SEN0121
SEN0121
    DFROBOT
    STEAMSENSOR
SEN0121 数据手册
  Steam Sensor (SKU:SEN0121)   Contents  1 Introduction 1.1 Applications 1.2 Specification 1.3 Connection Diagram 1.4 Sample Code Introduction This is a steam sensor from DFRobot. This steam sensor can be connected to the Arduino IO Expansion shield directly. The output voltage will increase when the humidity of the sensor surface goes up. Notice:The new version of analog sensor port pin mapping has been changed as the following two features. Warning: The connector is not waterproof, please be careful not to put the connector directly in water. Applications Simple rain detector Cheap steam level switch Touch sensor based on humidity Warning: The connector is not waterproof, please be careful not to put the connector directly in water. Specification     Power supply: 3.3v or 5v Output voltage signal: 0~4.5v(@5v) or 0~3.0v(@3.3v) Pin definition: Analog output(Blue wire) GND(Black wire) Power(Red wire) Size: 30x20x6mm Connection Diagram Stream_Sensor Connection Diagram Sample Code /******************************* Connection: VCC-5V GND-GND S-Analog pin 0 You can put the sensor on your palm, it may sense the humidity of your palm ********************************/ void setup() { Serial.begin(9600);// open serial port, set the baud rate to 9600 bps } void loop() { int sensorValue; sensorValue = analogRead(0); //connect Steam sensors to Analog 0 Serial.println(sensorValue); //print the value to serial delay(200); Powered By DFRobot © 2008-2017
SEN0121 价格&库存
很抱歉,暂时无法提供与“SEN0121”相匹配的价格&库存,您可以联系我们找货
SEN0121
  • 1+17.207131+2.23740
  • 3+15.121423+1.96620
库存:19
