2890
2890
    ADAFRUIT
    DMM DUAL-DISPLAY TRUE RMS
2890 数据手册
FeatherWing Doubler - Prototyping Add-on For All Feather Boards PRODUCT ID: 2890 DESCRIPTION - This is the FeatherWing Doubler - a prototyping add-on and more for all Feather boards. This is similar to our FeatherWing Proto except there are two! The magic of the Doubler comes when stacking a Feather and another board on top of the Doubler so you can work with both boards simultaneously side-by-side! In addition to the board the Doubler comes with: • 1 Doubler PCB • 1 set Feather Stacking Headers • 1 set Feather Female Headers The Doubler, like the Proto, has a duplicate breakout for each pin on a Feather, as well as a bunch of plain grid proto holes. For GND and 3.3V, we give you a strip of connected pads. You'll need to solder on the female headers or stacking headers however you like, the Doubler comes as a mini kit! http://www.adafruit.com/product/2890 12/2/2015 Technical Details PCB Dimensions: 50.9mm x 47mm x 1.6mm / 2" x 1.85" x 0.06" Weight: 6.7g
很抱歉,暂时无法提供与“2890”相匹配的价格&库存,您可以联系我们找货
