Digital Tilt Sensor SKU:DFR0028
Contents
1 Introduction
2 Specification
3 Connection Diagram
o 3.1 Sample Code
Introduction
The DFRobot Tilt Sensor is a digital tilt switch. It could be used as a simple tilt sensor. Simple
plug to our IO/Sensor Expansion board, you can make amazing interactive projects. The
dedicated sensor expansion boards with the Arduino, in combination, can achieve very
interesting and an interactive work.
Specification
Supply Voltage: 3.3V to 5V
Interface: Digital
Connection Diagram
Sample Code
int ledPin = 13;
// Connect LED to pin 13
int switcher = 3;
// Connect Tilt sensor to Pin3
void setup() {
pinMode(ledPin, OUTPUT);
// Set digital pin 13 to output mode
pinMode(switcher, INPUT);
// Set digital pin 3 to input mode
void loop() {
if (digitalRead(switcher) == HIGH) //Read sensor value
digitalWrite(ledPin, HIGH);
// Turn on LED when the sensor is tilted
else
digitalWrite(ledPin, LOW);
gered
// Turn off LED when the sensor is not trig
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“DFR0028”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+17.251171+2.22555
