%FSS BFSL),适用于多种应用场景。 3. 引脚分配:通过mikroBUS™ I2C接口(SCL, SDA)与目标板的MCU通信。 4. 参数特性:传感器量程为0至60 PSI的绝对压力,具有高爆破压力阈值,提高了可靠性。工作温度范围为0°C至50°C(32°F至122°F)。 5. 功能详解:传感器易于使用和实现,无需校准,依靠内部温度传感器自动补偿环境条件。 6. 应用信息:适用于需要精确测量压力的工业解决方案。 7. 封装信息:带有刺形端口,可接受4.93毫米(0.19英寸)的管子,直接连接,无需特殊扩展。
MIKROE-2237 价格&库存
很抱歉,暂时无法提供与“MIKROE-2237”相匹配的价格&库存,您可以联系我们找货
MIKROE-2237
    • 1+1259.01208
    • 5+1233.84183
    库存:3
    MIKROE-2237
      • 1+473.05314
      • 3+454.13389
      库存:5
