DFR0023
DFR0023
    DFROBOT
    GRAVITY:ANALOGLM35LINEARTEMPE
DFR0023 数据手册
    DFRobot LM35 Linear Temperature Sensor (SKU:DFR0023) DFRobot LM35 Linear Temperature Sensor Contents      1 Introduction 2 Specification 3 Tutorial 3.1 Connection Diagram 3.2 Sample Code1 3.3 Sample Code 2 4 Trouble shooting 5 More Introduction The DFRobot LM35 Linear Temperature Sensor is based on the semiconductor LM35 temperature sensor. The DFRobot LM35 Linear Temperature Sensor can be used to detect ambient air temperature. This sensor is produced by National Semiconductor Corporation and offers a functional range between 0 degree Celsius to 100 degree Celsius. Sensitivity is 10mV per degree Celsius. The output voltage is proportional to the temperature. It is commonly used as a temperature measurement sensors. It includes thermocouples, platinum resistance, thermal resistance and temperature semiconductor chips, which commonly used in high temperature measurement thermocouples. Platinum resistance temperature used in the measurement of 800 degrees Celsius, while the thermal resistance and semiconductor temperature sensor suitable for measuring the temperature of 100-200 degrees or below, in which the application of a simple semiconductor temperature sensor has good linearity and high sensitivity. The LM35 linear temperature sensor and sensor-specific expansion of Arduino board, in combination, can be very easy to achieve. Specification     Based on the semiconductor LM35 temperature sensor Can be used to detect ambient air temperature Sensitivity: 10mV per degree Celcius Functional range: 0 degree Celsius to 100 degree Celsius Tutorial Connection Diagram Sample Code1 Library installation void setup() { Serial.begin(9600);//Set Baud Rate to 9600 bps } void loop() { int val; int dat; val=analogRead(0);//Connect LM35 on Analog 0 dat=(500 * val) /1024;; Serial.print("Temp:"); //Display the temperature on Serial monitor Serial.print(dat); Serial.println("C"); delay(500); } Sample Code 2 float tempC; int reading; int tempPin = 0; void setup() { Serial.begin(9600); analogReference(INTERNAL); } void loop() { reading = analogRead(tempPin); tempC = reading / 9.31; Serial.print("Temp:"); //Display the temperature on Serial monitor Serial.print(tempC); Serial.println("C"); delay(500); } Trouble shooting More question and cool idea,visit DFRobot Forum Powered By DFRobot © 2008-2017
DFR0023 价格&库存
很抱歉,暂时无法提供与“DFR0023”相匹配的价格&库存,您可以联系我们找货
DFR0023
  • 1+90.654671+11.74070
库存:35
