DFR0076
DFR0076
    DFROBOT
    GRAVITY:ANALOGFLAMESENSOR
DFR0076 数据手册
    Flame sensor SKU: DFR0076 From Robot Wiki    Flame sensor V2    Contents      1 Introduction  2 Specification  3 Application  4 Tutorial   o 4.1 Connection Diagram  o 4.2 Sample Code  o 4.3 Result  5 FAQ  Introduction The flame sensor can be used to detect fire or other wavelength at 760 nm ~ 1100 nm light. In the fire-fighting robot game, the flame plays an important role in the probe, which can be used as the robot's eyes to find fire source or football. It can make use of fire-fighting robots, soccer robots. Flame sensor probe angle of 60 degrees, the special sensitivity of the flame spectrum, two M3 mounting holes to stabilize the module will not spin. The flame sensor's operating temperature is -25 degrees Celsius to 85 degrees Celsius, in the course of the flame it should be noted that the probe distance from the flame should not be too close inorder to avoid damage. The new version of analog sensor port pin mapping has been changed as the following two features.Please check the tips for changing sensor cable pin mapping while using the I/O Expansion shield. We will continue to update. For the inconvenience caused, please understand. Specification       Supply Voltage: 3.3V to 5V  Detection range: 20cm (4.8V) ~ 100cm (1V)  Rang of Spectral Bandwidth : 760nm to 1100nm  Responsive time : 15us  Interface: Analog  Size:22x30mm  Application   Fire alarm  Fire‐fighting robot  Tutorial Connection Diagram   connection diagram  Sample Code /* # Product: Flame sensor # SKU : DFR0076 # Description: # When flame sensor detected flame, the data will be read by the serial. */ void setup() { Serial.begin(9600); } void loop() { int sensorValue = analogRead(A0); Serial.println(sensorValue); } Result When the flame sensor detects the flame in the numerical change can be observed in the serial monitor. FAQ Q1. Some general Arduino Problems/ FAQ/ Tips, very good to know. A. Clike the topic link on DFRobot Forum.  Q2. Why my two flame sensors get different readings when to detect the same flame? A. It's normal. As an analog sensor, the readings would be effected by flame intensity, flame  position (angle & distance).  Q3. My flame sensor detects a flame without a flame present. At my desk it was reading values below 20, in my classroom students read value up to 800 without a flame present. A. The range of Spectral Bandwidth of the sensor is: 760nm to 1100nm, so it would detect any  light whose Spectral Bandwidth is within 760‐1100nm. After test, we found it can be effected  not only by flame, but also by infrared radiation (Analog read: 900), neon lamps in classrooms  (Thanks to Richard) and it can even be effected by phone's flash (Analog read: 50). Generally, in  our office, it outputs 0V (analog read: around 10). This can be found in its datasheet.  For any question/advice/cool idea to share, please visit DFRobot Forum.                                 Powered By DFRobot © 2008-2017
DFR0076
1. 物料型号:型号为EL817,是一种光耦器件。 2. 器件简介:EL817是一种通用型晶体管输出光电耦合器,具有较高的输入输出隔离电压和快速响应时间。 3. 引脚分配:EL817共有6个引脚,分别为1脚发光二极管阳极,2脚发光二极管阴极,3脚输出晶体管集电极,4脚输出晶体管发射极,5脚输出晶体管基极,6脚Vcc。 4. 参数特性:主要参数包括正向电流IF=20mA,反向电压VR=5V,输出低电平电压VOL=0.7V,输出高电平电压VOL=3.0V。 5. 功能详解:EL817通过光电效应实现电信号的隔离传输,常用于开关电源、测量设备等。 6. 应用信息:EL817适用于需要电气隔离的数字信号传输场合,如开关电源控制、传感器信号隔离等。 7. 封装信息:EL817采用DIP-6封装形式,尺寸为9.1mm×3.6mm×3.9mm。
DFR0076 价格&库存
很抱歉,暂时无法提供与“DFR0076”相匹配的价格&库存,您可以联系我们找货
DFR0076
  • 1+35.351861+4.56961
